anthony001 Posted March 5, 2022 Posted March 5, 2022 Hi I am currently using hyperspin/rocketlauncher on win10 and have already upgraded to 1.5.1 was wondering how I can use ahk to navigate on hyperspin without it being active on other game. I set the compiled version of the ahk to the startup script on hyperhq these are my current setup. havent tried mapping the direction button yet since i dont know how. how do i make the ahk not work when im in game? how do i make it so that i can exit the game without me pressing it accidentally and exiting the game ``` Joy3::Send {Enter} Joy2::Send {Esc} ```
Spawk Posted March 5, 2022 Posted March 5, 2022 Quote To use it Open HyperHQ, Go to Main Settings -> Startup\Exit -> and set the .exe file as your startup program. How to make it work: Run it once, a new file should appear in the folder it is in. It's name will be the same name as this program and will have the extension "ini" Open the ini file. You should see some of the settings described below. This ini is where you should set the keys. No need to create your own ahk
anthony001 Posted March 8, 2022 Author Posted March 8, 2022 On 3/5/2022 at 12:33 PM, Spawk said: This ini is where you should set the keys. No need to create your own ahk so in hyperhq i should enable joystick? i really dont know what i will be putting in the ini file, can you tell me the values i can put and its corresponding action?
Spawk Posted March 8, 2022 Posted March 8, 2022 ??? No, you do NOT enable joysticks in HQ! Everything you need to know is on the page where you downloaded the Startup Script! I guess I could have quoted more of it: Quote How to make it work: Run it once, a new file should appear in the folder it is in. It's name will be the same name as this program and will have the extension "ini" Open the ini file. You should see some of the settings described below. [Required] HyperSpin_Folder_Path REQUIRED! is the path to the folder containing hyperspin.exe (Default is .\ which would be the same folder as the startup script. ..\ means one folder up. ..\..\ would mean two folders up). Absolute paths are still accepted. Primary_Color_RRGGBB is the background color of the menus given in a hex rrggbb format. Examples and a color picker can be found here. Secondary_Color_RRGGBB is the background color of the menus given in a hex rrggbb format. Examples and a color picker can be found here. [Controls] Joysticks_Enabled can be true or false. Set this to true to use a joystick or gamepad with hyperspin. May work for controllers other than the 360 controller. Joystick_Delay is the number of milliseconds to wait before repeating for only the hyperspin startup menus Joystick_Deadzone is a number between 0 and 49 representing the size of the axis deadzone for every axis. 0 is the most sensitive. 49 is the least sensitive. Joysticks_MaxNumberOfJoysticks is a number between 1 and 16 that represents how many joysticks you want to use at the same time (using same control layout) to control hyperspin Joystick_Up, Joystick_Down, Joystick_SkipUp, Joystick_SkipDown, Joystick_SkipUpNumber, Joystick_SkipDownNumber, Joystick_HyperSpin, Joystick_Genre, Joystick_Favorites, Joystick_Start and Joystick_Exit do the same thing as their HyperSpin keyboard counterparts. Joystick_Roulette, Joystick_Volume, Joystick_Volume_Close, Joystick_QuickLaunch and Joystick_QuickLaunch_Close joystick controls for roulette, volume bar and quicklaunch bar. Joystick_Info, Joystick_Info_Close, Joystick_Filters and Joystick_Filters_Close are not yet implemented, need to be able to receive Event Dispatcher info, com xml code are needed to get these controls to work. Joystick control options in the settings are separated by a vertical bar delimiter | . The joystick control options available are as follows for axis: JoyX-, JoyX+, JoyY-, JoyY+, JoyZ-, JoyZ+, JoyR-, JoyR+, JoyU-, JoyU+, JoyV- and JoyV+ for dpad/hat switch: JoyPOVN, JoyPOVE, JoyPOVS and JoyPOVW for buttons: Joy1, Joy2, Joy3, Joy4, Joy5, Joy6, Joy7, Joy8, Joy9, Joy10, Joy11, Joy12, Joy13, Joy14, Joy15, Joy16, Joy17, Joy18, Joy19, Joy20, Joy21, Joy22, Joy23, Joy24, Joy25, Joy26, Joy27, Joy28, Joy29, Joy30, Joy31 and Joy32 ^^ here are the joypad codes There are a couple of different sections to the ini, read about them on the download page:
yoann Posted May 23, 2022 Posted May 23, 2022 Is there a solution that natively allows you to use an xbox one controller for example without going through a jconfig type tool. I configured everything in hyperHQ but no controllers work to navigate in hyperspin. I have to use jconfig. an idea ?
Spawk Posted May 23, 2022 Posted May 23, 2022 HQ's joystick options have NEVER been a reliable way to configure. That's why we all use either the "Startup Script" or a keymapper like JoyToKey or Xpadder.
yoann Posted May 23, 2022 Posted May 23, 2022 Ok thx what's the difference between Startup Script and joytokey ? I'm using joytokey a this time
