tdspin Posted May 16, 2023 Posted May 16, 2023 I'm trying to filter my MAME wheel in Hyperhq like I have done with my other systems, to show only the games I have but for someone reason it's not working for MAME. When I check Roms Only and try to go to the wheel in Hyperspin, there's no games. Is there something different you have to do for MAME? When there's no filter, everything shows and the ROMs I do have, work fine. Thanks.
jesfknkrys Posted May 19, 2023 Posted May 19, 2023 Do you have the MAME.xml created under "Hyperspin\databases\mame"?
Andyman Posted May 24, 2023 Posted May 24, 2023 You may encounter that problem when using a merged MAME set. Split and unmerged work best. Also, double-check to make sure the rom extension and path are correct in HyperHQ for MAME. As an alternative, you can filter another way, such as Themes Only, and keep only the themes for games you have in the Media/MAME/Themes folder.
floatingyeti Posted May 26, 2023 Posted May 26, 2023 That has happened to me because extentions are case sensitive in HyperHQ but not case sensitive in RocketlauncherUI For every extension in HyperHQ list both upper and lower case variations. Example (MAME) 7z,7Z,zip,ZIP I follow this rule for every system and have not had the issue since.
