I recently switched to using the nightly builds of Ryubing / Ryujinx & if I now launch it normally it works but if I launch using HyperSpin Classic it says Ryubing / Ryujinx is not supported in Administrative mode anyone else had this as had to go back to older build. I'll try & get a video of what's happening. I haven't changed Ryubing / Ryujinx to run as admin either so it's weird as double checked it's not got run as admin enabled.
Any help much appreciated.
The reason it does this is because you are running RocketLauncher as admin (which is required for many systems to work correctly).
The only way to fix it is to disbable admin in RL or go back to a previous working build of Ryujinx.
No idea why this happens, as I literally have 100's of emulators and no others do this.
Thanks I never thought about RL & yes it's set to run as admin but only UI is so i'll see if it makes a difference & it works. My Ryujinx is set as portable so do you think actually installing it might get around this ?  In RL UI is there a separate setting for turning Admin off or is it just in properties in the exe. file ? Once I get things working right I tend to forget how I did things especially quite a while ago, I should make notes but i'm waiting on HS2 being really stable but I just wanted to update things as it's been a while. I'll test later today & see if anything fixes this.
Really appreciate the help. Thanks
UI is the important one sadly. Admin is either set on or off.
There is no way around it from what I have seen 😒
Emulator will work fine as is, just not with Hyperspin/RocketLauncher.
Once again Thanks as nothing like you said will make it work but I wonder as there nightly builds that's the problem as I don't think we've had a stable release in a while.
Really appreciate the reply
This is the latest version that still works in RL/Hyperspin with admin set (just in case you don't have it)
ryujinx-canary-1.3.199-win_x64.zip
Thanks & looks like more than myself has downloaded it also unless you checked download works. A Thanks or a like would be nice if it wasn't you just testing. I have a jailbroken switch but can never figure it else I let ryujinx devs know but surely they know by now.
Thanks again really appreciate it
FYI, Vita3k (latest update) is now doing exactly the same thing saying admin rights need to be disabled.
This looks like many new emulator updates are going this way.
I have now disabled Admin rights on both RL+Hyperspin.exe as 95% of systems will run fine this way.
Any that require admin rights can be set via the emulator itself.
So does this make Ryujinx work disabling Admin rights on both RL+Hyperspin.exe ? If so can you just post the steps on how to do so i'm doing it right as i'm sure I did this but could have done it the completely wrong way.
Great work Thanks
Great work Thanks
Just right click , properties, compatibility and ensure Run this program as administrator is unticked.
Do this for Hyperspin.exe and RocketLuncherUI.exe
And yes when they are both unticked, latest Ryujinx will then work as before.
17 hours ago, Agard said:
Thank you I thought it was that way but was unsure if there was another setting somewhere in RL or HS1
No, that's it.
