haimbilia Posted August 28, 2014 Posted August 28, 2014 Daphne, action max and american laser games are all laserdisc games, i want to have them all under the laserdisc games wheel. can i do it? is it possible to have more then 1 emulator in a wheel?
marxkemp Posted August 29, 2014 Posted August 29, 2014 Yes it is, use an alternative emulator for games in the same xml
Fromlostdays Posted August 29, 2014 Posted August 29, 2014 Step one: Create your xml with all titles included, and put into the database folder for whichever system you want the multiwheel on Step two: Set your rom path(s) if they are in seperate locations Step three: In hyperlaunchHQ set your default emulator to the one that will play the most titles. Step four: In HyperlaunchHQ set up your alternate emulators under that system, and point those emulators to the appropriate games. I'd go into more detail but I'm at work and no setup in front of me. Walter:beerglass:
32assassin Posted August 29, 2014 Posted August 29, 2014 step 3a: chances are that Daphne Global emulator will be your default emulator, make sure you add the rom extensions from Action Max and American Laser Games to your Daphne Global emulator settings. if you don't, hyperlaunch will not find your games when you audit them or play them.
