thenoob Posted August 3, 2021 Posted August 3, 2021 Ok almost finished n64 won’t launch in RA either. seems zip support on both cores mupen64plusNextGles2/3 do not have zip support. any way around this? I checked the n64 ini file and no way to turn on but if the core doesn’t support zip, what do you do? What are the options? Tried to look for diff cores all I can find are these 2 and both don’t support zip
Creezz67 Posted August 4, 2021 Posted August 4, 2021 On 8/3/2021 at 7:00 PM, thenoob said: Ok almost finished n64 won’t launch in RA either. seems zip support on both cores mupen64plusNextGles2/3 do not have zip support. any way around this? I checked the n64 ini file and no way to turn on but if the core doesn’t support zip, what do you do? What are the options? Tried to look for diff cores all I can find are these 2 and both don’t support zip Expand Download Mupen64 from Google Play and then change your ini file to this: https://play.google.com/store/apps/details?id=org.mupen64plusae.v3.fzurita&hl=en_GB&gl=US You will need to extract your roms for it to work (N64 game sizes are small so not much difference after being unzipped) exe=org.mupen64plusae.v3.fzurita/paulscode.android.mupen64plusae.SplashActivity parameters= romextension=z64,n64,v64
