Creezz67 Posted March 12, 2023 Posted March 12, 2023 Does anyone know how to fix this cfg file (see attached) so it works with MAME 0.252 ? All working fine for previous MAME builds all the way up to MAME 0.251, but now Start + Select not working (lots of changes were done on MAME 0.252) Tried fixing, but can't find the right button combination that works. I am hoping the person that created it all those years ago will see this post (or someone with the skills to fix it obviously) Thanks in advance ps, All working fine once Coin + Start pressed on keyboard. XARCADE_XBox360x4.cfg
floatingyeti Posted March 15, 2023 Posted March 15, 2023 "Joy # Select" has been renamed to "Joy # Back" in the current MAME input menu This might be bad, VERY bad! You might be able to fix it by using a find and replace for: JOYCODE_1_BUTTON7 -> JOYCODE_1_START JOYCODE_1_BUTTON8 -> JOYCODE_1_SELECT Replace for JOYCODE_1 to JOYCODE_4 I made identical remap cfg for 1941 in both MAME 251 and 252 and the resulting cfgs had identical values for the start/select buttons so our existing remaps might still work in 252.
floatingyeti Posted March 15, 2023 Posted March 15, 2023 I replaced all: "_BUTTON7" with "_START" "_BUTTON8" with "_SELECT" See if that works XARCADE_XBox360x4.cfg
Creezz67 Posted March 15, 2023 Author Posted March 15, 2023 1 hour ago, floatingyeti said: I replaced all: "_BUTTON7" with "_START" "_BUTTON8" with "_SELECT" See if that works XARCADE_XBox360x4.cfg 35.26 kB · 1 download Thanks Start + Coin working fine now, but the only thing not working now is the D Pad (analog working fine) MAME 0.252 has completely messed this ctrl file up. Can you use the D pad on 1941 with this ctrl file ? Thanks
floatingyeti Posted March 15, 2023 Posted March 15, 2023 6 hours ago, Creezz67 said: Start + Coin working fine now, but the only thing not working now is the D Pad (analog working fine) I will check later today and see if I can rename the dpad values.
Creezz67 Posted March 15, 2023 Author Posted March 15, 2023 6 minutes ago, floatingyeti said: I will check later today and see if I can rename the dpad values. Nice one
floatingyeti Posted March 16, 2023 Posted March 16, 2023 This looks tricky. all DPAD values are changed to HAT(#) Example: JOYCODE_1_DPADLEFT -> JOYCODE_1_HAT1LEFT Let's see if I can find and replace all the right text but it's a bit much. If this doesn't work the whole XARCADE_XBOX360x4.cfg needs to be redone.
floatingyeti Posted March 16, 2023 Posted March 16, 2023 OK I altered all instances of: 1_DPAD -> 1_HAT1 2_DPAD -> 2_HAT2 3_DPAD -> 3_HAT3 4_DPAD -> 4_HAT4 Let me know if that works. If it doesn't, then I won't be able to "fix" the cfg. Too much has changed in MAME and it will have to be completely redone. XARCADE_XBox360x4.cfg
Creezz67 Posted March 16, 2023 Author Posted March 16, 2023 3 hours ago, floatingyeti said: OK I altered all instances of: 1_DPAD -> 1_HAT1 2_DPAD -> 2_HAT2 3_DPAD -> 3_HAT3 4_DPAD -> 4_HAT4 Let me know if that works. If it doesn't, then I won't be able to "fix" the cfg. Too much has changed in MAME and it will have to be completely redone. XARCADE_XBox360x4.cfg 35.26 kB · 0 downloads You have done it !!! Now all working like it did on MAME 0.251 i have literally been using it for over 10 years with no issues at all ... until MAME 0.252 Thanks for your help.
