thenoob Posted September 2, 2014 Posted September 2, 2014 Hi guys Before I begin, a massive thanks to everyone helping me out while I performed CPR on this old shinobi cab. Here's a new issue. Mame is working good. Now I'm trying to run my emulators, first up Znes. I've ran it in clrmamepro, everything good. Set it up in hyperspin wheel, everything good. Set up in hyperlaunch hq, bad. I can launch the emulator by itself within HQ. I have correct rom paths and emu path setup. I go Games, audit my game list for Znes, all there and green. I launch the games at that point to make sure everything is good, znes launches with the rom (s) to a blank screen. I've tried a ton of the roms in the audit list and none of them launch, and the emulator itself doesn't show up... Just a blank screen, smh. Everything is working as it should until the very end. Any ideas?
thenoob Posted September 2, 2014 Author Posted September 2, 2014 Actually Now at the games tab All games show up during the audit But not the emulator is not launching. It does launch when launched in the emulators tab
thenoob Posted September 2, 2014 Author Posted September 2, 2014 Ok I guess there was another instance of it running in the background. It's now back to how it was. Launches fine under emulator tab, blank screen when launching it under games audit tab. In hyperspin when running, it does the same thing. All the roms show up in the wheel, select a game, screen goes black and doesn't proceed to fully launch
thenoob Posted September 2, 2014 Author Posted September 2, 2014 I'll have to go back to ground zero. I used the dat file from dat o matic, scanned fine. Now, even tho I can see all the roms within znes, I can't load a rom at all.... Even outside of hyperspin, I wonder if clrmame messed it up
gigapig Posted September 2, 2014 Posted September 2, 2014 Its recommended that you back up your Roms before using CLRMamepro. Make sure you get the games running in the emulator first, turn off bezels and fade and then post your logs and make sure they are set to the correct level.
Fromlostdays Posted September 2, 2014 Posted September 2, 2014 I'm just... a snob, I guess. But everything is better than zsnes. So many excellent emulators. Snes9x for awesome composite imaging, Higan for accuracy, Retroarch with the bsnes (Accuracy or balanced) for much shaders. Mednafen, which is pretty much flawless after setup. But yeah, sounds like an odd problem. Post your troubleshooting log. Walter:beerglass:
