Screen Tearing in HyperSpin
newoski
Hi Guys,
I'm running into screen tearing in HyperSpin themes.
I'm running an i5-4670K and a GTX660 GPU. I have the latest drivers for everything and I have the latest version of Flash installed.
Monitor is 1280x1024 and I've tried 1280x1024 and 800x600 for my HS resolution.
Any recommended solutions?
Owen
Is your system equipped with dual Intel graphics along with the GTX660?
Some systems have integrated Intel graphics along with discrete graphics installed. General Windows functionality uses the lower power Intel graphics and graphics intensive applications will use the discrete higher power graphics card. If this is your system, you can right click the app and instruct Windows to run HyperSpin to use the discreet graphics rather than the Intel graphics. There are some known issues Intel graphics. But just wanted to get an idea of what your hardware is.
Your issue could be anything. The themes are Flash based. Go into HyperHQ and adjust the processing priority settings. Possibly disable some of the artwork levels until you find the problem. Update your drivers. Download a codec pack.
albert,
Not sure we're on the same page here. Unless I'm missing something, codecs wouldn't help as it is flash, not conventional video. I have the latest version of flash and java (not sure if that's necessary). Additionally, I don't think discrete vs integrated matters, because I have the GTX660, right?
I am on the latest drivers.
Seen this before, but with Flash video/movies. Was a Flash/Nvidia driver issue. Nickelberry is right. You'll need to enable Vsync. Forgot how I fixed it but found a thread here about it:
https://code.google.com/p/chromium/issues/detail?id=160454
See if that helps.
Hi, same issue with my notebook. I have 2 GPU on is for high end other for Dektop use. Right click on Hyperspin.exe and run it with high Power Graphic prozessor. That fixed the problem for me.
  • 4 weeks later...
OK, so after more troubleshooting than I'll ever care to admit... I finally solved this.
Simply switch to Windows Aero.
Fixed it immediately, without needing to change anything else.
Hope this helps someone in the future
