Agard Posted May 6 Posted May 6 I recently switched to using the nightly builds of Ryubing / Ryujinx & if I now launch it normally it works but if I launch using HyperSpin Classic it says Ryubing / Ryujinx is not supported in Administrative mode anyone else had this as had to go back to older build. I'll try & get a video of what's happening. I haven't changed Ryubing / Ryujinx to run as admin either so it's weird as double checked it's not got run as admin enabled. Any help much appreciated. Thanks
Creezz67 Posted May 6 Posted May 6 6 hours ago, Agard said: I recently switched to using the nightly builds of Ryubing / Ryujinx & if I now launch it normally it works but if I launch using HyperSpin Classic it says Ryubing / Ryujinx is not supported in Administrative mode anyone else had this as had to go back to older build. I'll try & get a video of what's happening. I haven't changed Ryubing / Ryujinx to run as admin either so it's weird as double checked it's not got run as admin enabled. Any help much appreciated. Thanks The reason it does this is because you are running RocketLauncher as admin (which is required for many systems to work correctly). The only way to fix it is to disbable admin in RL or go back to a previous working build of Ryujinx. No idea why this happens, as I literally have 100's of emulators and no others do this.
Agard Posted May 8 Author Posted May 8 Thanks I never thought about RL & yes it's set to run as admin but only UI is so i'll see if it makes a difference & it works. My Ryujinx is set as portable so do you think actually installing it might get around this ? In RL UI is there a separate setting for turning Admin off or is it just in properties in the exe. file ? Once I get things working right I tend to forget how I did things especially quite a while ago, I should make notes but i'm waiting on HS2 being really stable but I just wanted to update things as it's been a while. I'll test later today & see if anything fixes this. Really appreciate the help. Thanks
Creezz67 Posted May 8 Posted May 8 6 hours ago, Agard said: Thanks I never thought about RL & yes it's set to run as admin but only UI is so i'll see if it makes a difference & it works. My Ryujinx is set as portable so do you think actually installing it might get around this ? In RL UI is there a separate setting for turning Admin off or is it just in properties in the exe. file ? Once I get things working right I tend to forget how I did things especially quite a while ago, I should make notes but i'm waiting on HS2 being really stable but I just wanted to update things as it's been a while. I'll test later today & see if anything fixes this. Really appreciate the help. Thanks UI is the important one sadly. Admin is either set on or off. There is no way around it from what I have seen Emulator will work fine as is, just not with Hyperspin/RocketLauncher.
Agard Posted May 11 Author Posted May 11 Once again Thanks as nothing like you said will make it work but I wonder as there nightly builds that's the problem as I don't think we've had a stable release in a while. Really appreciate the reply Thanks
Creezz67 Posted May 12 Posted May 12 8 hours ago, Agard said: Once again Thanks as nothing like you said will make it work but I wonder as there nightly builds that's the problem as I don't think we've had a stable release in a while. Really appreciate the reply Thanks This is the latest version that still works in RL/Hyperspin with admin set (just in case you don't have it) ryujinx-canary-1.3.199-win_x64.zip 1
Agard Posted May 13 Author Posted May 13 Thanks & looks like more than myself has downloaded it also unless you checked download works. A Thanks or a like would be nice if it wasn't you just testing. I have a jailbroken switch but can never figure it else I let ryujinx devs know but surely they know by now. Thanks again really appreciate it 1
Creezz67 Posted May 20 Posted May 20 On 5/13/2026 at 10:52 PM, Agard said: Thanks & looks like more than myself has downloaded it also unless you checked download works. A Thanks or a like would be nice if it wasn't you just testing. I have a jailbroken switch but can never figure it else I let ryujinx devs know but surely they know by now. Thanks again really appreciate it FYI, Vita3k (latest update) is now doing exactly the same thing saying admin rights need to be disabled. This looks like many new emulator updates are going this way. I have now disabled Admin rights on both RL+Hyperspin.exe as 95% of systems will run fine this way. Any that require admin rights can be set via the emulator itself.
Agard Posted May 22 Author Posted May 22 So does this make Ryujinx work disabling Admin rights on both RL+Hyperspin.exe ? If so can you just post the steps on how to do so i'm doing it right as i'm sure I did this but could have done it the completely wrong way. Great work Thanks
Creezz67 Posted May 22 Posted May 22 2 hours ago, Agard said: So does this make Ryujinx work disabling Admin rights on both RL+Hyperspin.exe ? If so can you just post the steps on how to do so i'm doing it right as i'm sure I did this but could have done it the completely wrong way. Great work Thanks Just right click , properties, compatibility and ensure Run this program as administrator is unticked. Do this for Hyperspin.exe and RocketLuncherUI.exe And yes when they are both unticked, latest Ryujinx will then work as before. 1
Agard Posted May 26 Author Posted May 26 Thank you I thought it was that way but was unsure if there was another setting somewhere in RL or HS1
Creezz67 Posted May 27 Posted May 27 17 hours ago, Agard said: Thank you I thought it was that way but was unsure if there was another setting somewhere in RL or HS1 No, that's it.
Agard Posted May 29 Author Posted May 29 I got another problem though I close down like I always do but now it stays on the game over screen & doesn't exit back to HS plus you can hear the game still running. i'll do a capture of what's happening & see if you can diagnose it. I think it might have some to do with module for RL ? Any help always appreciated Thanks
Create an account
Register a new accountSign in
Sign In Now
