LED light bar
keithpaw
Hi guys just wondered if any one knows where I can purchase a LED light bar or the parts to build one my self I am in the UK
thanks in advance.
You can build it yourself. You just need:
- 5 flasher caps (transparent, several pinball part shops have these)
- A cable
For example like this one (Conrad):
https://www.conrad.nl/nl/kleurgecordeerde-vlakbandkabel-aantal-polen-16-awg-28-7-x-0127-mm-bkl-electronic-744279.html
- 5 RGB leds (350mA)
For instance these on e-bay:
http://www.ebay.com/itm/400644271034?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
IMPORTANT TIP: the plus sign on one of the legs is NOT the right one, use the one opposite. Probably a manufacturing fault. If you stick to that they work awesome and are very cheap.
- 15 resistors of 27 Ohm if you decide to hook them up on the 12V power supply of the PC. Also via Conrad or any other electronic store.
Much more satisfying and transport costs via zebsboards in Canada are pretty steep.
  • 4 weeks later...
