doozerhhh Posted January 14 Posted January 14 nello I installed hperhq in a disk called D so everything is installed well except that with each update hyperhq is installed in C program files so I don't know if this is normal
0 fr0stbyt3 Posted January 14 Posted January 14 10 hours ago, Fursphere said: The hyperhq installer (and updated) is bugged. So if you 'update' it'll auto-install on the C:\ drive, even if you originally installed it on D:\ (or where ever). They're working on a fix. this was a bug with the installer itself that is fixed now. If you uninstall and install 2.0.33 you should be good to go from now on.
0 Fursphere Posted January 14 Posted January 14 The hyperhq installer (and updated) is bugged. So if you 'update' it'll auto-install on the C:\ drive, even if you originally installed it on D:\ (or where ever). They're working on a fix.
0 doozerhhh Posted January 14 Author Posted January 14 4 minutes ago, Fursphere said: The hyperhq installer (and updated) is bugged. So if you 'update' it'll auto-install on the C:\ drive, even if you originally installed it on D:\ (or where ever). They're working on a fix. ah ok thanks
0 Creezz67 Posted January 14 Posted January 14 Just updated from 2.0.31 to 2.0.33 and it still updated to the wrong drive C:\ Copied it to my D:\ drive location, installed a new system and now it is finally putting ALL the media and videos in the correct location, rather than sending it all to C:\ as it was before 1
0 honda Posted January 14 Posted January 14 I'm pretty sure 33 does this too still I had to copy all the files from c:\program files back over to my f:\ drive
Question
doozerhhh
nello
5 answers to this question
