jamaster14 Posted November 15, 2014 Posted November 15, 2014 are there instrucitons anywhere for adding TurboGrafx-16 to HS? It is the only emulator/console im having trouble with. Games work fine outside of hyperspin but wont launch in hyperspin. was looking for guides on it but they all are for HS 1.0 and they dont seem to be accurate for the newer version of HS im using.
gigapig Posted November 15, 2014 Posted November 15, 2014 Your best bet is to give us some more detail and post your logs so we can see why your chosen emu isn't working with Hyperlaunch. Thanks.
craiganderson Posted November 15, 2014 Posted November 15, 2014 mednafen works well for me just fyi http://craigandersonthemes.weebly.com/
gigapig Posted November 15, 2014 Posted November 15, 2014 Yes it works well with RetroArch as well, but I'm not sure if it's supported in the official module yet. Mine is the modified one.
craiganderson Posted November 15, 2014 Posted November 15, 2014 i need to learn about retroarch i just dont want to mess up all my systems that are working so well maybe later on..... to the OP post your logs and somebody will be able to help you i bet good luck! http://craigandersonthemes.weebly.com/
gigapig Posted November 15, 2014 Posted November 15, 2014 i need to learn about retroarchi just dont want to mess up all my systems that are working so well There's no need to mess things up, I still have the emulators setup for the ones I've moved over. I can switch between them very quickly if needed. And RetroArch works out of the box with 360 controllers.
jamaster14 Posted November 16, 2014 Author Posted November 16, 2014 i ended up just using magic engine instead and all is well. thanks for the responses, this just seemed like the path of least resistance with so many other things on my to do list for this project
dsnyd22 Posted December 16, 2014 Posted December 16, 2014 i tried to switch to retro arch and had button problems so i went back to magic engine. It works best for all my turbografx games but i get the error every time that says "waiting for window or whatever. I have given up on fixing this
