Renaming artwork
Emu54
Hi just checking is there a app that can rename my artwork to match my roms lot of work renaming individually
Artwork 4 Wheel Thunder v1.002 (2000)(Midway)(NTSC)(US)[!]
Rom 4 Wheel Thunder (USA)
why would you wan't to do this?
if you rename your artwork 4 to match your rom name you will also have to
- make your own XML
-rename all your disc images
-rename your box images
-rename your videos
-rename your wheels
if you rename your artwork to match your roms, you will have to do 4 times the work and make your own XML.
The way I do it is by using Hyperspin Rom Manager 1.1c, and putting png in the search type (where it says 7zip, zip, rar). Use whatever XML you want.
Works pretty good but you still will have to go through and make sure it matched the images to the xml properly.
Hope this helps.
