Best way to have games from multiple systems on one wheel.
albert_c
Hoping to build a 'Best Games' wheel regardless of system/emulator that it plays on. Is irondragoon's method still the defacto best way to accomplish this?
that is what you would do for Hyperlaunch 2
its much easier with Hyeprlaunch 3
1. Create an XML with the games you would like to add.
you do not add any of the <exe>Arbitrary System A (B)</exe"
Open HyperHQ
2. add your custom system (name does not matter)
Open HyperlaunchHQ
3. select your custom system
-select emulators tab
- add your rom paths
- you do not need to select any Default emulator
4. the most important part
-Select Games Tab
-In the Games Tab select "Alternate Emulators"
hit the green cross
when the Add Alternate Game Emulator window opens
-click on the magnifying glass for:
Game: select a game from your list
System: LEAVE BLANK
Emulator: from your Global emulators list select the appropriate emulator for the game you have selected.
repeat process for each game on your list.
Going to be a quite a task due to the list length. Damnit, we need HS 2.0 :). Kidding. Thanks 32assassin!
  • 6 months later...
@32assassin .. What if the list contains some of the PC games.. For rom path should I add the folder which contains the exe file ? ... I am getting error "No Default emulator found" .. Can you pls help.. Thanks
Open HyperHQ
Open HyperlaunchHQ
-Select Games Tab
hit the green cross
System: LEAVE BLANK
Just wondering if the artwork needs to be moved into the new custom folder for the system?
I'm assuming it does....but i might try symlinks.
Wanting to merge:
AAE,
MAME,
Sega Model 2,
Zinc.
