Creezz67 Posted November 30, 2024 Posted November 30, 2024 Hi all, Has anyone managed to get this working in Hyperspin ? I tried this bat file but can't get it to work using PCLAUNCHER module ... shadPS4.exe "D:\Hyperspin\emulators\shadPS4\ps4 games\CUSA00319\\eboot.bin If I remove "D:\Hyperspin\emulators\shadPS4\ps4 games\CUSA00319\\eboot.bin, the emulator opens fine using the bat file, so it must be an error somewhere in the line ? Any help appreciated
brudibru Posted November 30, 2024 Posted November 30, 2024 Creez67, you have to add -g after shadps4.exe (like this: shadPS4.exe -g "H:\Hyperspin\Emulators\Shad PS4\games\CUSA08791\eboot.bin") It works for me 1
Creezz67 Posted November 30, 2024 Author Posted November 30, 2024 9 minutes ago, brudibru said: Creez67, you have to add -g after shadps4.exe (like this: shadPS4.exe -g "H:\Hyperspin\Emulators\Shad PS4\games\CUSA08791\eboot.bin") It works for me No luck here. What settings do you have in RocketLauncher ? Anything specific ?
Creezz67 Posted November 30, 2024 Author Posted November 30, 2024 8 minutes ago, Creezz67 said: No luck here. What settings do you have in RocketLauncher ? Anything specific ? This is what I used ... shadPS4.exe -g "D:\Hyperspin\emulators\shadPS4\ps4 games\CUSA00319\eboot.bin" should the " be at the start AND the end ?
brudibru Posted November 30, 2024 Posted November 30, 2024 I have only tried a .bat file so far, but I guess it should work with pclauncher if the bat file works. Your command line is correct, I don't understand why it doesn't work. Are you using the latest version of shadPS4 ? They have changed a few things recently concerning the command lines 1
brudibru Posted November 30, 2024 Posted November 30, 2024 I have just tested it and It works for me with PCLauncher as well. I have just selected the rom and emu skipchecks in RocketLauncher 1
Creezz67 Posted November 30, 2024 Author Posted November 30, 2024 4 hours ago, brudibru said: I have just tested it and It works for me with PCLauncher as well. I have just selected the rom and emu skipchecks in RocketLauncher All working now. Thanks
Creezz67 Posted November 30, 2024 Author Posted November 30, 2024 4 hours ago, brudibru said: I have only tried a .bat file so far, but I guess it should work with pclauncher if the bat file works. Your command line is correct, I don't understand why it doesn't work. Are you using the latest version of shadPS4 ? They have changed a few things recently concerning the command lines Yes using latest version and updates (nightly updates)
brudibru Posted December 1, 2024 Posted December 1, 2024 11 hours ago, Creezz67 said: All working now. Thanks Cool. I also had that problem with ShadPS4 losing focus and the RocketLauncher GUI popping up in front so I had to determine the fade title of the game with the method provided with PCLauncher. I don't know if it comes only with my computer but doing that for each games could be a drag even if there are only a few working for now. That's the problem with not having a proper module for ShadPS4 (I am too incompetent myself to create one, I'm afraid).
Creezz67 Posted December 1, 2024 Author Posted December 1, 2024 6 minutes ago, brudibru said: Cool. I also had that problem with ShadPS4 losing focus and the RocketLauncher GUI popping up in front so I had to determine the fade title of the game with the method provided with PCLauncher. I don't know if it comes only with my computer but doing that for each games could be a drag even if there are only a few working for now. That's the problem with not having a proper module for ShadPS4 (I am too incompetent myself to create one, I'm afraid). Where are you putting your bat files ? In a separate folder ? Also, use nightly update rather than release on update channel (settings/configure in emulator) as for some reason they act differently. Où placez-vous vos fichiers bat ? Dans un dossier séparé ? De plus, utilisez la mise à jour nocturne plutôt que la publication sur le canal de mise à jour (paramètres/configuration dans l'émulateur) car pour une raison quelconque, ils agissent différemment.
brudibru Posted December 1, 2024 Posted December 1, 2024 I put the bat file in the root of the shadPS4 folder so you I had no need to write down the whole path to the exe in the bat file. But it sure would be cleaner to put them in a separate dedicated folder. I haven't set up this system yet, just tried on one game to see if it was working. I also use the nightly updates of ShadPS4.
Creezz67 Posted December 1, 2024 Author Posted December 1, 2024 29 minutes ago, brudibru said: I put the bat file in the root of the shadPS4 folder so you I had no need to write down the whole path to the exe in the bat file. But it sure would be cleaner to put them in a separate dedicated folder. I haven't set up this system yet, just tried on one game to see if it was working. I also use the nightly updates of ShadPS4. FYI, That's why mine didn't work previously. I put them all in a separate folder and no luck, but when I put them all in the root with the exe all working fine. Just need to find the missing command that lets you put them in a folder on their own, as I have other bat files like PSVita that work fine in their own folder.
Create an account
Register a new accountSign in
Sign In Now
