Bug - HyperSpin completely unusable - No media displayed, and wheel unresponsive when trying to scroll
I've got 8 systems 'setup' at this point.  Hyperspin takes 50 second to 3 minutes to load.  When it finally loads, if I try and rotate the main wheel up or down, after a few moves, it completely dies.  I have to alt-f4 out of the program.  Clear logos and themes never display.   Looks like this:
At first I thought maybe the trackball was overloading the 'move' buffer, so I disabled it, but that didn't make a difference.
I tried clearing all the image cache, that didn't help.   Tried disabling LEDBLinky too.  No help.
HyperSpin.exe is also consuming 3.2+ GB of memory, which seems really excessive.  (my other front end with a lot more going on only uses 590mb)
These are the 'systems' i have provisioned so far in HyperHQ.
I'm not sure what I can provide to help debug this one, so please let me know how I can help.
thanks,
Most of my systems were able to download media but some wouldn't for whatever reason. I am curious where the meta data for games is being pulled from which is probably the issue. Some main menu themes won't display even after downloading and clearing cache as well. Setting up emulators is working as advertised and I really like the design of the app.
Mame is the culprit. Delete Mame and readd it, but before you do turn the autoscraper off. When you first install Mame, you'll filter out when you don't want (casino, adult etc). It works fine from there. The autoscraper then wants to fill back in the other 30K roms. That froze mine up.
CydXero
2 hours ago, Fursphere said:
So..  can't use auto-import in the current builds if you're using MAME.   Got it.
For now, I'm sure that's on the list of fixes.
CydXero
