N64 zips wont load in RA
thenoob
Retroarch, perfect set N64
mupen64us Gles3 core , tried 2 and 3, zips won’t load. Does N64 need to be unzipped for Retroarch?
i scanned the directory and they games show, but won’t launch with cores... any ideas?
So I see on the core Info that .zip is not supported for both n64 cores. Any options or do I have to unzip all of them?
Expand
Are you using RocketLauncher with your setup ?
If so, just set zip option to true and this will sort out the issue.
Expand
Maybe mention that in your posts ?
Yes the ini has an option and if zipped you would usually need to add zip,7z in the exe line of the ini, though for N64 you will need to unzip them if you are using Android.
