Hald2k Posted December 22, 2025 Posted December 22, 2025 Hello. I have a problem with the latest Hyperspin 2 install, I installed HQ (on Drive E:) and Hyperspin but i get a blank screen when HS boots up. I have tried reinstalling plugins, i have tried deleting the cache, i have tried uninstalling HQ and deleting leftover folders. Fresh install dont solve it. So i moved to my other computer, lets call it computer number 2. Did install HQ at preset path (C:), HS was working! . wanted to try have it on another drive so i deleted everything. installed it again on Drive D; Got the same problem again on this computer also. Uninstalled and tried to install it in the working preset path at drive C:, Same problem, HS not working for me anymore on my 2 computers. So when i launch HS the loading bar stops just after it says Loading Wheel then jumps directly into HS, Can anyone point me how to use logs for this matter? or if you have any other ideas? i have a picture of HS screen, Kind Regards
Circo Posted December 22, 2025 Posted December 22, 2025 @Hald2kWe had this alot in testing. It's a byproduct of different media systems. This is a good time for fresh install, and by fresh I mean all the way fresh. Go into c:/users/username and delete the .HyperHQ and .HyperSpin folders etc. Then when you reinstall its going to build 100% new databases etc. I think this is the full list, havent had to do it in awhile now. c:/users/username/appdata/roaming/HyperHQ c:/users/username/appdata/roaming/HyperSpin c:/users/username/.HyperHQ c:/users/username/.HyperSpin I think that this is everything and you shouldn't have to do this again in the future. Let me know how you get on ___________________________________ HyperSpin Website Admin Team Also Visit EmuMovies.com
Hald2k Posted December 25, 2025 Author Posted December 25, 2025 Hey! ive tried uninstalling and then deleting the folders of the four locations you mentioned, Did a fresh install but it still wont show any themes. im on Hyperspin App version: 2.0.65 Hyper HQ v2.0.121 These are my first installs. i havnt been able to try Hyperspin 2 once :(.
Solution Circo Posted December 26, 2025 Solution Posted December 26, 2025 23 hours ago, Hald2k said: Hey! ive tried uninstalling and then deleting the folders of the four locations you mentioned, Did a fresh install but it still wont show any themes. im on Hyperspin App version: 2.0.65 Hyper HQ v2.0.121 These are my first installs. i havnt been able to try Hyperspin 2 once :(. We will get this figured out I sent a note to the dev team to come take a look at this. Couple of questions: What systems do you have installed in HyperHQ? Are you seeing any related errors in the log viewer? (See Below) Best to get some details to troubleshoot this faster. Since it wasn't mentioned, until you have setup a System in HQ nothing will populate in HyperSpin. IE, if you did a fresh install and then went to hypertheme and clicked download on the snes theme, it wouldn't populate. The system and games need to be set up and then the default theme will populate and that can be changed in HyperTheme. Can you provide a screenshot of what you see in the systems/game view of Hyper HQ? If you haven't seen it yet, check out the getting started guide and see if there is anything that stands out. https://docs.hyperai.io/docs/hyperhq/getting-started EDIT: Spoke with @fr0stbyt3 and he discovered that logging for HyperSpin is disabled in error, and though there is a checkbox to enable it, that is in the wrong place (beta problems) . ___________________________________ HyperSpin Website Admin Team Also Visit EmuMovies.com
fr0stbyt3 Posted December 26, 2025 Posted December 26, 2025 @Hald2k We're looking into this. In addition to making sure you have at least one system installed, there is a process that runs that makes sure the cache gets built before first run. Depending on the speed of your system this can take up to a minute. Try a smaller console just to get you going and see if it works. Last, can you verify you have media showing in the media tab in HyperHQ? 1
Hald2k Posted December 27, 2025 Author Posted December 27, 2025 [2025-12-27 21:04:08.805] [info] App starting... [2025-12-27 21:04:08.810] [info] App version: 2.0.65 [2025-12-27 21:04:08.811] [info] App path: C:\Users\NotöDator2\Desktop\Hyperspin\resources\app.asar [2025-12-27 21:04:08.891] [info] Initializing connection to external marquee app... [2025-12-27 21:04:08.891] [info] Marquee Socket Client: Connecting to http://localhost:3456... [2025-12-27 21:04:08.927] [error] Marquee Socket Client: Connection error (attempt 1): websocket error [2025-12-27 21:04:11.645] [error] Marquee Socket Client: Connection error (attempt 2): websocket error [2025-12-27 21:04:12.105] [info] Dynamic Wheel Service => Wheel Load Started [ '[]' ] [2025-12-27 21:04:12.107] [info] Dynamic Wheel Service => Loading Wheel Grayscale Setting [ '[]' ] [2025-12-27 21:04:12.108] [info] Dynamic Wheel Service => Loading Opacity Setting [ '[]' ] [2025-12-27 21:04:12.109] [info] Dynamic Wheel Service => Loading Position Setting [ '[]' ] [2025-12-27 21:04:12.111] [info] Dynamic Wheel Service => Loading Wheel Data [ '[]' ] [2025-12-27 21:04:12.112] [info] Dynamic Wheel Service => Sorting Wheel [ '[]' ] [2025-12-27 21:04:12.112] [info] Dynamic Wheel Service => Building Dynamic Wheel [ '[]' ] [2025-12-27 21:04:12.113] [info] Dynamic Wheel Service => Active Wheel Built: [ '[[]]' ] [2025-12-27 21:04:12.116] [info] Dynamic Wheel Service => Rebuilding Dynamic Wheel Items [ '[]' ] [2025-12-27 21:04:12.117] [info] Dynamic Wheel Service => Data Load Completed [ '[]' ] [2025-12-27 21:04:12.118] [info] Hopper Service => Hopper Load Started [ '[]' ] [2025-12-27 21:04:12.118] [info] Hopper Service => Build/Re-Build Hopper Items Started [ '[]' ] [2025-12-27 21:04:12.118] [info] Hopper Service => Build/Re-Build Hopper Items => Old Items Destoyed [ '[]' ] [2025-12-27 21:04:12.119] [info] Hopper Service => Build/Re-Build Hopper Items => The Active Hopper [ '[[]]' ] [2025-12-27 21:04:12.119] [info] Hopper Service => Hopper Data Load Completed [ '[]' ] [2025-12-27 21:04:12.120] [info] Hopper Service => Build/Re-Build Hopper Items Started [ '[]' ] [2025-12-27 21:04:12.120] [info] Hopper Service => Build/Re-Build Hopper Items => Old Items Destoyed [ '[]' ] [2025-12-27 21:04:12.121] [info] Hopper Service => Build/Re-Build Hopper Items => The Active Hopper [ '[[]]' ] [2025-12-27 21:04:16.343] [error] Marquee Socket Client: Connection error (attempt 3): websocket error [2025-12-27 21:04:22.445] [error] Marquee Socket Client: Connection error (attempt 4): websocket error [2025-12-27 21:04:32.450] [error] Marquee Socket Client: Connection error (attempt 5): websocket error [2025-12-27 21:04:32.490] [info] Disconnecting from external marquee app... [2025-12-27 21:04:32.490] [info] Marquee Socket Client: Disconnecting... 1
Hald2k Posted December 27, 2025 Author Posted December 27, 2025 Are these Folders supposed to have media files? all of them only contain one file each. And that is a .txt file named _Place_Override_Media_Here, not just in the Snes folder, Even the Hyperspin Default Theme folder is empty. i am logged in to Emumovies but i am standard member, do i need to be Platinum (or their counterpart) for everything to work? Can i try to manually move a theme inside these folders? Kind Regards John
Hald2k Posted December 27, 2025 Author Posted December 27, 2025 Alright, got it working! tried Supernintendo this time. downloaded an emulator and set a rompath inside. Thanks everyone! Still a bit confused but i will learn. 1
Circo Posted December 28, 2025 Posted December 28, 2025 8 hours ago, Hald2k said: Are these Folders supposed to have media files? all of them only contain one file each. And that is a .txt file named _Place_Override_Media_Here, not just in the Snes folder, Even the Hyperspin Default Theme folder is empty. i am logged in to Emumovies but i am standard member, do i need to be Platinum (or their counterpart) for everything to work? Can i try to manually move a theme inside these folders? Kind Regards John That text file that says put override media here means just that. Any media you put there will replace the default media that comes from EmuMovies. Everything HyperSpin downloads goes into the HSM folder and is not user editable ___________________________________ HyperSpin Website Admin Team Also Visit EmuMovies.com
Hald2k Posted December 28, 2025 Author Posted December 28, 2025 Ok Thank you for everything and fast support. Regards
SamVSsami Posted January 1 Posted January 1 On 12/27/2025 at 9:23 PM, Hald2k said: Are these Folders supposed to have media files? all of them only contain one file each. And that is a .txt file named _Place_Override_Media_Here, not just in the Snes folder, Even the Hyperspin Default Theme folder is empty. i am logged in to Emumovies but i am standard member, do i need to be Platinum (or their counterpart) for everything to work? Can i try to manually move a theme inside these folders? Kind Regards John Hi all, I’m having the same issue — how did you finally resolve it? Do I need to drop ZIP files (like the HS 1.5 ones) into the Main Menu Theme folder, or does it have to be an MP4 or something else? I’m confused about what still works from 1.5 and what doesn’t. I have a bunch of custom system themes for HS 1.5 (ZIP files). Can I simply place them here, or do they need to be converted before they can be used in HS 2.0? Some of them contain SWF files, and I’ve noticed those don’t work in the new HyperTheme. Is there a basic guide that explains all these new folders? Please let me know. I love tweaking things, but with a bit of guidance the process would be a lot less frustrating. Thanks in advance — and great job to everyone working on this! Build your cabinet, conquer the codes, become a King of Chaos!
thatman84 Posted January 2 Posted January 2 18 hours ago, SamVSsami said: Hi all, I’m having the same issue — how did you finally resolve it? Do I need to drop ZIP files (like the HS 1.5 ones) into the Main Menu Theme folder, or does it have to be an MP4 or something else? I’m confused about what still works from 1.5 and what doesn’t. I have a bunch of custom system themes for HS 1.5 (ZIP files). Can I simply place them here, or do they need to be converted before they can be used in HS 2.0? Some of them contain SWF files, and I’ve noticed those don’t work in the new HyperTheme. Is there a basic guide that explains all these new folders? Please let me know. I love tweaking things, but with a bit of guidance the process would be a lot less frustrating. Thanks in advance — and great job to everyone working on this! No themes from 1.5 are compatible with 2.0. All themes for 2.0 need to be configured with the new Hyper theme Platform. Documentation is out now and linked up at the top of the forum "docs" for HyperHQ and Hyper theme and plugins is there 2 Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
rondar Posted January 2 Posted January 2 On 12/27/2025 at 3:40 PM, Hald2k said: why does HQ create 2 clients? I don't know why it does it, but you can safely delete the extra clients. 1 Beer Me! [sIGPIC][/sIGPIC]
fr0stbyt3 Posted January 3 Posted January 3 On 12/27/2025 at 3:40 PM, Hald2k said: why does HQ create 2 clients? This will be fixed in the latest release. 1 1
