dsnyd22 Posted June 16, 2014 Posted June 16, 2014 Is there a way to set up hyperspin so when you run a particular system it will shut down xpadder or disable it. In my xbmc settings in hyperlaunchhq, i have expadder set to false but its not disabling it.
dougan78 Posted June 16, 2014 Posted June 16, 2014 Set it to use a blank profile for that system then it wont interfere with stuff. Sent from my SCH-I545 using Tapatalk
dsnyd22 Posted June 16, 2014 Author Posted June 16, 2014 thanks for your help. for whatever reason i really struggle with xpadder. i still cant get it too disable.
craiganderson Posted June 16, 2014 Posted June 16, 2014 xpadder is very confusing until you "get it" then its really easy particularly through hyperlaunchHQ couldnt imagine having 100 systems without xpadder to keep them all straight good luck http://craigandersonthemes.weebly.com/
dsnyd22 Posted June 16, 2014 Author Posted June 16, 2014 THanks! yeah thats exactly my problem. I ve never actually set up different profiles for different systems within hyperlaunch. I ve tried 2 or 3 times and i get closer each time. So far i only have 1 profile come up when hyperspin runs and it works fine but i cant get it to switch to another profile when i run particular emulators. ALso i thought i read that hyperspin supports joysticks/gamepads now, is this true?
demechman Posted June 17, 2014 Posted June 17, 2014 I am using the auto profile switching built into xpadder and it works well. The key is create a "blank" profile and set it as the default. I am working towards using hyper launch profile switching but it's a big hassle right and things are working well enough for now. Sent from my iPhone using Tapatalk
demechman Posted June 17, 2014 Posted June 17, 2014 I also forgot to mention that controller support in HS is a myth for now Sent from my iPhone using Tapatalk
dsnyd22 Posted June 26, 2014 Author Posted June 26, 2014 Alright sorry to bump this but if anyone can chime in to help me id be very thankful. Below is what i am trying to do. any comments on whether or not this is the right way or how to do this will be appreciated............ I want to start out with a Blank profile for xpadder. this is my default profile. I want this to be used for all games that i dont need keymapping for. when i start hyperspin, i want my hyperspin xpadder profile to kick in so my keyboard commands will work the wheel and pick games.... When i go to a particular system such as NES, i want the default profile to kick in, because nestopia works with my gamepad and i dont need xpadder whatsoever when playing nes.. However if i go to a system such as atari, i want an xpadder profile to kick in bc my atari emulator needs keymapping, joystick not supported. I have been trying to figure this out for over a year with no success, so if that makes sense to anybody, please help. Take Care!
dougan78 Posted June 26, 2014 Posted June 26, 2014 Turn off auto profile in xpadder. User hlhq to select what profiles you want to use for the front end and for each system. Setup the profiles in hlhq per controller per system. About all there is to it.
Cryofax Posted June 27, 2014 Posted June 27, 2014 Turn off auto profile in xpadder. User hlhq to select what profiles you want to use for the front end and for each system. Setup the profiles in hlhq per controller per system. About all there is to it. I chose the opposite. I use XPadder's autoprofile and it works flawlessly and is simple to set up. Doing it within XPadder also means it is completely portable if you don't use HyperLaunch. Is there any particular advantage to doing it within HL?
dsnyd22 Posted June 28, 2014 Author Posted June 28, 2014 yeah i chose opposite too. seemed almost too easy to setup blank profile then use autoprofile to assign most emulators blank profiles and a few custiomized profiles when needed. So glad i finally figured this out. At least for my 1st controller. not sure how to make 2nd controller work for all systems yet.
