Guillermo075 Posted September 22, 2019 Posted September 22, 2019 I realized that sometimes the theme default does not load on my systems, I know that you have to be perfectly careful when it comes to upper and lower case, My question is, how should the name of the theme default be? default.zip, Default.zip, DEFAULT.zip or .ZIP? Thanks in advance!
Creezz67 Posted September 23, 2019 Posted September 23, 2019 Default.zip or default.zip should do it. Make sure inside default.zip that it is not in another folder or it may not load (all files should just be inside the zip, not in a folder)
Guillermo075 Posted September 23, 2019 Author Posted September 23, 2019 Thanks cataclysm67! Yes, the default.zip file have not folder inside, all files are in zip root, but sometimes don't load, this happened to me once time when the difference was for example pacman.zip or Pacman.zip, That's why I was asking but if it's the same I stay ok! Thank you !
