ShadowPhoenix87 Posted May 4, 2020 Posted May 4, 2020 I have a lot of bezels for my mame games, however I have a default folder for bezels when a game does not have one. I did want to create my own other than the default for games that do not have one. So far I have created inside my bezels folder the image to the correct dimensions, named the .jpg to the same name as the game file inside of a folder labeled the same name as the game file. It still pulls the default bezel. I cannot seem to find a cfg file or where each game looks to pull a bezel from to change or redirect it correctly. Thanks.
gigapig Posted May 5, 2020 Posted May 5, 2020 If you have created a bezel for a particular game then the folder needs to be named the same as the game. The bezel inside needs to be named Bezel - game name. You will also need ini file with the coordinates and will be named the same as the bezel with .ini at the end.
