Agard Posted May 6 Posted May 6 I recently switched to using the nightly builds of Ryubing / Ryujinx & if I now launch it normally it works but if I launch using HyperSpin Classic it says Ryubing / Ryujinx is not supported in Administrative mode anyone else had this as had to go back to older build. I'll try & get a video of what's happening. I haven't changed Ryubing / Ryujinx to run as admin either so it's weird as double checked it's not got run as admin enabled. Any help much appreciated. Thanks
Creezz67 Posted May 6 Posted May 6 6 hours ago, Agard said: I recently switched to using the nightly builds of Ryubing / Ryujinx & if I now launch it normally it works but if I launch using HyperSpin Classic it says Ryubing / Ryujinx is not supported in Administrative mode anyone else had this as had to go back to older build. I'll try & get a video of what's happening. I haven't changed Ryubing / Ryujinx to run as admin either so it's weird as double checked it's not got run as admin enabled. Any help much appreciated. Thanks The reason it does this is because you are running RocketLauncher as admin (which is required for many systems to work correctly). The only way to fix it is to disbable admin in RL or go back to a previous working build of Ryujinx. No idea why this happens, as I literally have 100's of emulators and no others do this.
Agard Posted May 8 Author Posted May 8 Thanks I never thought about RL & yes it's set to run as admin but only UI is so i'll see if it makes a difference & it works. My Ryujinx is set as portable so do you think actually installing it might get around this ? In RL UI is there a separate setting for turning Admin off or is it just in properties in the exe. file ? Once I get things working right I tend to forget how I did things especially quite a while ago, I should make notes but i'm waiting on HS2 being really stable but I just wanted to update things as it's been a while. I'll test later today & see if anything fixes this. Really appreciate the help. Thanks
Creezz67 Posted Friday at 08:12 AM Posted Friday at 08:12 AM 6 hours ago, Agard said: Thanks I never thought about RL & yes it's set to run as admin but only UI is so i'll see if it makes a difference & it works. My Ryujinx is set as portable so do you think actually installing it might get around this ? In RL UI is there a separate setting for turning Admin off or is it just in properties in the exe. file ? Once I get things working right I tend to forget how I did things especially quite a while ago, I should make notes but i'm waiting on HS2 being really stable but I just wanted to update things as it's been a while. I'll test later today & see if anything fixes this. Really appreciate the help. Thanks UI is the important one sadly. Admin is either set on or off. There is no way around it from what I have seen Emulator will work fine as is, just not with Hyperspin/RocketLauncher.
Agard Posted Monday at 10:29 PM Author Posted Monday at 10:29 PM Once again Thanks as nothing like you said will make it work but I wonder as there nightly builds that's the problem as I don't think we've had a stable release in a while. Really appreciate the reply Thanks
Creezz67 Posted Tuesday at 07:01 AM Posted Tuesday at 07:01 AM 8 hours ago, Agard said: Once again Thanks as nothing like you said will make it work but I wonder as there nightly builds that's the problem as I don't think we've had a stable release in a while. Really appreciate the reply Thanks This is the latest version that still works in RL/Hyperspin with admin set (just in case you don't have it) ryujinx-canary-1.3.199-win_x64.zip 1
Agard Posted 6 hours ago Author Posted 6 hours ago Thanks & looks like more than myself has downloaded it also unless you checked download works. A Thanks or a like would be nice if it wasn't you just testing. I have a jailbroken switch but can never figure it else I let ryujinx devs know but surely they know by now. Thanks again really appreciate it
