Ciao, tryed to put sxs.dll on the folder but when I click on hyperspin.exe nothing happened. If I check in task manager I can see hyperspin proccess start and then close.
Any idea?
Thank you
  • taribo changed the title to HS issue on Windows 11
  • 4 weeks later...
Thx @awok559 but I already tried a lot of time to reinstal HS and fix the sxs.dll but always same issue... appear and immidiatly disapper from task manager.
Works fine on Windows 11 Home (64bit) version 21H2
Been using it for over a year with the sxs.dll
I haven't had any issues with any Windows 10 updates. I would try running Hyperspin as an administrator, if that doesn't work check Windows 10 system file checker using the steps below.
1. In the Windows search bar, type "cmd".
2. Right-click on the command prompt, and select "Run as administrator".
3. Type sfc /scannow in the command window and press enter.  Let the the scan complete.
4. Try running Hyperspin.
Also, it helps to add your HyperSpin folder as an exception in your antivirus app, as many will wreak havoc via false-positive alerts.
  • 1 year later...
1 MENÚ/ configuraciónes
2 aplicaciones
3 CONFIGURACIÓN AVANZADA de Aplicaciones
3 elimar actualización
4 elimina la última actualización 24 y también SEGURIDAD
Ya puedes ingresar a tu hyperspin sin problemas
  •  Finally !!!!!!!
Hyperspin 2 is coming 😀 :thumbsup:
I know one person that won't be happy about it ..... Jason Carr !! 🤣
And if you don't go and read the announcement on FB, remember this site will be down for a few days from tomorrow to get it all sorted.
1 thing i read .... the 24H2 problem will be no more !!!!
From Andyman
 https://www.facebook.com/therealhyperspin/posts/pfbid02oaam4b6xjJ9pwQsQNVCeK88kLMLw2yaUaS9oQEUThRV8VD84EexVX9gkKipbda5Jl
... that's all I'm at liberty to say right now. See? I told you things only seemed quiet around here! 😁
  • 1 year later...
Any idea?
Thank you
thanks for the information!
