nello
I installed hperhq in a disk called D
so everything is installed well except that with each update hyperhq is installed in C program files
so I don't know if this is normal
The hyperhq installer (and updated) is bugged.  So if you 'update' it'll auto-install on the C:\ drive, even if you originally installed it on D:\ (or where ever).
They're working on a fix.
ah ok thanks
Just updated from 2.0.31 to 2.0.33 and it still updated to the wrong drive C:\
Copied it to my D:\ drive location, installed a new system and now it is finally putting ALL the media and videos in the correct location, rather than sending it all to C:\ as it was before 👍
this was a bug with the installer itself that is fixed now. If you uninstall and install 2.0.33 you should be good to go from now on.
I'm pretty sure 33 does this too still I had to copy all the files from c:\program files back over to my f:\ drive
