Some real nooby questions... but im stuck :(
SIMPLYAUSTIN
Like it says, I have been doing this for a while but I have a few niggles I aint ironed out yet....
First off the "PRESS START" and the "Joystick flash" at the bottom on the themes.... how the hell do you get rid of them???? I know you can go into HyperHQ and tick the boxes to disable them... but they just stay there?? Is there a way to delete them or what would be even better, have a better looking images with Xbox Pad Instructions as I dont use a cab, I have 4x 360 pads. If not... can they be deleted all together?
Next... Nintendo 64 boxes. Does anyone have any nice Nintendo 64 boxes? I have some but to be honest they just stick out like a sore thumb with the Unified Megatheme. Has anyone been good enough to update these? a 16:9 version would make my thirsty Thursday ;D
Other then that... Its Thursday, Im thirsty, England play in the world cup in 1 hour 30 and I will be as drunk as a skunk as I aint on duty tomoz!!! GET IN!!!!
Thanks guys
Thanks guys
I can address your fist question. In HyperHQ, select the Wheel Settings tab and then choose Main Menu. In the Special Art tab: Special Artwork A is the joystick and Special Artwork B is the "Press Start". Those files are located in .../HyperSpin/Media/Main Menu/Images/Special:
SpecialA1.swf is the Next System Joystick
SpecialA2.swf is the Previous System Joystick
SpecialB1.swf is the Press Start Text
SpecialB2.swf is the Free Play Text
In HyperHQ, if you select a System Wheel. Special Artwork A is the Joystick and Special Artwork B is the Free Play Text.
[EDIT]
Special Artwork C is the Current Genre Text.
[/EDIT]
In each System Name folder (.../HyperLaunch/Media/AAE/Images/Special) is also a set of Special images:
SpecialA1.swf is the Previous Game Joystick
SpecialA2.swf is the Next Game Joystick
SpecialA3.swf is the Jump Forward Joystick
SpecialA4.swf is the Jump Backward Joystick
So, you can delete them or any number of them. Or just turn them off. There is also a couple of new sets of joystick artwork here:
http://www.hyperspin-fe.com/forum/showthread.php?25272-Hyperspin-Bat-top-Joystick-Manicshere-amp-Donnei1979(20130576)
Hope this helps some.
Thanks,
Ron
Thanks for that Ron, it was really doing my head in! I thought it was those check boxes "Remove Text Box Info!" etc... now Im good!
Now I just need to hunt some good N64 boxes... Famicom Vids.... PC Engine doesnt show the game theme screen and wheel art for that also... so much to do and only a crate of beer to get me through it! Its going to be a long night :(
Right, here we go again with one of my really noobie questions again. I have the newest MAMe set 53. I have the CHDs and he ROMS. A tthe moment I have just been running these from the rom folder as I didnt have space. Now I have got the space for he CHDs.
My question is how do I let MAME run with both CHDs AND Roms with Hyperlaunch?
As in the chds usually come in folders named after the roms. You want all those folders put into your roms folder. Just wanted to clarify.
Sent from my SCH-I545 using Tapatalk
Yes I have the matching sets, both have the ROMS and CHDs in folders with the names, so if I was to copy over they would go into the correct folders.
However if I was to keep them in a CHD folder and a ROMs folder, add both these folders to the MAME folder list. Then in HLHQ add both of these folders.... would that work? Sorry to be a pain. Would just like if possible to keep these unmerged.
I have a roms folder. That has the roms zipped. Then has subfolders for each game that has a chd by rom name so in essence they are separated. not sure about 2 separate folders. I know when I had it that way it did not work.
However if I was to keep them in a CHD folder and a ROMs folder, add both these folders to the MAME folder list. Then in HLHQ add both of there folders.... would that work? Sorry to be a pain. Would just like if possible to keep these unmerged.
This works fine for me. Just add your CHD folder in HLHQ and try it out.
Sent from my phone with Tapatalk.
