ParaJVE and GCE Vectrex error message
crane_minter
I'm using ParaJVE 0.7.0. When launching the games outside of Hyperspin they work fine, but when using Hyperlaunch, all games do start, but after about 30 seconds I get the following error message:
There was an error waiting for the window "ParaJVEahk_class SunAwtFrame"
I'm using Java Runtime Environment 1.5.0+ and the official Hyperlist database. Any ideas what's wrong?
Often with that error you are using the wrong version of the emulator, or the wrong module.
Mine works great with ParaJVE v0.7.0, the ParaJVE module v2.0.2 and HyperLaunch v3.0.1.1
Make sure your Global emulator is pointed to ParaJVE.exe and not ParaJVE_console.exe.
Lastly, please post your HyperLaunch log as per this post: http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm
Thanks,
Ron
Thanks,
Ron
Hi,
thanks for reply.
Took a look at what you posted and I have the same emulator and module but the HyperLaunch version is v3.0.0.9. Emulator is also pointed to the right exe.
HyperSpin is v1.3.2.0 with update pack and for HyperLaunchHQ v.1.0.13.0.
Is there a way to download the update for HyperLaunch v3.0.1.1. I tried to find it but it seems it's only possible with the GIT program. My problem is that I use a computer to download all the stuff, but then I port that to one without internet connection, so I only have HyperSpin and co. installed in the Internet-less computer.
I will also try to post the HyperLaunch log asap, but as I mentioned, I have to bring it from one computer to the other. Will do it when I have some more free time.
Hi,
thanks for reply.
This post explains how to update without installing the GIT program. You can download the update as a zip file:
http://www.hyperspin-fe.com/forum/showthread.php?31472-Complete-Guide-for-Commodore-Amiga-in-HS-and-RL-Using-WinUAE-Only&p=304130&viewfull=1#post304130
Thanks,
Ron
Hi,
I updated Hyperlaunch but still have the same problem. Game starts fine but still get the above error message after about 30 seconds.
I have included the log. Hope this is the right one. I selected the TroubleShooting logging level.
15:49:03:671 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.0.1.1c
15:49:03:812 | HL |     INFO  | +141   | Main - System Specs:
				HyperLaunch Dir: D:\HyperSpin\HyperLaunch
				OS: Microsoft Windows XP Professional
				SKU:
				Total Memory: 3326.39 MB
				Free Memory: 2652.68 MB
				Used Memory: 673.703 MB
				SystemType: X86-based PC
				Physical Processors: See Logical in XP
				Logical Processors: 1
				GPU 1 Name: RADEON X800 XT
				GPU 1 RAM: 256.00 MB
				GPU 1 Driver Version: 6.14.10.6925
				GPU 2 Name: RADEON X800 XT Secondary
				GPU 2 RAM: 256.00 MB
				GPU 2 Driver Version: 6.14.10.6925
				Sound 1 Device: Realtek High Definition Audio
				Sound 1 Status: Enabled
				OS Language: Spanish_Modern_Sort
				OS Admin Status: Yes
				Monitor #1 (\\.\DISPLAY1): 1024x768 (1024x738 work)
				AutoHotkey Path:
				AHK Version: 1.1.09.04
				Unicode: No
15:49:03:812 | HL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x y w h
15:49:03:812 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\HyperLaunch.exe exists
15:49:03:812 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileVersion             	3.0.1.1
				File Size:			910336 bytes
				Created:			10/4/2014 - 2:04:56
				Modified:			9/7/1601 - 10:13:47
15:49:03:812 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Module Extensions\itextsharp.dll exists
				FileDescription         	iTextSharp
				FileVersion             	5.4.2.0
				InternalName            	itextsharp.dll
				LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
				OriginalFilename        	itextsharp.dll
				ProductName             	iTextSharp
				ProductVersion          	5.4.2.0
				CompanyName             	1T3XT BVBA
				File Size:			3743744 bytes
				Created:			10/4/2014 - 2:04:57
				Modified:			10/13/1601 - 1:24:20
15:49:03:812 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Module Extensions\SevenZipSharp.dll exists
				FileDescription         	SevenZipSharp
				FileVersion             	0.64.4841.31212
				InternalName            	SevenZipSharp.dll
				LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
				OriginalFilename        	SevenZipSharp.dll
				ProductName             	SevenZipSharp
				ProductVersion          	0.64.4841.31212
				CompanyName             	Markovtsev Vadim
				File Size:			165888 bytes
				Modified:			8/2/1601 - 7:03:15
15:49:03:812 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Module Extensions\gsdll32.dll exists
				File Size:			8818688 bytes
				Modified:			6/12/1601 - 9:22:28
15:49:03:812 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Module Extensions\BlockInput.exe exists
				FileDescription
				InternalName
				OriginalFilename
				ProductName
				File Size:			657920 bytes
				Created:			10/17/2014 - 3:31:59
				Modified:			8/5/1601 - 8:08:17
15:49:03:812 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Module Extensions\gdip.ahk exists
15:49:03:828 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
15:49:03:828 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			88789 bytes
				Created:			10/4/2014 - 2:04:55
				Modified:			10/3/2014 - 4:19:48
15:49:03:828 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Module Extensions\RIni.ahk exists
15:49:03:828 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
				File Size:			67561 bytes
				Modified:			1/31/1601 - 10:15:49
15:49:03:828 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Module Extensions\CLR.ahk exists
				File Size:			10586 bytes
				Modified:			2/22/1601 - 2:57:32
15:49:03:828 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Module Extensions\COM.ahk exists
				File Size:			26342 bytes
				Modified:			5/11/1601 - 10:43:22
15:49:03:828 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Module Extensions\JSON.ahk exists
				File Size:			9203 bytes
				Modified:			2/15/1601 - 5:57:38
15:49:03:828 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Lib\Fade Init.ahk exists
15:49:03:828 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
				File Size:			1145 bytes
				Modified:			1/6/1601 - 4:36:13
15:49:03:828 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Lib\HyperPause Init.ahk exists
				File Size:			691 bytes
				Modified:			1/4/1601 - 10:26:22
15:49:03:828 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Lib\Keymapper Init.ahk exists
				File Size:			3435 bytes
				Modified:			1/18/1601 - 1:48:41
15:49:03:828 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Lib\MultiGame Init.ahk exists
15:49:03:843 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
15:49:03:843 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			161 bytes
				Modified:			1/1/1601 - 7:12:28
15:49:03:843 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Lib\Statistics Init.ahk exists
15:49:03:843 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
				File Size:			167 bytes
				Modified:			1/1/1601 - 7:55:25
15:49:03:843 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Lib\Fade.ahk exists
				File Size:			25516 bytes
				Modified:			5/7/1601 - 8:10:38
15:49:03:843 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Lib\HyperPause.ahk exists
15:49:03:859 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
15:49:03:859 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			360180 bytes
				Modified:			9/21/1601 - 8:45:36
15:49:03:859 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Lib\Keymapper.ahk exists
15:49:03:859 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
				File Size:			30775 bytes
				Modified:			6/2/1601 - 11:36:01
15:49:03:859 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Lib\MultiGame.ahk exists
				File Size:			36816 bytes
				Modified:			7/3/1601 - 12:19:11
15:49:03:859 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Lib\Bezel.ahk exists
				File Size:			83008 bytes
				Modified:			4/18/1601 - 5:09:45
15:49:03:875 | HL |     INFO  | +16    | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Lib\Statistics.ahk exists
15:49:03:875 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:49:03:875 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			26153 bytes
				Modified:			5/11/1601 - 12:10:27
15:49:03:875 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists
				File Size:			63798 bytes
				Modified:			1/12/1601 - 5:19:13
15:49:03:875 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Lib\Shared.ahk exists
				File Size:			81966 bytes
				Modified:			4/13/1601 - 12:50:49
15:49:03:875 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Lib\XHotkey.ahk exists
				File Size:			28374 bytes
				Modified:			5/22/1601 - 1:09:00
15:49:03:875 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Lib\Fade Animations.ahk exists
15:49:03:890 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
15:49:03:890 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			49050 bytes
				Modified:			9/1/1601 - 7:53:34
15:49:03:890 | HL |     INFO  | +0     | Main - HyperLaunch received "GCE Vectrex" and "Berzerk (World)"
15:49:03:890 | HL |     INFO  | +0     | Main - Berzerk (World) is using the default emulator: ParaJVE
15:49:03:890 | HL |     INFO  | +0     | Main - Checking for a [ParaJVE] section in D:\HyperSpin\HyperLaunch\Settings\GCE Vectrex\Emulators.ini
15:49:03:890 | HL |     INFO  | +0     | Main - Found [ParaJVE] in D:\HyperSpin\HyperLaunch\Settings\GCE Vectrex\Emulators.ini
15:49:03:890 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Modules\ParaJVE\ParaJVE.ahk exists
				File Size:			7876 bytes
				Modified:			10/17/2014 - 3:48:08
15:49:03:890 | HL |  WARNING  | +0     | Main - CRC Check - CRC does not match official module and will not be supported. Continue using at your own risk.
15:49:03:890 | HL |     INFO  | +0     | Main - Berzerk (World) will use module: D:\HyperSpin\HyperLaunch\Modules\ParaJVE\ParaJVE.ahk
15:49:03:906 | HL |     INFO  | +15    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
15:49:03:906 | HL |     INFO  | +0     | Main - INI Keys read
15:49:03:906 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Module Extensions\7z.exe exists
15:49:03:906 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileVersion             	9.20
				InternalName            	7z
				ProductVersion          	9.20
				File Size:			163840 bytes
				Modified:			7/23/1601 - 2:43:12
15:49:03:906 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Module Extensions\7z.dll exists
				FileVersion             	9.20
				InternalName            	7za
				ProductVersion          	9.20
				File Size:			914432 bytes
				Modified:			9/27/1601 - 6:54:06
15:49:03:906 | HL |     INFO  | +0     | CheckPaths - Started
15:49:03:906 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\HyperSpin\Roms\GCE Vectrex\Berzerk (World).zip
15:49:03:906 | HL |     INFO  | +0     | CheckPaths - Found rom: D:\HyperSpin\Roms\GCE Vectrex\Berzerk (World).zip
15:49:03:906 | HL |   DEBUG1  | +0     | CheckPaths - Current romName: Berzerk (World)
15:49:03:906 | HL |   DEBUG1  | +0     | CheckPaths - Current romPath: D:\HyperSpin\Roms\GCE Vectrex
15:49:03:906 | HL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .zip
15:49:03:906 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\Emulators\ParaJVE\ParaJVE.exe exists
				FileDescription         	ParaJVE launcher (GUI mode)
				FileVersion             	0.7.0
				InternalName            	ParaJVE_windows
				LegalCopyright          	2006-2010, Franck Chevassu
				OriginalFilename        	ParaJVE.exe
				ProductName             	Parabellum's Java Vectrex Emulator
				ProductVersion          	0.7.0.101120
				CompanyName             	-
				File Size:			18944 bytes
				Created:			11/20/2010 - 1:48:52
				Modified:			11/20/2010 - 1:48:52
15:49:03:906 | HL |     INFO  | +0     | CheckPaths - Ended
15:49:03:906 | HL |     INFO  | +0     | BuildScript - User Variables:
				; INJECTED VARIABLES
				#NoTrayIcon
				#InstallKeybdHook
				DetectHiddenWindows, ON
				SetTitleMatchMode, 2
				SendMode, Event
				0 = 2
				hlMode =
				frontendPID = 0
				frontendPath = D:\HyperSpin
				frontendExe = HyperSpin.exe
				frontendExt = exe
				frontendName = HyperSpin
				frontendDrive = D:
				exitEmulatorKey = ~Esc
				exitEmulatorKeyWait = 0
				forceHoldKey = ~Esc
				restoreFE = false
				exitScriptKey = ~q & ~s
				toggleCursorKey = ~e & ~t
				emuFullPath = D:\HyperSpin\Emulators\ParaJVE\ParaJVE.exe
				emuPath = D:\HyperSpin\Emulators\ParaJVE
				emuName = ParaJVE
				emuExt = exe
				romPath = D:\HyperSpin\Roms\GCE Vectrex
				romPathFromIni = D:\HyperSpin\Roms\GCE Vectrex
				romExtension = .zip
				romExtensionOrig = .zip
				romExtensions = zip|vec|bin
				executable = ParaJVE.exe
				systemName = GCE Vectrex
				dbName = Berzerk (World)
				romName = Berzerk (World)
				romMapPath =
				romMappingEnabled = false
				romMappingMenuWidth = 300
				romMappingMenuMargin = 50
				romMappingTextMargin = 10
				romMappingMenuFlagWidth = 40
				skipchecks = false
				romMatchExt = true
				blockInputTime = 0
				blockInputFile = D:\HyperSpin\HyperLaunch\Module Extensions\BlockInput.exe
				errorLevelReporting = false
				logFile = D:\HyperSpin\HyperLaunch\HyperLaunch.log
				logLevel = 10
				logIncludeModule = true
				logShowCommandWindow = false
				logCommandWindow = false
				sysLang = Spanish_Modern_Sort
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				navSelectKey = Enter
				navP2UpKey = Numpad8
				navP2DownKey = Numpad2
				navP2LeftKey = Numpad4
				navP2RightKey = Numpad6
				navP2SelectKey = NumpadEnter
				originalWidth = 1024
				originalHeight = 768
				dtEnabled = true
				dtPath =
				dtUseSCSI = true
				dtAddDrive = true
				emuIdleShutdown = 0
				hideCursor = false
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDuration = 500
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOutExitDelay = 0
				fadeOut = false
				fadeOutExtraScreen = false
				fadeOutDuration = 500
				fadeOutDelay = 0
				fadeLyrInterpolation = 7
				fadeLyr1Color = FF000000
				fadeLyr2X = 300
				fadeLyr2Y = 300
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3Pos = Center
				fadeLyr3X = 300
				fadeLyr3Y = 300
				fadeLyr3Adjust = 0.75
				fadeLyr3Speed = 750
				fadeLyr3Type = imageandbar
				fadeLyr3Repeat = 1
				fadeLyr3PicPad = 0
				fadeLyr4Adjust = 0.75
				fadeLyr4X = 100
				fadeLyr4Y = 100
				fadeLyr4FPS = 10
				fadeLyr4PicPad = 0
				fadeTranspGifColor = FFFFFF
				fadeBarWindow = false
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 600
				fadeBarWindowH = 120
				fadeBarWindowR = 20
				fadeBarWindowM = 20
				fadeBarWindowHatchStyle = 8
				fadeBarBack = true
				fadeBarBackColor = FF555555
				fadeBarH = 20
				fadeBarR = 5
				fadeBarColor = DD00BFFF
				fadeBarHatchStyle = 3
				fadeBarPercentageText = true
				fadeBarInfoText = true
				fadeBarXOffset = 0
				fadeBarYOffset = 100
				fadeRomInfoDescription = text
				fadeRomInfoSystemName = text
				fadeRomInfoYear = text
				fadeRomInfoGenre = text
				fadeRomInfoRating = text
				fadeRomInfoTextMargin = 5
				fadeStatsInfoTextMargin = 5
				fadeText1X = 0
				fadeText1Y = 0
				fadeText1 = Loading Game
				fadeText2X = 0
				fadeText2Y = 0
				fadeFont = Arial
				fadeInterruptKey =
				detectFadeErrorEnabled = true
				fadeImgPath = D:\HyperSpin\HyperLaunch\Media\Fade
				HLDataPath = D:\HyperSpin\HyperLaunch\Data
				HLMediaPath = D:\HyperSpin\HyperLaunch\Media
				HLErrSoundPath = D:\HyperSpin\HyperLaunch\Media\Sounds\Error
				modulesPath = D:\HyperSpin\HyperLaunch\Modules
				moduleFullName = D:\HyperSpin\HyperLaunch\Modules\ParaJVE\ParaJVE.ahk
				moduleName = ParaJVE
				modulePath = D:\HyperSpin\HyperLaunch\Modules\ParaJVE
				moduleExtension = ahk
				moduleExtensionsPath = D:\HyperSpin\HyperLaunch\Module Extensions
				libPath = D:\HyperSpin\HyperLaunch\Lib
				7zEnabled = false
				7zPath = D:\HyperSpin\HyperLaunch\Module Extensions\7z.exe
				7zDllPath = D:\HyperSpin\HyperLaunch\Module Extensions\7z.dll
				7zExtractPath = C:\DOCUME~1\CLAUDIO\CONFIG~1\Temp\HS
				7zExtractPathOrig =
				7zAttachSystemName = false
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgBackgroundColor = FF000000
				mgSidePadding = 0.2
				mgYOffset = 500
				mgImageAdjust = 1
				mgFont = Arial
				mgText2Offset = 70
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgSelectedEffect = rotate
				mgUseGameArt = false
				mgArtworkDir = Artwork1
				hpEnabled = false
				hpKey = ~NumpadAdd
				hpBackToMenuBarKey = X
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = D:\HyperSpin\HyperLaunch\Module Extensions\HiToText.exe
				hpSaveStateKeyCodes =
				hpLoadStateKeyCodes =
				keymapperEnabled = false
				keymapperAHKMethod = false
				keymapper = ahk
				xpadderFullPath = D:\HyperSpin\Utilities\Xpadder\xpadder.exe
				joyToKeyFullPath = D:\HyperSpin\Utilities\JoyToKey\JoyToKey.exe
				keymapperProfilePath = D:\HyperSpin\HyperLaunch\Profiles\ahk
				JoyIDsEnabled = false
				JoyIDsPreferredControllersSystem = use_global
				CustomJoyNamesEnabled = false
				CustomJoyNames =
				FEProfile = D:\HyperSpin\HyperLaunch\Profiles\ahk\HyperSpin
				defaultProfile = D:\HyperSpin\HyperLaunch\Profiles\ahk\_Default
				systemProfile = D:\HyperSpin\HyperLaunch\Profiles\ahk\GCE Vectrex
				xPadderSystemProfile = D:\HyperSpin\HyperLaunch\Profiles\ahk\GCE Vectrex\_Default
				emuProfile = D:\HyperSpin\HyperLaunch\Profiles\ahk\GCE Vectrex\ParaJVE
				romProfile = D:\HyperSpin\HyperLaunch\Profiles\ahk\GCE Vectrex\Berzerk (World)
				HyperLaunchProfile = D:\HyperSpin\HyperLaunch\Profiles\ahk\HyperLaunch
				blankProfile = D:\HyperSpin\HyperLaunch\Profiles\ahk\blank
				ahkFEProfile = D:\HyperSpin\HyperLaunch\Profiles\AHK\HyperSpin
				ahkDefaultProfile = D:\HyperSpin\HyperLaunch\Profiles\AHK\_Default
				ahkSystemProfile = D:\HyperSpin\HyperLaunch\Profiles\AHK\GCE Vectrex
				ahkEmuProfile = D:\HyperSpin\HyperLaunch\Profiles\AHK\GCE Vectrex\ParaJVE
				ahkRomProfile = D:\HyperSpin\HyperLaunch\Profiles\AHK\GCE Vectrex\Berzerk (World)
				ahkHyperLaunchProfile = D:\HyperSpin\HyperLaunch\Profiles\AHK\HyperLaunch
				bezelEnabled = false
				statisticsEnabled = true
15:49:03:906 | HL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
15:49:03:906 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
15:49:03:906 | HL |     INFO  | +0     | BuildScript - Loaded User Functions Init.ahk script
15:49:03:906 | HL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
15:49:03:906 | HL |     INFO  | +0     | BuildScript - Module:
				MEmu = ParaJVE
				MEmuV = v0.7.0
				MURL = http://www.vectrex.fr/ParaJVE/
				MAuthor = djvj
				MVersion = 2.0.2
				MCRC = 3793FAE9
				iCRC = DC6FE5FD
				MID = 635038268912130749
				MSystem = "GCE Vectrex"
				; Notes:
				; To use the built-in roms for this emu, set SkipChecks to "Rom Only" in HLHQ.
				; ParaJVE requires Java Runtime Environment 1.5.0+ - Get it here: http://java.com/en/download/index.jsp
				; Roms are not needed for this system, they come with the emu
				; You must use the official database from HyperList for this module to work
				; In order to use the built-in overlays, the romName is being converted to the emu's built in game id found in the configuration.xml. This avoids having to edit the xml manually to change it to HS naming standards. We also don't have to setup overlay files this way too!
				StartModule()
				BezelGUI()
				FadeInStart()
				CreateParaModuleIni()   ; create default ini if one doesn't exist
				Menu := IniReadCheck(settingsFile, "Settings", "Menu","false",,1)
				Sound := IniReadCheck(settingsFile, "Settings", "Sound","true",,1)
				gameID := IniReadCheck(settingsFile, romName, "gameID",A_Space,,1)
				hideEmuObj := Object("ahk_class Static",0,"ParaJVE ahk_class SunAwtFrame",1)    ; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
				IfExist % romPath . "\" . romName . romExtension
				If (!gameID && !userRom)
				        ScriptError("Built-in rom not found in " . moduleName . ".ini or in " . romPath . "\" . romName . romExtension . "`nPlease use the official database from HyperList" )
				BezelStart()
				fullscreen := If Fullscreen = "true" ? "-Fullscreen=TRUE" : "-Fullscreen=FALSE"
				menu := If Menu = "true" ? "-Menu=ON" : "-Menu=OFF"
				sound := If Sound = "true" ? "-Sound=ON" : "-Sound=OFF"
				disableHideToggleMenu := true
				If bezelPath {          ; check for a bezel image and disable ParaJVE's chassis setting if found
				        paraJVEFile := CheckFIle(emuPath . "\data\configuration.xml")
				        FileRead, paraJVECFG, %paraJVEFile%
				        If InStr(paraJVECFG, "chassis enabled=""true""") {
				                paraJVEOrig := paraJVECFG
				                paraJVECFG := RegExReplace(paraJVECFG,"chassis enabled=""true""","chassis enabled=""false""")
				                Log("Module - Disabling chassis setting in ParaJVE's configuration.xml so bezels work properly")
				                SaveFile(paraJVECFG, paraJVEFile)
				HideEmuStart()
				Run(executable . " -game=" . (If userRom ? """" . romPath . "\" . romName . romExtension . """" : gameID) . " " . Fullscreen . " " . Menu . " " . Sound, emuPath) ;, "Min")
				WinWait("ParaJVE ahk_class SunAwtFrame")
				WinWaitActive("ParaJVE ahk_class SunAwtFrame")
				BezelDraw()
				HideEmuEnd()
				FadeInExit()
				Process("WaitClose", "javaw.exe")
				FadeOutExit()
				If paraJVEOrig {        ;If bezel was used, save original config file
				        Log("Module - Restoring ParaJVE's original configuration.xml")
				        SaveFile(paraJVEOrig, paraJVEFile)
				ExitModule()
				CreateParaModuleIni() {
				        Global settingsFile
				        If !FileExist(settingsFile)
				        {       txt := "# Standard games`r`n[Armor..Attack (World)]`r`ngameID = ARMORATTACK`r`n[bedlam (USA, Europe)]`r`ngameID = BEDLAM`r`n[berzerk (World)]`r`ngameID = BERZERK`r`n[blitz! - Action Football (USA, Europe)]`r`ngameID = BLITZ`r`n[Clean Sweep (World)]`r`ngameID = CLEANSWEEP`r`n[Cosmic Chasm (World)]`r`ngameID = COSMICCHASM`r`n[Fortress of Narzod (USA, Europe)]`r`ngameID = NARZOD`r`n[Heads-Up - Action Soccer (USA)]`r`ngameID = HEADSUP`r`n[HyperChase - Auto Race (World)]`r`ngameID = HYPERCHASE`r`n[Mine Storm (World)]`r`ngameID = MINESTORM`r`n[Mine Storm II (USA)]`r`ngameID = MINESTORM2`r`n[Polar Rescue (USA)]`r`ngameID = POLARRESCUE`r`n[Pole Position (USA)]`r`ngameID = POLEPOSITION`r`n[Rip Off (World)]`r`ngameID = RIPOFF`r`n[scramble (USA, Europe)]`r`ngameID = SCRAMBLE`r`n[solar Quest (World)]`r`ngameID = SOLARQUEST`r`n[space Wars (World)]`r`ngameID = SPACEWARS`r`n[spike (USA, Europe)]`r`ngameID = SPIKE`r`n[spinball (USA)]`r`ngameID = SPINBALL`r`n[star Castle (USA)]`r`ngameID = STARCASTLE`r`n[star Trek - The Motion Picture (USA)]`r`ngameID = STARTREK`r`n[star Hawk (World)]`r`ngameID = STARHAWK`r`n[Web Wars (USA)]`r`ngameID = WEBWARS`r`n# 3D Imager games`r`n[3D Crazy Coaster (USA)]`r`ngameID = 3DCRAZYCOASTER`r`n[3D Mine Storm (USA)]`r`ngameID = 3DMINESTORM`r`n[3D Narrow Escape (USA)]`r`ngameID = 3DNARROWESCAPE`r`n# Homebrew games`r`n[3D Lord Of The Robots (World) (Unl)]`r`ngameID = 3DLOTR`r`n[All Good Things (World) (Unl)]`r`ngameID = ALLGOODTHINGS`r`n[City Bomber (World) (Unl)]`r`ngameID = CITYBOMBER`r`n[Continuum (World) (Unl)]`r`ngameID = CONTINUUM`r`n[Gravitrex (World) (Unl)]`r`ngameID = GRAVITREX`r`n[Moon Lander (World) (Unl)]`r`ngameID = MOONLANDER`r`n[Nebula Commander (World) (Unl)]`r`ngameID = NEBULA`r`n[Omega Chase (World) (Unl)]`r`ngameID = OMEGACHASE`r`n[Patriots (World) (Unl)]`r`ngameID = PATRIOTS`r`n[Patriots Remix (World) (Unl)]`r`ngameID = PATRIOTSREMIX`r`n[Patriots III (World) (Unl)]`r`ngameID = PATRIOTS3`r`n[Protector (World) (Unl)]`r`ngameID = PROTECTOR`r`n[Repulse (World) (Unl)]`r`ngameID = REPULSE`r`n[Revector (World) (Unl)]`r`ngameID = REVECTOR`r`n[Rockaroids Remix (World) (Unl)]`r`ngameID = ROCKAR`r`n[Rockaroids Remix - 3rd Rock (World) (Unl)]`r`ngameID = ROCKAR3RD`r`n[space Frenzy (World) (Unl)]`r`ngameID = SPACEFRENZY`r`n[spike Hoppin' (World) (Unl)]`r`ngameID = SPIKEHOPPIN`r`n[spike's Water Balloons (World) (Unl)]`r`ngameID = SPIKEBALLONS`r`n[star Fire Spirits (World) (Unl)]`r`ngameID = STARFIRESPIR`r`n[star Sling - Freeware Edition (World) (Unl)]`r`ngameID = STARSLING`r`n[star Sling - Turbo Edition (World) (Unl)]`r`ngameID = STARSLING_1`r`n[Thrust (World) (Unl)]`r`ngameID = THRUST`r`n[Tsunami (World) (Unl)]`r`ngameID = TSUNAMI`r`n[Vectrex Frogger (World) (Unl)]`r`ngameID = VFROGGER`r`n[Vaboom! (World) (Unl)]`r`ngameID = VABOOM`r`n[Vec Fu (World) (Unl)]`r`ngameID = VECFU`r`n[Vecmania (World) (Unl)]`r`ngameID = VECMANIA64`r`n[Vectopia (World) (Unl)]`r`ngameID = VECTOPIA64`r`n[Vector 21 (World) (Unl)]`r`ngameID = VECTOR21`r`n[Vector Sports Boxing (World) (Unl)]`r`ngameID = VECTORSPORTSBOX`r`n[Vector Vaders (World) (Unl)]`r`ngameID = VECTORVADERS`r`n[Vector Vaders Remix (World) (Unl)]`r`ngameID = VECTORVADERSREMIX`r`n[Vectrace (World) (Unl)]`r`ngameID = VECTRACE`r`n[Vectrex Maze (World) (Unl)]`r`ngameID = VECTREXMAZE`r`n[Vectrex Pong (World) (Unl)]`r`ngameID = VECTREXPONG`r`n[Vectrexians (World) (Unl)]`r`ngameID = VECTREXIANS`r`n[Vexperience - B.E.T.H. and Vecsports Boxing (World) (Unl)]`r`ngameID = VEXPERIENCE`r`n[Vimpula (World) (Unl)]`r`ngameID = VIMPULA`r`n[VIX (World) (Unl)]`r`ngameID = VIX`r`n[War of the Robots (World) (Unl)]`r`ngameID = WOTR`r`n[War of the Robots - Bow to the Queen (World) (Unl)]`r`ngameID = BTTQ`r`n[Wormhole (World) (Unl)]`r`ngameID = WORMHOLE`r`n# VecVoice enabled games`r`n[Verzerk (World) (Unl)]`r`ngameID = VERZERK`r`n[Yasi (World) (Unl)]`r`ngameID = YASI`r`n# Lightpen games`r`n[AnimAction - Advanced Animation (USA)]`r`ngameID = ANIMACTION`r`n[Art Master (USA)]`r`ngameID = ARTMASTER`r`n[Engine Analyzer (USA) (Proto)]`r`ngameID = ANALYZER`r`n[Melody Master - Music Composition and Entertainment (USA)]`r`ngameID = MELODYMASTER`r`n# Prototypes`r`n[Pitcher's Duel (USA) (Proto)]`r`ngameID = PITCHERSDUEL"
				                FileAppend, %txt%, %settingsFile%
				SaveFile(text,file) {
				        FileDelete, %file%
				        FileAppend, %text%, %file%
				CloseProcess:
				        FadeOutStart()
				        BezelExit()
				        WinClose("ParaJVE ahk_class SunAwtFrame")
				Return
15:49:03:906 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
15:49:03:906 | HL |     INFO  | +0     | BuildScript - Loaded User Functions.ahk script
15:49:03:906 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
15:49:03:906 | HL |     INFO  | +0     | Main - Module is built
15:49:03:906 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\AutoHotkey.dll exists
				File Size:			785408 bytes
				Modified:			8/28/1601 - 5:53:38
15:49:03:921 | HL |     INFO  | +16    | Main - Running module
15:49:03:921 | HL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
15:49:04:015 | MD |     INFO  | +N/A   | Module initialized
15:49:04:015 | MD |     INFO  | +0     | StartModule - Started
15:49:04:015 | MD |     INFO  | +0     | StartModule - MEmu: ParaJVE
				MEmuV: v0.7.0
				MURL: http://www.vectrex.fr/ParaJVE/
				MAuthor: djvj
				MVersion: 2.0.2
				MCRC: 3793FAE9
				iCRC: DC6FE5FD
				MID:
				MSystem: "GCE Vectrex"
15:49:04:015 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "GCE Vectrex"
15:49:04:015 | MD |   DEBUG1  | +0     | StartModule - Leaving romName as is because Rom Mapping filled it with an Alternate_Rom_Name: Berzerk (World)
15:49:04:015 | MD |     INFO  | +0     | StartModule - Ended
15:49:04:015 | MD |     INFO  | +0     | StartGlobalUserFeatures - Starting
15:49:04:015 | MD |     INFO  | +0     | StartGlobalUserFeatures - Ending
15:49:04:015 | MD |     INFO  | +0     | Module Setting - [settings] - Fullscreen: true
15:49:04:015 | MD |     INFO  | +0     | Module Setting - [settings] - Menu: false
15:49:04:015 | MD |     INFO  | +0     | Module Setting - [settings] - Sound: true
15:49:04:015 | MD |     INFO  | +0     | Module Setting - [berzerk (World)] - gameID: BERZERK
15:49:04:015 | MD |     INFO  | +0     | Run - Running: D:\HyperSpin\Emulators\ParaJVE\ParaJVE.exe -game=BERZERK -Fullscreen=TRUE -Menu=OFF -Sound=ON
15:49:04:031 | MD |   DEBUG1  | +15    | Run - "ParaJVE.exe -game=BERZERK -Fullscreen=TRUE -Menu=OFF -Sound=ON" Process ID: 1700
15:49:04:046 | MD |   DEBUG1  | +16    | GetActiveWindowStatus - Title: HyperLaunch HQ v1.0.13.0 | Class: HwndWrapper[HyperLaunchHQ.exe;;5245545a-f85a-43c8-9fc6-6f591bb78382] | State: 1 | X: -4 | Y: -4 | Width: 1032 | Height: 746 | Window HWND: 0x70280 | Process ID: 2924 | Process Path: D:\HyperSpin\HyperLaunch\HyperLaunchHQ\HyperLaunchHQ.exe
15:49:04:046 | MD |     INFO  | +0     | WinWait - Waiting for "ParaJVE ahk_class SunAwtFrame"
15:49:34:046 | MD |   DEBUG1  | +30000 | GetActiveWindowStatus - Title: ParaJVE v0.7.0 | Class: javax.swing.JFrame | State: 0 | X: 0 | Y: 0 | Width: 1024 | Height: 768 | Window HWND: 0xd01f6 | Process ID: 600 | Process Path: C:\Archivos de programa\Java\jre1.5.0_10\bin\javaw.exe
15:49:34:390 | MD |   DEBUG1  | +344   | ScriptError - Playing error sound: error1.mp3
15:49:40:015 | MD |    ERROR  | +5625  | There was an error waiting for the window "ParaJVE ahk_class SunAwtFrame". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem.
15:49:40:015 | MD |     INFO  | +0     | ExitModule - Started
15:49:40:015 | MD |     INFO  | +0     | Starting Updating Statistics:
15:49:40:015 | MD |   DEBUG2  | +0     | Total Elapsed Time in Pause in seconds: 0
15:49:40:015 | MD |   DEBUG2  | +0     | gameSectionStartTime:1587703
15:49:40:015 | MD |   DEBUG2  | +0     | ElapsedTime:36
15:49:40:015 | MD |     INFO  | +0     | CreateRomTable - Started
15:49:40:015 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "Berzerk (World)" and "(Disc"
15:49:40:031 | MD |   DEBUG1  | +15    | CreateRomTable - Checking for match: "Berzerk (World)" and "(Disk"
15:49:40:031 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "Berzerk (World)" and "(Cart"
15:49:40:031 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "Berzerk (World)" and "(Tape"
15:49:40:031 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "Berzerk (World)" and "(Cassette"
15:49:40:031 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "Berzerk (World)" and "(Part"
15:49:40:031 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "Berzerk (World)" and "(Side"
15:49:40:031 | MD |     INFO  | +0     | CreateRomTable - Ended, 7 Loops to create table.
15:49:40:031 | MD |   DEBUG2  | +0     | Statistics cleared game name: Berzerk
15:49:40:062 | MD |   DEBUG2  | +32    | Loaded game statistics from ini files:
				Number_of_Times_Played: 1
				Last_Time_Played: viernes octubre 17, 2014 03:33:54
				Average_Time_Played: 33
				Total_Time_Played: 33
				System_Total_Played_Time: 33
				Total_Global_Played_Time: 5991
15:49:40:062 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 2
				Last_Time_Played: viernes octubre 17, 2014 03:49:04
				Average_Time_Played: 35
				Total_Time_Played: 69
				System_Total_Played_Time: 69
				Total_Global_Played_Time: 6027
15:49:40:093 | MD |     INFO  | +31    | Game section statistics updated.
15:49:40:093 | MD |     INFO  | +0     | ExitModule - Ended
15:49:40:093 | MD |     INFO  | +0     | End of Module Logs
15:49:40:109 | HL |     INFO  | +36187 | Main - Module ended, exiting HyperLaunch normally
15:49:40:109 | HL |     INFO  | +0     | ExitScript - Started
15:49:40:109 | HL |     INFO  | +0     | SystemCursor - Restoring mouse cursor
15:49:40:109 | HL |     INFO  | +0     | ExitScript - Ended
  • 2 months later...
Same exact problem here.. please advise...
- HL 3.0.1.1
- HLHQ 1.0.13
- Module: ParaJVE.ahk v.2.0.2
- Emu: ParaJVE v0.7.0
Game runs with overlay. About 30 seconds in I get the error below.
Error closes itself automatically and game is still running beneath.
Here's my log when running a game from HLHQ...
15:34:44:640 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.0.1.1c
15:34:44:890 | HL |     INFO  | +250   | Main - System Specs:
				HyperLaunch Dir: C:\HyperSpin\HyperLaunch
				OS: Microsoft(R) Windows(R) XP Professional x64 Edition
				SKU:
				Total Memory: 1407.14 MB
				Free Memory: 798.48 MB
				Used Memory: 608.652 MB
				SystemType: x64-based PC
				GPU 1 Name: ATI Radeon X1200 Series
				GPU 1 RAM: 576.00 MB
				GPU 1 Driver Version: 6.14.10.6903
				Sound 1 Device: ATI HDMI Audio
				Sound 2 Device: Realtek High Definition Audio
				Sound 2 Status: Enabled
				Monitor #1 (\\.\DISPLAY1): 1366x768 (1366x740 work)
				AutoHotkey Path:
				Unicode: No
15:34:44:890 | HL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x y w h
15:34:44:890 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\hyperlaunch.exe exists
15:34:44:890 | HL |     INFO  | +0     | Main - HyperLaunch received "GCE Vectrex" and "Pole Position (USA)"
15:34:44:906 | HL |     INFO  | +16    | Main - Pole Position (USA) is using the default emulator: Vectrex
15:34:44:906 | HL |     INFO  | +0     | Main - Checking for a [Vectrex] section in C:\HyperSpin\HyperLaunch\Settings\GCE Vectrex\Emulators.ini
15:34:44:906 | HL |     INFO  | +0     | Main - Found [Vectrex] in C:\HyperSpin\HyperLaunch\Settings\GCE Vectrex\Emulators.ini
15:34:44:906 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Modules\ParaJVE\ParaJVE.ahk exists
15:34:44:906 | HL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
15:34:44:906 | HL |     INFO  | +0     | Main - Pole Position (USA) will use module: C:\HyperSpin\HyperLaunch\Modules\ParaJVE\ParaJVE.ahk
15:34:44:937 | HL |     INFO  | +31    | Main - Using SkipChecks method "Rom Only".
15:34:44:937 | HL |     INFO  | +0     | Main - INI Keys read
15:34:44:937 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\7z.exe exists
15:34:44:937 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\7z.dll exists
15:34:44:937 | HL |  WARNING  | +0     | Main - SkipChecks is enabled and set to: Rom Only
15:34:44:937 | HL |     INFO  | +0     | CheckPaths - Started
15:34:44:937 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\Emulators\ParaJVE\ParaJVE.exe exists
15:34:44:937 | HL |     INFO  | +0     | CheckPaths - Ended
15:34:44:937 | HL |     INFO  | +0     | BuildScript - User Variables:
				#NoTrayIcon
				#InstallKeybdHook
				SendMode, Event
				0 = 2
				hlMode =
				frontendPID = 0
				frontendPath = C:\HyperSpin
				frontendExt = exe
				frontendDrive = C:
				forceHoldKey = ~Esc
				restoreFE = false
				emuFullPath = C:\HyperSpin\Emulators\ParaJVE\ParaJVE.exe
				emuPath = C:\HyperSpin\Emulators\ParaJVE
				emuName = Vectrex
				emuExt = exe
				romPath =
				romPathFromIni =
				romExtension =
				romExtensionOrig =
				romExtensions = bin
				dbName = Pole Position (USA)
				romName =
				romMapPath =
				skipchecks = Rom Only
				romMatchExt = true
				blockInputTime = 0
				blockInputFile =
				errorLevelReporting = true
				logFile = C:\HyperSpin\HyperLaunch\HyperLaunch.log
				logLevel = 3
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				originalWidth = 1366
				dtEnabled = true
				dtPath =
				dtUseSCSI = true
				dtAddDrive = true
				emuIdleShutdown = 0
				hideCursor = true
				hideEmu = true
				hideFE = false
				fadeIn = false
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOut = false
				fadeOutDelay = 0
				fadeLyr2X = 300
				fadeLyr2Y = 300
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3X = 300
				fadeLyr3Y = 300
				fadeLyr3Speed = 750
				fadeLyr3Repeat = 1
				fadeLyr3PicPad = 0
				fadeLyr4X = 100
				fadeLyr4Y = 100
				fadeLyr4FPS = 10
				fadeLyr4PicPad = 0
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowR = 20
				fadeBarWindowM = 20
				fadeBarBack = true
				fadeBarH = 20
				fadeBarR = 5
				fadeBarXOffset = 0
				fadeText1X = 0
				fadeText1Y = 0
				fadeText2X = 0
				fadeText2Y = 0
				fadeFont = Arial
				fadeInterruptKey =
				fadeImgPath = C:\HyperSpin\HyperLaunch\Media\Fade
				HLDataPath = C:\HyperSpin\HyperLaunch\Data
				HLMediaPath = C:\HyperSpin\HyperLaunch\Media
				HLErrSoundPath = C:\HyperSpin\HyperLaunch\Media\Sounds\Error
				modulesPath = C:\HyperSpin\HyperLaunch\Modules
				moduleFullName = C:\HyperSpin\HyperLaunch\Modules\ParaJVE\ParaJVE.ahk
				modulePath = C:\HyperSpin\HyperLaunch\Modules\ParaJVE
				moduleExtensionsPath = C:\HyperSpin\HyperLaunch\Module Extensions
				libPath = C:\HyperSpin\HyperLaunch\Lib
				7zEnabled = false
				7zPath = C:\HyperSpin\HyperLaunch\Module Extensions\7z.exe
				7zDllPath = C:\HyperSpin\HyperLaunch\Module Extensions\7z.dll
				7zExtractPath = D:\
				7zExtractPathOrig =
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgSidePadding = 0.2
				mgYOffset = 500
				mgImageAdjust = 0
				mgFont = Arial
				mgText2Offset = 70
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				hpEnabled = false
				hpKey = ~NumpadAdd
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = C:\HyperSpin\HyperLaunch\Module Extensions\HiToText.exe
				keymapper =
				xpadderFullPath = C:\HyperSpin\HyperLaunch\Xpadder.exe
				joyToKeyFullPath = C:\HyperSpin\Utilities\JoyToKey\JoyToKey.exe
				keymapperProfilePath = C:\HyperSpin\HyperLaunch\Profiles\
				keymapperFrontEndProfile = xpadder
				CustomJoyNames =
				FEProfile = C:\HyperSpin\HyperLaunch\Profiles\\HyperSpin
				defaultProfile = C:\HyperSpin\HyperLaunch\Profiles\\_Default
				systemProfile = C:\HyperSpin\HyperLaunch\Profiles\\GCE Vectrex
				xPadderSystemProfile = C:\HyperSpin\HyperLaunch\Profiles\\GCE Vectrex\_Default
				emuProfile = C:\HyperSpin\HyperLaunch\Profiles\\GCE Vectrex\Vectrex
				romProfile = C:\HyperSpin\HyperLaunch\Profiles\\GCE Vectrex\Pole Position (USA)
				HyperLaunchProfile = C:\HyperSpin\HyperLaunch\Profiles\\HyperLaunch
				blankProfile = C:\HyperSpin\HyperLaunch\Profiles\\blank
				ahkFEProfile = C:\HyperSpin\HyperLaunch\Profiles\AHK\HyperSpin
				ahkDefaultProfile = C:\HyperSpin\HyperLaunch\Profiles\AHK\_Default
				ahkSystemProfile = C:\HyperSpin\HyperLaunch\Profiles\AHK\GCE Vectrex
				ahkEmuProfile = C:\HyperSpin\HyperLaunch\Profiles\AHK\GCE Vectrex\Vectrex
				ahkRomProfile = C:\HyperSpin\HyperLaunch\Profiles\AHK\GCE Vectrex\Pole Position (USA)
				ahkHyperLaunchProfile = C:\HyperSpin\HyperLaunch\Profiles\AHK\HyperLaunch
15:34:44:937 | HL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
15:34:44:937 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
15:34:44:937 | HL |     INFO  | +0     | BuildScript - Module:
				MEmu = ParaJVE
				MEmuV = v0.7.0
				MAuthor = djvj
				MVersion = 2.0.2
				MCRC = 3793FAE9
				iCRC = DC6FE5FD
				; Notes:
				StartModule()
				BezelGUI()
				FadeInStart()
				BezelStart()
				HideEmuStart()
				BezelDraw()
				HideEmuEnd()
				FadeInExit()
				FadeOutExit()
				ExitModule()
					Global settingsFile
					FileDelete, %file%
				CloseProcess:
					FadeOutStart()
					BezelExit()
				Return
15:34:44:937 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
15:34:44:937 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
15:34:44:937 | HL |     INFO  | +0     | Main - Module is built
15:34:44:937 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\AutoHotkey.dll exists
15:34:44:953 | HL |     INFO  | +16    | Main - Hiding taskbar
15:34:45:062 | HL |     INFO  | +109   | Main - Hiding desktop
15:34:45:062 | HL |     INFO  | +0     | Main - Running module
15:34:45:203 | MD |     INFO  | +N/A   | Module initialized
15:34:45:203 | MD |     INFO  | +0     | StartModule - Started
15:34:45:203 | MD |     INFO  | +0     | StartModule - MEmu: ParaJVE
				MEmuV: v0.7.0
				MAuthor: djvj
				MVersion: 2.0.2
				MCRC: 3793FAE9
				iCRC: DC6FE5FD
				MID:
15:34:45:203 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "GCE Vectrex"
15:34:45:203 | MD |     INFO  | +0     | Hiding mouse cursor
15:34:45:218 | MD |     INFO  | +15    | StartModule - Ended
15:34:45:218 | MD |     INFO  | +0     | Module Setting - [settings] - Fullscreen: true
15:34:45:218 | MD |     INFO  | +0     | Module Setting - [settings] - Menu: false
15:34:45:218 | MD |     INFO  | +0     | Module Setting - [settings] - Sound: true
15:34:45:218 | MD |     INFO  | +0     | Module Setting - [Pole Position (USA)] - gameID: POLEPOSITION
15:34:45:218 | MD |     INFO  | +0     | HideEmuStart - Starting HideEmuTimer, scanning for windows defined in hideEmuObj every 2ms
15:34:45:218 | MD |     INFO  | +0     | Run - Running: C:\HyperSpin\Emulators\ParaJVE\ParaJVE.exe -game=POLEPOSITION -Fullscreen=TRUE -Menu=OFF -Sound=ON
15:34:45:265 | MD |     INFO  | +47    | WinWait - Waiting for "ParaJVE ahk_class SunAwtFrame"
15:35:28:093 | MD |    ERROR  | +42828 | There was an error waiting for the window "ParaJVE ahk_class SunAwtFrame". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem.
15:35:28:093 | MD |     INFO  | +0     | ExitModule - Started
15:35:28:093 | MD |     INFO  | +0     | Starting Updating Statistics:
15:35:28:093 | MD |     INFO  | +0     | CreateRomTable - Started
15:35:28:093 | MD |     INFO  | +0     | CreateRomTable - Ended, 7 Loops to create table.
15:35:28:171 | MD |     INFO  | +78    | Game section statistics updated.
15:35:28:234 | MD |     INFO  | +63    | Restoring mouse cursor
15:35:28:234 | MD |     INFO  | +0     | ExitModule - Ended
15:35:28:234 | MD |     INFO  | +0     | End of Module Logs
15:35:28:312 | HL |     INFO  | +43250 | Main - Module ended, exiting HyperLaunch normally
15:35:28:312 | HL |     INFO  | +0     | ExitScript - Started
15:35:28:421 | HL |     INFO  | +109   | SystemCursor - Restoring mouse cursor
15:35:28:421 | HL |     INFO  | +0     | ExitScript - Ended
After looking over the log I turned off 'hide emulator' but that had no effect.
I notice that WinWait is called after the emulator launches and that's where it's throwing this error.
If I comment out these 2 lines form the module
;WinWait("ParaJVE ahk_class SunAwtFrame")
;WinWaitActive("ParaJVE ahk_class SunAwtFrame")
I don't get the error anymore but I do get a bit of blinking as the emulator loads.. (screen shows 'paraJVE' splash screen, shows HS again, black screen, game appears) which I'm sure has to do with commenting those 2 lines.
Any thoughts?
Could be that you are running a newer version of the emulator than the module was written for and they've since changed the Window class. You can use the ActiveWindowsLogger.ahk to find out what the window class is of the emulator's windows and let us know what it should be now.
I can check but I just used the 2.0.1 module and the 2.0.2 which both say they work with the version of paraJve I'm running.
where can I find info on using the window logger ahk u mentioned to troubleshoot?
besides Google of course.
Not sure what is going on. I have all the latest modules and HL files and the same version of the emulator. It works fine.
Thanks,
Ron
rfancella: i grabbed latest module files from either your folder or djvj's folder. i can't recall right now.
zerojay: i'll grab it from your folder but where do i put it/how do i use it?
@zerojay
Found activeWindow logger from djvj but no idea what to look for in here.
I see there's an error but I'm not seeing anywhere that mentions SunAwtFrame or similar.
Check it out...
11:33:27 PM |  (¯·._.·´¯·._.·´¯·._.·´¯·._STARTING LOG_.·´¯·._.·´¯·._.·´¯·._.·´¯)
11:33:27 PM |  Title/Class: HyperLaunch HQ v1.0.13.0 ahk_class HwndWrapper[HyperLaunchHQ.exe;;0bab3623-6617-413f-a4d9-121525dadc92] is now active
11:33:29 PM |  Title/Class: HyperLaunch HQ v1.0.13.0 ahk_class HwndWrapper[HyperLaunchHQ.exe;;0bab3623-6617-413f-a4d9-121525dadc92] is no longer active
11:33:29 PM |  Title/Class: BlackScreen ahk_class AutoHotkeyGUI is now active
11:33:29 PM |  Title/Class: BlackScreen ahk_class AutoHotkeyGUI is no longer active
11:33:29 PM |  Title/Class:  ahk_class Static is now active
11:33:29 PM |  Title/Class:  ahk_class Static is no longer active
11:33:30 PM |  Title/Class:  ahk_class Static is no longer active
11:33:30 PM |  Title/Class:  ahk_class Static is now active
11:33:31 PM |  Title/Class:  ahk_class Static is no longer active
11:33:31 PM |  Title/Class: ParaJVE v0.7.0 ahk_class javax.swing.JFrame is now active
11:33:59 PM |  Title/Class: ParaJVE v0.7.0 ahk_class javax.swing.JFrame is no longer active
11:33:59 PM |  Title/Class: Error Layer 1 ahk_class AutoHotkeyGUI is now active
11:34:16 PM |  Title/Class: Error Layer 1 ahk_class AutoHotkeyGUI is no longer active
11:34:17 PM |  Title/Class: ParaJVE v0.7.0 ahk_class javax.swing.JFrame is now active
11:34:25 PM |  (¯·._.·´¯·._.·´¯·._.·´¯·._EXITING SCRIPT_.·´¯·._.·´¯·._.·´¯·._.·´¯)
Ok. I think I fixed it.
Looking at AHK command documentation and then back at the active window log and then into the module I decided to swap out
WinActive("ParaJVE ahk_class SunAwtFrame")
with
WinWait("ParaJVE v0.7.0 ahk_class javax.swing.JFrame")
WinWaitActive("ParaJVE v0.7.0 ahk_class javax.swing.JFrame")
BAM.. no error!
Don't know if it's 'right' ... but it works for me.
Onto the next system.
That's odd because I don't see that window at all when I use parajve.post-4446-142870664976_thumb.jpg
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Maybe i got the emulator from some weird place. Different version of Java maybe?
Hmmm... I have a thought. What are you using for your emulator executable?
If you are using the ParaJVE_console.exe, try changing it to ParaJVE.exe and try again.
Thanks,
Ron
Using global emulator set in global emulators.ini
(Was one of the first things I checked as I read somewhere not to use console one)
[ParaJVE]
Emu_Path=..\Emulators\ParaJVE\ParaJVE.exe
Rom_Extension=zip|bin|vec|jverom
Module=ParaJVE.ahk
HyperPause_Save_State_Keys={F5 down}{F5 up}
HyperPause_Load_State_Keys={F9 down}{F9 up}
The mystery continues!
