irondragoon Posted February 20, 2011 Posted February 20, 2011 I have the default theme installed. So I went and got Circo's movies. Is it just me or does everyone have the white bar at the top between the video and the top of the purple gameboy as if the video isn't positioned high enough on it's Y coordinate? Is it suppose to be like that? Setup Multiple Systems on One wheel
jahilton2002 Posted February 20, 2011 Posted February 20, 2011 irondragoon said: I have the default theme installed. So I went and got Circo's movies.Is it just me or does everyone have the white bar at the top between the video and the top of the purple gameboy as if the video isn't positioned high enough on it's Y coordinate? Is it suppose to be like that? you can edit this in hypertheme
irondragoon Posted February 20, 2011 Author Posted February 20, 2011 When I load it in HyperTheme I can't seem to find a button to get it to load: <video w="309" h="340" x="300" y="430" r="-15" time=".5" bcolor="0x000000" bcolor2="0x000000" bcolor3="0x000000" bsize="0" bsize2="0" bsize3="0" bshape="square" type="ease" start="left" forceaspect="none" below="false" /> so I can't see what I'm doing. It only load Artwork1.png, background.png and the simulated Artwork2 like the video tutorial indicated. Video.png is MIA as well. Setup Multiple Systems on One wheel
jahilton2002 Posted February 20, 2011 Posted February 20, 2011 i'll upload mine to the ftp....... under jahilton2002 tell me when you've got them... so i can remove them
irondragoon Posted February 20, 2011 Author Posted February 20, 2011 Thanks! With the Video Overlay you provided and the original everything else the video is sitting exactly where it is suppose to be. Setup Multiple Systems on One wheel
irondragoon Posted February 20, 2011 Author Posted February 20, 2011 Sure thing. Thanks again. Setup Multiple Systems on One wheel
Swanksta Posted March 16, 2011 Posted March 16, 2011 sorry to bump an old thread but im having the same problem could i use yours as well jahilton?
irondragoon Posted March 17, 2011 Author Posted March 17, 2011 It's in my upload folder now. Setup Multiple Systems on One wheel
trancechris Posted November 14, 2011 Posted November 14, 2011 Found it on the ftp, been looking for this "fix". Thank you, and sorry for the bump.
F3rrY Posted August 22, 2012 Posted August 22, 2012 Hi everyone. Sorry for bump the post but I have the same issue that yours and cannot fix it. I changed the "W" and "H" and compress "Stored" but the problem continues. For your information, I don't have access to the FTP. ¿Can any paste the XML parameters of the Default theme? I wait for your answers. Thanks, regards
F3rrY Posted August 23, 2012 Posted August 23, 2012 Hi there! At last, the problem is solved (I do it myself) Thanks. Regards
irondragoon Posted August 23, 2012 Author Posted August 23, 2012 Why not post the solution instead of just telling everyone you fixed it? I wish the download would come with a fixed theme. Then this topic would be solved. Setup Multiple Systems on One wheel
jahilton2002 Posted August 23, 2012 Posted August 23, 2012 i fix this ages ago..... and uploaded the fixed theme......it appears in hyper sync as a alt option..... but you can only use hyper sync and a plat user.
irondragoon Posted August 23, 2012 Author Posted August 23, 2012 Yeah but Ferry isn't even gold? When did you download your Hyperspin Ferry? Setup Multiple Systems on One wheel
evil eye Posted August 23, 2012 Posted August 23, 2012 Hyperspin is free, you don't need to be a Gold member to download it. He meant he fixed the theme himself in HyperTheme, he didn't download the fixed one from the FTP or HyperSync.
irondragoon Posted August 23, 2012 Author Posted August 23, 2012 Ya...I know. I was wondering if he downloaded Hyperspin over a year ago or before jahilton fixed the theme and is just now implementing gameboy advance since obviously he didn't get a broken alt version from HyperSync or the corrected version from the FTP. Setup Multiple Systems on One wheel
evil eye Posted August 23, 2012 Posted August 23, 2012 You bring up a good point, I wonder if the HS package has the new fixed theme or not? If not, then even new members will have this issue, unless they go platinum or gold.
F3rrY Posted August 24, 2012 Posted August 24, 2012 Hi everyone! Well, I downloaded Hyperspin the last month and the only problem that I had was the GameBoy Advance's Theme. Unfortunately, the themes are not updated in the page web. For your information, I don't use HyperTheme software to fix it. I have a degree in Information Technology (I'm a computer nerd or freak) and well, I fixed the XML that have the Theme. Many attributes (like "W", "H" and other) aren't good. The only that I can do is give a advice: Do a maintenance of the material that have the web, because that (for example) if people knows that the GameBoy Advance have a problem, the Theme must be replaced for the repaired theme. But if the only answer are that the repaired theme are in the FTP, the users like me who don't have access have a problem. One thing is have the FTP for material and another is have material broken in the web for obligate the users become gold members to download the repaired things. Think about it Thanks, regards.
evil eye Posted August 24, 2012 Posted August 24, 2012 Well that answers that question. Thanks! I don't believe anyone is purposefully not updating the HS download with the correct theme, its just that only a handful of people (maybe just BBB) have the ability to fix it, and they're not aware of the issue. I think you should send a PM to BadBoyBill and let him know what's up.
azzajess Posted May 19, 2014 Posted May 19, 2014 Sorry to revive an old thread however recently i ran into the same problem with the theme off hypersync. So i came across this thread and downloaded the 'fix' for for it however it wasnt detecting my artwork from folder 3 and 4 like the theme off hypersync did. To fix this, what i did was download the 'fix' from irondragoon's FTP and used the lines the artwork line of code in the XML from the hypersync theme (Old one) and apply it to the XML in the irondragoon's fixed version XML in the zip. If this sounds a bit complicated you can download it from my FTP folder (azzajess). Just remember to make a backup of original theme. Sorry if the 'fix' sounds a bit complicated for some...
zerojay Posted May 19, 2014 Posted May 19, 2014 I was just about to fix this on my install myself. You can also use HyperSync and choose jahilton2002's version of the system theme to fix it.
binderjustin Posted May 21, 2014 Posted May 21, 2014 Is there anyone willing to help out a new user with the fixed theme? I love Hyperspin, and that white bar is the only blemish so far. It would be appreciated Thanks
azzajess Posted July 2, 2014 Posted July 2, 2014 binderjustin said: Is there anyone willing to help out a new user with the fixed theme? I love Hyperspin, and that white bar is the only blemish so far. It would be appreciated Thanks To make it less complicated, just simply download the fixed theme in my FTP under Upload Here/azzajess/Nintendo Gameboy Advance/Themes Just remember to make a backup of your original one in case something goes wrong. Let me know how you went, and feel free to ask any question if need be.
