Sharp X68000 Script - Update
darkbelmonte
here's an update I did the script for Sharp X68000, to fix some bugs and makes it more functional and able to play in decent games for this computer.
I encouraged this mess that the script for this manson976 collecting the artwork of the system and is getting a very good job.
His work is here!
Changes / Features
- Runs the floppy
- Run the HD's (Hard Disk Image)
- Exchange floppy disks
- Expands memory of the machine to prevent further exchanges of floppy disks and be compatible with all games
- Works with 2 emulators (note the efforts are concentrated in "WinX68kHighSpeed_eng"!)
- Must save the GUI
- Works in 1024x768 and 1280x1024 resolutions (better)
For those who do not know very well this system follows some important information.
- And a computer with two floppy drives (disk1 and disk2)
at the bottom of the computer screen will be displayed which disks can be inserted and that the program requires you to insert a new disk.
- Another method is we play games stored on the hard drive and just put them in this case and will never need to replace any floppies.
Below is a sample video in which they are played
Video - Upload is being done! Wait
Floppy:
Akumajō Dracula (1993) (Konami) (Disk 1 of 2). Dim
How are two disks in the script puts them Disk1 and Disk2 and worked perfectly without the need for exchange (in the fianal cideo triggers the Bill just to make the save and load the advance in the game)
Floppy:
Street Fighter II Champion Edition (1993) (SPS) (Disk 1 of 4) (System). Dim
The game is 4 disks, then the script does so he sets up your machine with 2 MB of RAM to prevent you from having to keep changing the floppy after the fights, so you Garreg all at the beginning of the game as the video and then mopstra can play without problems. (If you omit the script from the memory ally Sharp X68000 he will start the game and there depending on the character you're facing you'll be asking different disks and that's very alternate).
Super Street Fighter II (1993) (Capcom) [hdf]. Hdf
Sample game in HD and 1 to be displayed on the video and it's behavior and the same script when run only one game with two diaquetes. (In the video it takes to get a pouvo, but that's normal and Sharp PC X680000)
With three games above you can have an overview of the features of the script, but the script runs with up to 9 games floppy if you need.
NOTE:. On the video screen of the emulator is in a lower resolution, and because of this resolution settings that was recording and cantasia emulator was configured, when executives realized that there is no problem for video
; Sharp X68000
; WinX68kHighSpeed
; by Darkbelmonte
; 4.7
; This script was created from the discuções fosum arcadebr
; http://www.arcadebr.com/threads/2284-Hyperlaunch-scripting-duvidas-dicas/page3
; Works with emulators "WinX68kHighSpeed??" and "XM6"
; If you use the HD using "XM6" if not please use the "WinX68kHighSpeed??" because it works best with Gui
; The merit of the process to use the emulator "XM6" and all of the MEMBERS airhead, just made a free adaptation
; Which is still far from having all the features that he developed in his (As the use of HD)
; - Runs the floppy
; - Run the HD's (Hard Disk Image)
; - Exchange floppy disks
; - Expands memory of the machine to prevent further exchanges of floppy disks and be compatible with all games
; - Works with 2 emulators (note the efforts are concentrated in "WinX68kHighSpeed_eng"!)
; INITIAL PART OF THE SCRIPT - DEFINING KEY EMULATOR AND OPERATIONS										 ;
Gosub, NOMEROMPROCESSO																					 ;
Gosub, ATALHOS        ;
Gosub, ATALHOS2        ;
if(executable = "WinX68kHighSpeed_eng.exe"){															 ;
Goto, PREWINX68HS																						 ;
}else if(executable = "XM6.exe"){																		 ;
Goto, PREXM6																							 ;
ExitApp																									 ;
CloseProcess:																							 ;
 Process, Close, %executable%        ;
 WinClose, ahk_class WinX68kHighSpeed																	 ;
 Process, Close, HyperLaunch.exe 																		 ;
 Process, Close, AutoHotkey.exe 																		 ;
 Gui, destroy																							 ;
return																									 ;
; EXECUTION Emulators
; 1) PRIMARY PART OF THE IMPLEMENTATION OF EMULATOR
; Run emulators "WinX68kHighSpeed??" and "XM6"
PREWINX68HS:
Gui +AlwaysOnTop -Caption +ToolWindow
Gui, Color, Black
Gui Show, x0 y0 h%A_ScreenHeight% w%A_ScreenWidth%
; WinX68kHighSpeed ??*** Using the Emulator
; Dedication of some facilitators
SetWorkingDir, %emuPath%
IniWrite, %romPath%, %emuPath%\winx68k.ini, WinX68k, StartDir
IniWrite, true, %emuPath%\winx68k.ini, WinX68k, FDDStatWin
IniWrite, true, %emuPath%\winx68k.ini, WinX68k, FDDStatFullScr
IniWrite, 10, %emuPath%\winx68k.ini, WinX68k, MpuClock
IniWrite, 1, %emuPath%\winx68k.ini, WinX68k, WinStretch
IniWrite, false, %emuPath%\winx68k.ini, WinX68k, JoySwap
; Define what type of device emulator will work WinX68kHighSpeed
if(romExtension = ".hdf"){
IniWrite, %romPath%%romName%%romExtension%, %A_WorkingDir%\winx68k.ini, WinX68k, HDD0
IniWrite, %A_Space%, %A_WorkingDir%\winx68k.ini, WinX68k, FDD0Image
IniWrite, %A_Space%, %A_WorkingDir%\winx68k.ini, WinX68k, FDD1Image
Goto, execusimples
; 2 floppy disks if he starts the game and ready (in a floppy drive in drive 0 and another one)
   if(romExtension = ".xdf" || ".dim" || ".hdm"){
IniWrite, %romPath%%romName%%romExtension%, %A_WorkingDir%\winx68k.ini, WinX68k, FDD0Image
Loop, %romPath%%nomeraiz%%formato%%A_Space%2*%romExtension%, , 1       ; Browse to C: \ ROM \ Alshark (1991) (Right Stuff) (Disk dim *.
IniWrite, %A_LoopFileFullPath%, %A_WorkingDir%\winx68k.ini, WinX68k, FDD1Image
goto, execusimples
PREXM6:
Gui, Color, Black
; XM6 *** Using the Emulator
IniWrite, 5, %emuPath%\XM6.ini, Basic, Memory                                                            ; Trabalha com o maximo de RAM possivel 12 MB
IniWrite, %romPath%, %emuPath%\XM6.ini, Resume, Path                                                     ; Insere o caminho default do diretório
IniWrite, 1, %emuPath%\XM6.ini, Resume, FD                                                               ; Faz o emulador inicializar com o disquete nos Drives
IniWrite, 1, %emuPath%\XM6.ini, Joystick, Button11                                                       ; Congura o soco medio Street EX:.
IniWrite, 2, %emuPath%\XM6.ini, Joystick, Button12                                                       ; Congura o Chute medio Street  EX:.
IniWrite, %romPath%%romName%%romExtension%, %A_WorkingDir%\XM6.ini, SASI, File0
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, MRU0, File0
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, MRU1, File0
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, SASI, File1
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, SASI, File2
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, SASI, File3
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, SASI, File4
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, SASI, File5
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, SASI, File6
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, SASI, File7
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, SASI, File8
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, SASI, File9
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, SASI, File10
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, SASI, File11
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, SASI, File12
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, SASI, File13
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, SASI, File14
IniWrite, %A_Space%, %A_WorkingDir%\XM6.ini, SASI, File15
Goto, execusimples
      IniWrite, %romPath%%romName%%romExtension%, %A_WorkingDir%\XM6.ini, MRU0, File0
	  IniWrite, %A_LoopFileFullPath%, %A_WorkingDir%\XM6.ini, MRU1, File0
	  goto, execusimples
;RUN MODE SIMPLE EMULATOR - LAUNCHES EMULATOR
execusimples:
  Run, %EmuPath%%Executable%, , UseErrorLevel
     WinWait, ahk_class WinX68kHighSpeed,
     WinWaitActive, ahk_class WinX68kHighSpeed,
     Sleep, 50
  yOffset = -20
     winHeight := A_ScreenHeight - yOffset
     WinMove, ahk_class WinX68kHighSpeed,, 0, %yOffset%, %A_ScreenWidth%, %winHeight%
  Sleep, 200
  DetectHiddenWindows, on
  IfWinNotActive, ahk_class WinX68kHighSpeed, ,
  WinActivate, ahk_class WinX68kHighSpeed,
  Sleep, 100
  Send, {F11}
  Sleep, 100
     Send, o
  Sleep, 50
     Send, {UP}
  Sleep, 50
     Send, {UP}
  Sleep, 50
     Send, {ENTER}
  WinWait, The amount of MainMemory, Cancel
  IfWinNotActive, The amount of MainMemory, Cancel, WinActivate, The amount of MainMemory, Cancel
  WinWaitActive, The amount of MainMemory, Cancel
  Send, {DEL}{DEL}{DEL}{DEL}10{ENTER}
  Sleep, 100
  Send, {F11}
  Sleep, 100
  Send, {DOWN}
  Sleep, 100
  Send, {ENTER}
  Send, {F11}
  Send, d
  Send, {ENTER}
  Sleep, 200        ; avoid some errors
  Send, {SPACE}
  Sleep, 150
  WinShow, ahk_class WinX68kHighSpeed
  Process, WaitClose, %executable%
  Sleep, 500
  WinSet, AlwaysOnTop, On, ahk_pid %Errorlevel%
  WinSet, Top,, ahk_pid %Errorlevel%
  WinActivate, ahk_pid %Errorlevel%
  WinWaitActive, ahk_pid %Errorlevel%
return
   Process, Exist, %executable%
   if !ErrorLevel = 0
WinWait, ahk_class AfxFrameOrView70,
IfWinNotActive, ahk_class AfxFrameOrView70, ,
WinActivate, ahk_class AfxFrameOrView70,
Sleep, 100
Send, {ALTDOWN}{ENTER}{ALTUP}
Sleep, 700
MouseClick, left,  0,  0
Sleep, 100
WinShow, ahk_class AfxFrameOrView70
return
; 2) DEFINITION OF THE KEYBOARD SHORTCUTS
; I used the keys q and w
; Also in the SELECT and START Joystick
ATALHOS:
JoystickNumber = 1
JoystickPrefix = %JoystickNumber%Joy
;  Support Swap Joy by L1 and L2 (E and R on the keyboard)
Hotkey, e, FDD0IMAGE
Hotkey, r, FDD1IMAGE
Joy5::Send, e
Joy7::Send, r
Joy10::Send, {ENTER}
;	Joy3::Send, z ; to play Street Fighter with 6 buttons
;	Joy6::Send, c
;	Joy4::Send, a
;	Joy8::Send, d
  return
ATALHOS2:
#Persistent  ; Keep this script running until the user explicitly exits it.
SetTimer, WatchPOV, 5
return
WatchPOV:
GetKeyState, POV, JoyPOV  ; Get position of the POV control.
KeyToHoldDownPrev = %KeyToHoldDown%  ; Prev now holds the key that was down before (if any).
; Some joysticks might have a smooth/continous POV rather than one in fixed increments.
; To support them all, use a range:
if POV < 0   ; No angle to report
   KeyToHoldDown =
else if POV > 31500                 ; 315 to 360 degrees: Forward
   KeyToHoldDown = Up
else if POV between 0 and 4500      ; 0 to 45 degrees: Forward
   KeyToHoldDown = Up
else if POV between 4501 and 13500  ; 45 to 135 degrees: Right
   KeyToHoldDown = Right
else if POV between 13501 and 22500 ; 135 to 225 degrees: Down
   KeyToHoldDown = Down
else                                ; 225 to 315 degrees: Left
   KeyToHoldDown = Left
if KeyToHoldDown = %KeyToHoldDownPrev%  ; The correct key is already down (or no key is needed).
   return  ; Do nothing.
; Otherwise, release the previous key and press down the new key:
SetKeyDelay -1  ; Avoid delays between keystrokes.
if KeyToHoldDownPrev   ; There is a previous key to release.
   Send, {%KeyToHoldDownPrev% up}  ; Release it.
if KeyToHoldDown   ; There is a key to press down.
   Send, {%KeyToHoldDown% down}  ; Press it down.
return
; 3 ) DEFINITION OF THE NAME GAME
NOMEROMPROCESSO:
; 	    WORKING WITH THE NAME OF ROMS
; 1º stage
	; Dedicate some facilitators eg. NAME = Alshark (1991) (Right Stuff) (Disk 1 of 5) (System). Dim
	nome = %romName%%romExtension%
; 2º stage
	; A ) Setting the default naming standard ideal can be found in
	; http://www.emuparadise.org/Sharp_X68000_ROMs/Games-Starting-With-C/23
	IfInString, nome,(Disk%A_Space%
	formato =(Disk%A_Space%
	IfInString, nome,[Disk%A_Space%
	formato =[Disk%A_Space%
	; B ) Calculation of the names for division
	StringGetPos, totaldeletrasnome, nome, %romExtension%
	StringGetPos, contar, nome, %formato%
	letras := totaldeletrasnome - contar
	contarfim := totaldeletrasnome - contar -3
	; StringMid This time I used to divide the name of Rom (Disk 1 of?) If [Disk 1] using only %count% and not count +1
	; C) Determines the Short Name EX:. (Disk 1 of 5) (System) *** This is the name that manipulate ***
	StringMid, nomecurto, nome, contar+1, %letras%
	; StringLeft This time I used to divide the name of Rom and get the principal name
	; D) Determining the Name of the Game EX:. of "Alshark (1991) (Right Stuff) (Disk 1 of 5) (System)" The nomeraiz = "Alshark (1991) (Right Stuff)"
	StringLeft, nomeraiz, nome, contar
	; E) He had taken only after the name of our variable floppy EX:. of "Alshark (1991) (Right Stuff) (Disk 1 of 5) (System)" The nomefinal = "of 5) (System)"
	StringRight, nomefinal, nome, %contarfim%
	; The StringGetPos nomeraiz divides the year to catch the Game
	; F) will take the year continued in the name of the ROM output format will be 19??
	StringGetPos, ano, nomeraiz, (19
	StringMid, year, nomeraiz, ano+2, 4
	; G) found the producer of the game and the output format is (producer) EX:. (Right Stuff)
	StringMid, produtoraB, nomeraiz, ano+8,
	StringGetPos, produtoraC, produtoraB, )
	StringLeft, produtoraD, produtoraB, %produtoraC%
	StringMid, produtora, nomeraiz, ano+7,
	; The StringGetPos divides nomefinal to get the type of floppy disk that will use
	; H) The output format is (name of disk) EX:. (System)
	StringGetPos, Tnomefinal , nomefinal, %romExtension%
	StringMid, TDISKETTE, nomefinal, 9, Tnomefinal-9
	; I ) Only the name of the game and nothing else EX:. "Alshark" *** is the name after the space
	StringLeft,sonomedojogo, nomeraiz, %ano%
; 3º stage
	; determines how the game has floppy
	FileList = 														 ; White boots in the FileList
	Loop, %romPath%%nomeraiz%%formato%%A_Space%*%romExtension%       ; Browse to C: \ ROM \ Alshark (1991) (Right Stuff) (Disk dim *.
		FileList = %FileList%%A_LoopFileName%`n                      ;
	Loop, parse, FileList, `n
		if A_LoopField =  ; Ignore the blank item at the end of the list.
			continue
		quantidade = %A_Index%
; END OF WORK WITH THE NAME OF ROMS
return
; 4 ) KEYBOARD SHORTCUTS FOR THE CHOICE OF DIQUETES
; Construct the GUI for FDD0 or FDD1
FDD0IMAGE:
 FDD = 0
 Gui, 2: destroy
 Gui, 3: destroy
 Gosub, TELADESWAP
 ; Trick that ensures that the screen is on 1 plan
 Sleep, 100
 MouseClick, left,  %A_ScreenWidth%, 0
return
FDD1IMAGE:
FDD = 1
Gui, 2: destroy
Gui, 3: destroy
 Gosub, TELADESWAP
 Sleep, 100
return
TELADESWAP:
; 5 ) Part of the script that builds the GUI
; The GUI will be built with the corresponding number of disks
;TELADESWAP:
; Prevents the GUI is made ??in the resolution of the emulator
Gui, 1:Destroy
Gui, 2:Destroy
Gui, 2:  color, %colorB%
Gui, 2: Show, x0 y0 h%A_ScreenHeight% w%A_ScreenWidth%
Sleep, 50
Gui, 2: destroy
; Pause Game - Use the F11 key to stop playing the game
;	WinWait, ahk_class WinX68kHighSpeed,
;	WinWaitActive, ahk_class WinX68kHighSpeed,
;	Send, {F11}
; CODE - Determines the position of buttons in the GUI
; Settings Axis "X"
; Eixo "X" |buttons
XPosD := A_ScreenWidth/2 - A_ScreenWidth/10 - 5
XPosM := A_ScreenWidth/2
XPosE := A_ScreenWidth/2 + A_ScreenWidth/10 + 5
; Eixo "X" |Text
XPosA := A_ScreenWidth/24
XPosB := A_ScreenWidth/18
XPosC := XPosE + XPosE/6
; Settings Axis "Y"
; Eixo "Y" |buttons
YPosm := A_ScreenHeight/2 - 80
YPos1 := A_ScreenHeight/2 + 65 - 80
YPos2 := A_ScreenHeight/2 + 130 - 80
YPosi1 := A_ScreenHeight/2 + 75
YPosi2 := A_ScreenHeight/2 + 119
YPosi3 := A_ScreenHeight/2 + 162
YPosi4 := A_ScreenHeight/24 *20
YPosi5 := A_ScreenHeight/24 *21 + 5
YPosi6 := A_ScreenHeight/24 *22 + 10
; Eixo "Y" |Text
YPosA := A_ScreenHeight/30
YPosB := A_ScreenHeight/12
YPosC := YPos2 + YPos2/6 + 20
YPosD := YPos2 + YPos2/6 + 46
YPosE := YPos2 + YPos2/6 + 65
YPosF := YPos2 + YPos2/6 + 105
YPosG := A_ScreenHeight/10 + 20
; Eixo "Y" | position do checkbox
1check := YPosA*24
2check := YPosA*25
3check := YPosA*26
4check := YPosA*27
checkA := A_ScreenWidth/10,1
checkB := A_ScreenWidth/3,80
checkC := A_ScreenWidth/2
altnome1 := 1check - 130
altnome2 := 1check - 90
altnome3 := 1check - 50
; 1° GUI
; Colors
if(FDD = 0){
 colorB = 000000
 colorF = Cfffffffff
}else if(FDD = 1){
 colorB = Cfffffffff
 colorF = 000000
; Launching the GUI - do not generate error images
Gui, 1:color, %colorB%
; Sets the font of the buttons
Gui, Font, S13 CDefault, Verdana
; Only a Floppy
if(quantidade =2){
Gui, Add, Button, x%XPosD% y%YPosm% w130 h75 , DISKETTE1_A
Gui, Add, Button, x%XPosE% y%YPosm% w130 h75 , DISKETTE2_B
 if(quantidade =3){
Gui, Add, Button, x%XPosM% y%YPosm% w130 h75 , DISKETTE2_B
Gui, Add, Button, x%XPosE% y%YPosm% w130 h75 , DISKETTE3_C
 if(quantidade =4){
Gui, Add, Button, x%XPosD% y%YPosm% w130 h64 , DISKETTE1_A
Gui, Add, Button, x%XPosE% y%YPosm% w130 h64 , DISKETTE2_B
Gui, Add, Button, x%XPosD% y%YPos1% w130 h64 , DISKETTE3_C
Gui, Add, Button, x%XPosE% y%YPos1% w130 h64 , DISKETTE4_D
 if(quantidade =5){
Gui, Add, Button, x%XPosM% y%YPos1% w130 h75 , DISKETTE3_C
Gui, Add, Button, x%XPosD% y%YPos2% w130 h75 , DISKETTE4_D
Gui, Add, Button, x%XPosE% y%YPos2% w130 h75 , DISKETTE5_E
 if(quantidade =6){
Gui, Add, Button, x%XPosD% y%YPos1% w130 h75 , DISKETTE4_D
Gui, Add, Button, x%XPosM% y%YPos1% w130 h75 , DISKETTE5_E
Gui, Add, Button, x%XPosE% y%YPos1% w130 h75 , DISKETTE6_F
  if(quantidade =7){
Gui, Add, Button, x%XPosM% y%YPos2% w130 h75 , DISKETTE7_G
   if(quantidade =8){
Gui, Add, Button, x%XPosD% y%YPos2% w130 h75 , DISKETTE7_G
Gui, Add, Button, x%XPosE% y%YPos2% w130 h75 , DISKETTE8_H
	if(quantidade =9){
; 1º row
Gui, Add, Button, x%XPosD% y%YPosm% w100 h60  , DISKETTE1_A
Gui, Add, Button, x%XPosM% y%YPosm% w100 h60  , DISKETTE2_B
Gui, Add, Button, x%XPosE% y%YPosm% w100 h60  , DISKETTE3_C
; 2º row
Gui, Add, Button, x%XPosD% y%YPos1% w100 h60  , DISKETTE4_D
Gui, Add, Button, x%XPosM% y%YPos1% w100 h60  , DISKETTE5_E
Gui, Add, Button, x%XPosE% y%YPos1% w100 h60  , DISKETTE6_F
; 3º row
Gui, Add, Button, x%XPosD% y%YPos2% w100 h60  , DISKETTE7_G
Gui, Add, Button, x%XPosM% y%YPos2% w100 h60  , DISKETTE8_H
Gui, Add, Button, x%XPosE% y%YPos2% w100 h60  , DISKETTE9_I
; Launching the GUI
Gui, -Caption
Gui, Show, x0 y0 h%A_ScreenHeight% w%A_ScreenWidth%
; adding Cover e Wheel
Gui, 1:  Show, x0 y0 h%A_ScreenHeight% w%A_ScreenWidth%
Gui, 1:Add, Picture,x%XPosB% y%YPosG%, %A_ScriptDir%\Media\%systemName%\Images\Artwork3\%romName%.png
Gui, 1:Add, Picture,x%XPosD% y%YPosB%, %A_ScriptDir%\Media\%systemName%\Images\Wheel\%romName%.png
; 2° GUI
; adding buttons
; Gui Show, x0 y0 h%A_ScreenHeight% w%A_ScreenWidth%
; LAUNCHED PART BUTTONS AND WRITTEN
; adding Text
; 1º Question Title
Gui, 1: Font, S26 %colorF% Bold, Verdana
Gui, 1: -Caption +ToolWindow %AlwaysOnTop%
   ;Gui +AlwaysOnTop -Caption +ToolWindow
Gui, 1: Add, Text, x%XPosA% y%YPosA% w970 h50 BackgroundTrans, Choose a disk for te Device FDD %FDD%
; WinSet, TransColor, %Background_Color% 200
; 3º ROM INFORMATION
Gui, 1: Font, S12 %colorF% Bold, Verdana
Gui, 1: Add, Text, x%XPosB% y%altnome1% w300 h40 , GAME : %sonomedojogo% `nDATE : %year%
Gui, 1: Add, Text, x%XPosB% y%altnome2% w300 h40 , SOFT HOUSE : %produtoraD%`nNUMBER OF DISKS : %quantidade%
Gui, 1: Add, Text, x%XPosB% y%altnome3% w300 h40 , Drive Disk %FDD%`ninitial %TDISKETTE%
Gui, 1: Font, S7 %colorF% Bold, Verdana
Gui, 1: Add, Button, x%XPosB% y%1check% w45 h20 , x68030
Gui, 1: Add, Button, x%XPosB% y%2check% w45 h20 , 10MB
Gui, 1: Add, Button, x%XPosB% y%3check% w45 h20 , Reset
Gui, 1: Add, Text, x%checkA% y%1check% w200 h25 , 43 Mhz mode (WinX68k)
Gui, 1: Add, Text, x%checkA% y%2check% w200 h25 , Increase memory to 10 MB (WinX68k)
Gui, 1: Add, Text, x%checkA% y%3check% w200 h25 , Reset Game
;Gui, 1: -Caption +ToolWindow %AlwaysOnTop%
Gui, 1: Add, Button, x%checkB% y%1check%  w45 h20 , Save
Gui, 1: Add, Button, x%checkB% y%2check%  w45 h20 , Load
Gui, 1: Add, Button, x%checkB% y%3check%  w45 h20 , Return
Gui, 1: Add, Text, x%XPosD% y%1check% w200 h25 , Save : Save the Current Position of the game
Gui, 1: Add, Text, x%XPosD% y%2check% w200 h25 , Load : Return to a position Saved
Gui, 1: Add, Text, x%XPosD% y%3check% w200 h25 , Return : Return to Game
return
GuiClose:
GuiEscape:
1GuiClose:
1GuiEscape:
2GuiClose:
2GuiEscape:
ExitApp
; ? ) DEFINE WHAT WILL MAKE EACH
; Each button corresponds to a specific number of disks
ButtonDISKETTE1_A:
DISQUETE =1
Goto, TROCA
ButtonDISKETTE2_B:
DISQUETE =2
Goto, TROCA
ButtonDISKETTE3_C:
DISQUETE =3
Goto, TROCA
ButtonDISKETTE4_D:
DISQUETE =4
Goto, TROCA
ButtonDISKETTE5_E:
DISQUETE =5
Goto, TROCA
ButtonDISKETTE6_F:
DISQUETE =6
Goto, TROCA
ButtonDISKETTE7_G:
DISQUETE =7
Goto, TROCA
ButtonDISKETTE8_H:
DISQUETE =8
Goto, TROCA
ButtonDISKETTE9_I:
DISQUETE =9
Goto, TROCA
; ? ) EXECUTE THE PROCESS OF CHANGE FLOPPY
; This configuirado to work in 2 emulators
TROCA:
Sleep, 100
Send, {F11}
Send, %FDD%
WinWait, Select X68k disk image,
Sleep, 100
clipboard=
Sleep, 100
Loop, %romPath%%nomeraiz%%formato%%A_Space%%DISQUETE%*%romExtension%, , 1
clipboard= %A_LoopFileName%
Sleep, 100
Send, {CTRL DOWN}
Sleep, 50
Send, v
Sleep, 100
Send, {CTRL UP}
Sleep, 150
Send, {ENTER}
Sleep, 150
Sleep, 150
Sleep, 200
Gui, destroy
return
else if (executable = "XM6.exe"){
  MouseClick, right, 0, 0
  Send, %FDD%
  Send, {Enter}
  WinWait, ahk_class #32770,
	clipboard=
	Sleep, 100
	Sleep, 100
	Send, {CTRL DOWN}
	Sleep, 50
	Send, v
	Sleep, 100
	Send, {CTRL UP}
	Sleep, 150
	Send, {ENTER}
	Sleep 1000
	Gui, destroy
return
; ? ) Button Return
; Simply close the GUI and back of the screen emulators
ButtonReturn:
	Sleep, 100
	Sleep, 200
	Gui, destroy
	return
  Sleep, 100
  Sleep, 200
  Gui, destroy
return
; ? ) SAVE - SAVE THE GAME IN THE CURRENT POCIÇÃO
; The script will save the game with your 1st name
ButtonSave:
Sleep, 100
Send, {F11}
Sleep, 100
Send, s
Sleep, 100
Send, s
WinWait, Save State,
Sleep, 100
clipboard=
Sleep, 100
clipboard=%sonomedojogo%.x68
Sleep, 100
Send, {CTRL DOWN}
Sleep, 100
Send, v
Sleep, 100
Send, {CTRL UP}
Sleep, 100
Send, {ENTER}
Sleep, 150
Sleep, 150
Gui, destroy
return
  Send, {F10}
  WinWait, XM6 [Running],
  IfWinNotActive, XM6 [Running], , WinActivate, XM6 [Running],
  WinWaitActive, XM6 [Running],
	Send, {DOWN}
	Sleep, 100
	Send, {DOWN}
	Sleep, 100
	Send, {DOWN}
	Sleep, 100
	Send, {ENTER}
	Sleep, 100
	WinWait, Save As,
	Sleep, 100
	clipboard=
	Sleep, 100
	clipboard=%sonomedojogo%.XM6
	Sleep, 100
	Send, {CTRL DOWN}
	Sleep, 100
	Send, v
	Sleep, 100
	Send, {CTRL UP}
	Sleep, 100
	Send, {ENTER}
	Sleep, 150
	Sleep, 150
	Gui, destroy
	return
; ? ) LOAD - SAVE BEARS TO PERSON 1 NAME OF THE GAME
; The script will look for the pattern of this script and save Carregal
ButtonLoad:
Sleep, 100
Send, {F11}
Sleep, 100
Send, s
Sleep, 100
Send, l
WinWait, Load State,
Sleep, 100
clipboard=
Sleep, 100
Sleep, 100
Send, {CTRL DOWN}
Sleep, 100
Send, v
Sleep, 100
Send, {CTRL UP}
Sleep, 100
Send, {ENTER}
Sleep, 150
Sleep, 150
Gui, destroy
return
  Send, {F10}
	Send, {DOWN}
	Sleep, 100
	Send, {ENTER}
	Sleep, 100
	WinWait, Open,
	Sleep, 100
	clipboard=
	Sleep, 100
	Sleep, 100
	Send, {CTRL DOWN}
	Sleep, 100
	Send, v
	Sleep, 100
	Send, {CTRL UP}
	Sleep, 100
	Send, {ENTER}
	Sleep, 150
	Sleep, 150
	Gui, destroy
	return
; ? ) RESET - RESET Emulators
; Reset the emulator
ButtonReset:
Sleep, 100
Send, {F11}
Sleep, 100
Send, {DOWN}
Sleep, 100
Send, {ENTER}
Sleep, 150
Gui, destroy
return
  Send, {F10}
	Send, {DOWN}
	Sleep, 100
	Send, {DOWN}
	Sleep, 100
	Send, {DOWN}
	Sleep, 100
	Send, {DOWN}
	Sleep, 100
	Send, {ENTER}
	Sleep, 100
	Sleep, 150
	Gui, destroy
	return
; BUTTON 43 mhz - x68030
Buttonx68030:
Sleep, 100
Send, {F11}
Sleep, 100
   Send, o
Sleep, 50
   Send, {DOWN}
Sleep, 50
   Send, {DOWN}
Sleep, 50
   Send, {DOWN}
Sleep, 50
   Send, {DOWN}
Sleep, 50
   Send, {DOWN}
Sleep, 50
   Send, {DOWN}
Sleep, 50
   Send, {DOWN}
Sleep, 50
   Send, {ENTER}
Sleep, 150
Gui, destroy
return
MsgBox,  only implemented for WinX68kHighSpeed`nsupport in the native script XM6.
Sleep, 400
; BUTTON UP MEMORY 10MB
Button10MB:
Sleep, 100
Send, {F11}
Sleep, 100
   Send, o
Sleep, 50
   Send, {UP}
Sleep, 50
   Send, {UP}
Sleep, 50
   Send, {ENTER}
Sleep, 100
Send, {F11}
Sleep, 100
Send, {DOWN}
Sleep, 100
Send, {ENTER}
Sleep, 150
Gui, destroy
return
Sleep, 400
The script may be more mature than it already, but for this you need the feerback if wants a voice will be welcomed.
Please translate the notes into english in the module, this is an english speaking forum.
There is sooooo much redundant code in that script btw. It does not need to be that big.
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
djvj,
Excuse my lack of attention, but it updated the information from the script into English.
For the script I found the Sharp X68000 solutions present in this script and I know that in many cases can be simplified, but I appreciate the feedback and obsevações who wish to do.
Thanks darkbelmonte, now if someone wants to help you, they can understand and read through the script better.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
FYI, the official DB naming for multi disc games needs to be
Game Name (Disc1),
Game Name (Part2),
Game Name (Tape3)
etc...
No spacing between number and type. Hope this doesnt affect any of your scripts.
  • 9 months later...
  • 2 years later...
Is this script for an old version of Hyperlaunch?
I have added it but the emu doesn't appear as an option for my "Sharp X68000" system..?
