Ape92 Posted August 11, 2019 Posted August 11, 2019 Hi Everyone, I am having issues with Sega CD in Hyperspin, everytime I launch a game it crashes HS. I am using Android HS on my Shield, I have checked the following items: .ini file checked paths and spelling are good path=H: rompath=Roms/Sega CD/roms userompath=true exe=com.retroarch/com.retroarch.browser.retroactivity.RetroActivityFuture romextension=chd parameters=cores/genesis_plus_gx_libretro_android.so searchsubfolders=false pcgame=false winstate=HIDDEN hyperlaunch=true Per_Game_Modules=false Skipchecks=false Hide_Cursor=use_global Hide_Desktop=use_global Hide_Taskbar=use_global RA core is updated and I am on 1.7.7 BIOS (RA sees it and it is the right checksum) XML file checked matches ROM spelling The ROMs are good as I am able to load them up and play them on my PC via Launchbox, using Retroarch and the same core. Any suggestions where else I can look to troubleshoot? I am having the same issue with all CD based platforms NEC PC, TurboGraphx CD, Famicom Disk, MSX so I dont know if there is some other issue I have overlooked Thanks
Creezz67 Posted August 12, 2019 Posted August 12, 2019 CHD files may be the issue. Bin & cue are compatible, not sure about chd on android. They are ok on pc, but android may not play on Sega CD
Honosuseri Posted August 15, 2019 Posted August 15, 2019 On 8/12/2019 at 12:41 PM, cataclysm67 said: CHD files may be the issue. Bin & cue are compatible, not sure about chd on android. They are ok on pc, but android may not play on Sega CD Expand I use CHD for Sega CD (to save space). Just tested Tom Cat Alley on my Shield TV to make sure all is okay after the update and it plays directly from Hyperspin. I don't think the Picodrive core supports CHD but Genesis Plus GX does (even if it's not listed in the info section). "There is so much more and beckons me. To look through to these, infinite possibilities..."
