ninja2bceen Posted January 4, 2015 Posted January 4, 2015 Roma do you see this? Can it be fixed? I'm going to try it tonight Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
r0man0 Posted January 4, 2015 Author Posted January 4, 2015 Roma do you see this? Can it be fixed? I'm going to try it tonight yes , but i use an old version of hyperlaunch that placed at root of hyperspin directory , i don't know if the new versions of hyperlaunch can be placed on any folder that user want or just HyperLaunch\ hyperlaunch.exe. can somebody knows the answer ? Sorry but i'm not interested to test now the new version of hyperlaunch, and i need to know that in order to fix it...
arshesney Posted January 4, 2015 Posted January 4, 2015 No dice, can't get the latest version to work, if I copy hyperlaunch.exe in the root hyperspin folder the Create Databases hangs around 10%, if I remove the copied hyperlaunch.exe, hypersearch complains that the ini is corrupted.
r0man0 Posted January 4, 2015 Author Posted January 4, 2015 Ok , i've fixed the path for hyperlaunch to be at root or in HyperLaunch\ of hyperspin folder. Please tell me if it solve the problem. here is the fixed HyperSearch.exe : http://hypermachine.free.fr/HyperSearch-fixed.zip
ninja2bceen Posted January 4, 2015 Posted January 4, 2015 U should go to hyperlaunch 2 it's amazing and soooo much better. RocketLauncher is in beta, has some bugs but I'd be surprised if many folks were on hyperlaunch 1 still considering all the amazing features and it just works better. Back to the question at hand though, hyperlaunch needs to be in this folder, it shouldn't move or be renamed.. Can this happen? ..hyperspin/hyperlaunch/hyperlaunch.exe Can't wait to test this. Oh also I think hypersearch needs to be able to be saved anywhere since it will act as an emulator withing hyperhq and ran as an exe. Good luck, looking fwd to trying it Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
arshesney Posted January 4, 2015 Posted January 4, 2015 The fixed .exe does not need hyperlaunch.exe in the main hyperspin folder, now it works as expected even with hyperlaunch beta. Regarding the create database issuse it was because of some comments in one of the xml files, when i deleted them the database was created succesfully. Thank you edit: another minor issue: the fullscreen mode is set to 800x600 which messes up all the other open windows, is there any option to set the fullscreen resolution?
r0man0 Posted January 4, 2015 Author Posted January 4, 2015 The fixed .exe does not need hyperlaunch.exe in the main hyperspin folder, now it works as expected even with hyperlaunch beta.Regarding the create database issuse it was because of some comments in one of the xml files, when i deleted them the database was created succesfully. Thank you edit: another minor issue: the fullscreen mode is set to 800x600 which messes up all the other open windows, is there any option to set the fullscreen resolution? Ok , also if possible i would like to see your xml file or a part of this to know how to increase compatibility with non-conventional xml-list. About screen resolution , for the moment it will only be available for 800*600 , others resolutions will be added later. I will try to fix problem with open Windows tomorow and if possible update main post. the package have been updated with the fixed hyperlaunch path at same adress : http://hypermachine.free.fr/HyperSearch_v0.9beta4_04-01-2015.zip
ninja2bceen Posted January 5, 2015 Posted January 5, 2015 Hello, I also get a hang when I load the exe. I'd say it's stuck on 25% in creating a database. My main menu xml is clean without comments. Within my database folder in each system folder, I may have a folder named old. Do you think the sub folders would mess it up? I also have a lot of genre xmls Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
r0man0 Posted January 5, 2015 Author Posted January 5, 2015 Hello, I also get a hang when I load the exe. I'd say it's stuck on 25% in creating a database. My main menu xml is clean without comments. Within my database folder in each system folder, I may have a folder named old. Do you think the sub folders would mess it up? I also have a lot of genre xmls Hi , thank you for testing HyperSearch , HyperSearch don't use xml genre list to create database , just the main list (atari 2600.xml , amiga.xml .... that are placed in the same name folder and also on the databases folder) If your database creating stay around 25% , not sure but maybe that could be one of your main list xml that is not compatible , but to know witch one , i have to check all of them... For this just send me all your main list xml or if you prefer a part of them from the header to the first game of each list I'll hope that you don't have too many systems, and also find a solution for you.
arshesney Posted January 6, 2015 Posted January 6, 2015 Here is the xml that was blocking the database creation: <?xml version="1.0"?> <menu> <game name="18wheelr" index="true" image="1"> <description>18 Wheeler - American Pro Trucker</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2000</year> <genre>Driving</genre> </game> <!-- Load Decrypted not working in demul 0.5.6 <game name="akatsukibk" index="" image=""> <description>Akatsuki Bk Ausf Achse</description> <cloneof></cloneof> <manufacturer>Subtle Style</manufacturer> <year>2008</year> <genre>Fighting</genre> </game> --> <game name="Akatsuki Bk Ausf Achse" index="" image=""> <description>Akatsuki Bk Ausf Achse</description> <cloneof></cloneof> <manufacturer>Subtle Style</manufacturer> <year>2008</year> <genre>Fighting</genre> <exe>NaomiMakaron</exe> </game> <game name="alpiltdx" index="" image=""> <description>Airline Pilots Deluxe</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Driving</genre> </game> <game name="azumanga" index="" image=""> <description>Azumanga Daioh Puzzle Bobble</description> <cloneof></cloneof> <manufacturer>Moss (Taito license)</manufacturer> <year>2002</year> <genre></genre> </game> <game name="bdrdown" index="" image=""> <description>Border Down</description> <cloneof></cloneof> <manufacturer>G-Rev</manufacturer> <year>2004</year> <genre>Shooter</genre> </game> <game name="cfield" index="" image=""> <description>Chaos Field</description> <cloneof></cloneof> <manufacturer>Able</manufacturer> <year>2004</year> <genre>Shooter</genre> </game> <game name="chocomk" index="" image=""> <description>Musapey's Choco Marker</description> <cloneof></cloneof> <manufacturer>Ecole Software</manufacturer> <year>2002</year> <genre>Puzzle</genre> </game> <game name="cleoftp" index="" image=""> <description>Cleopatra Fortune Plus</description> <cloneof></cloneof> <manufacturer>Altron</manufacturer> <year>2002</year> <genre>Puzzle</genre> </game> <!-- Boots to black screen <game name="crackndj" index="" image=""> <description>Crackin' DJ</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2000</year> <genre>Rhythm</genre> </game> --> <game name="crzytaxi" index="" image=""> <description>Crazy Taxi</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Driving</genre> </game> <!-- Transparency issues in demul 0.5.6 <game name="csmash" index="" image=""> <description>Cosmic Smash</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Breakout</genre> </game> --> <game name="Cosmic Smash (Rev A)" index="" image=""> <description>Cosmic Smash</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Breakout</genre> <exe>NaomiMakaron</exe> </game> <game name="cspike" index="" image=""> <description>Cannon Spike / Gun Spike (JPN)</description> <cloneof></cloneof> <manufacturer>Psikyo / Capcom</manufacturer> <year>2000</year> <genre>Shooter</genre> </game> <!-- Buggy sprites and sound delays in demul 0.5.6 <game name="cvsgd" index="" image=""> <description>Capcom Vs. SNK Millenium Fight 2000 Pro</description> <cloneof></cloneof> <manufacturer>Capcom / SNK</manufacturer> <year>2001</year> <genre>Fighter</genre> </game> --> <game name="Capcom vs SNK Millenium Fight 2000 Pro" index="" image=""> <description>Capcom Vs. SNK Millenium Fight 2000 Pro</description> <cloneof></cloneof> <manufacturer>Capcom / SNK</manufacturer> <year>2001</year> <genre>Fighter</genre> <exe>NaomiMakaron</exe> </game> <!-- Sound delays in demul 0.5.6 <game name="cvs2gd" index="true" image="c"> <description>Capcom vs SNK 2 Millionaire Fighting 2001</description> <cloneof></cloneof> <manufacturer>Capcom / SNK</manufacturer> <year>2001</year> <genre>Fighter</genre> </game> --> <game name="Capcom vs SNK 2 Millionaire Fighting 2001" index="true" image="c"> <description>Capcom Vs. SNK 2 Millionaire Fighting 2001</description> <cloneof></cloneof> <manufacturer>Capcom / SNK</manufacturer> <year>2001</year> <genre>Fighter</genre> <exe>NaomiMakaron</exe> </game> <!-- Needs USA Naomi Bios, need to read japanese but can't start a game due to an error, think it's card read/write error <game name="derbyoc" index="" image=""> <description>Derby Owners Club</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Sports</genre> </game> --> <!-- Needs USA Naomi Bios, error Card reader/writer no response <game name="derbyoc2" index="" image=""> <description>Derby Owners Club II</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Sports</genre> </game> --> <!-- Needs USA Naomi Bios, error Card reader/writer no response <game name="derbyocw" index="" image=""> <description>Derby Owners Club World Edition (Rev C) (JPN, USA, EXP, KOR, AUS)</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Sports</genre> </game> --> <!-- this game has a 30-sec wait on load, cannot fix. 1 sec sound lag & missing textures in demul 0.5.6 --> <game name="doa2m" index="" image=""> <description>Dead or Alive 2 Millennium</description> <cloneof>doa2</cloneof> <manufacturer>Tecmo</manufacturer> <year>2000</year> <genre>Fighter</genre> <exe>NaomiMakaron</exe> </game> <!-- No analog control support in makaron and buttons don't respond --> <game name="dybb99" index="" image=""> <description>World Series '99 / Dynamite Baseball '99 (JPN)</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Sports</genre> </game> <!-- No error, just reboots in makaron 12-5--> <game name="dybbnao" index="" image=""> <description>Dynamite Baseball NAOMI</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1998</year> <genre>Sports</genre> </game> <!-- Uses mouse as trackball and only works with gpuOgl video plugin in demul 0.5.6--> <game name="dygolf" index="" image=""> <description>Virtua Golf / Dynamic Golf (JPN)</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Sports</genre> </game> <!-- Load Decrypted not working in demul 0.5.6 <game name="dnmitdekex" index="" image=""> <description>Dynamite Deka Ex</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2006</year> <genre>Beat 'Em Up</genre> </game> --> <game name="Dynamite Deka Ex" index="" image=""> <description>Dynamite Deka Ex</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2006</year> <genre>Beat 'Em Up</genre> <exe>NaomiMakaron</exe> </game> <!-- Naomi Multi System not supported in makaron or demul yet <game name="f355" index="true" image="f"> <description>Ferrari F355 Challenge</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Driving</genre> </game> --> <!-- Naomi Multi System not supported in makaron or demul yet <game name="f355twin" index="" image=""> <description>Ferrari F355 Challenge (Twin)</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Driving</genre> </game> --> <!-- Naomi Multi System not supported in makaron or demul yet <game name="f355twn2" index="" image=""> <description>Ferrari F355 Challenge 2 (Twin)</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Driving</genre> </game> --> <!-- Sound less laggy in Makaron 12-5 then demul 0.5.6 --> <game name="ggram2" index="true" image="g"> <description>Giant Gram</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Sports</genre> <exe>NaomiMakaron</exe> </game> <!-- Crashes on launch with makaron 12-5, works fine in demul 0.5.6 with random graphic glitches --> <game name="ggx" index="" image=""> <description>Guilty Gear X</description> <cloneof></cloneof> <manufacturer>Arc System Works</manufacturer> <year>2000</year> <genre>Fighter</genre> </game> <game name="ggxx" index="" image=""> <description>Guilty Gear XX</description> <cloneof></cloneof> <manufacturer>Arc System Works</manufacturer> <year>2002</year> <genre>Fighter</genre> </game> <game name="ggxxac" index="" image=""> <description>Guilty Gear XX Accent Core</description> <cloneof></cloneof> <manufacturer>Arc System Works</manufacturer> <year>2006</year> <genre>Fighter</genre> </game> <game name="ggxxrl" index="" image=""> <description>Guilty Gear XX Reload</description> <cloneof></cloneof> <manufacturer>Arc System Works</manufacturer> <year>2003</year> <genre>Fighter</genre> </game> <game name="ggxxsla" index="" image=""> <description>Guilty Gear XX Slash</description> <cloneof></cloneof> <manufacturer>Arc System Works</manufacturer> <year>2005</year> <genre>Fighter</genre> </game> <!-- Boots to black screen in makaron 12-5 and demul 0.5.6 <game name="gram2000" index="" image=""> <description>Giant Gram 2000</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2000</year> <genre>Sports</genre> </game> --> <game name="gundmxgd" index="" image=""> <description>Mobile Suit Gundam: Federation VS Zeon DX</description> <cloneof></cloneof> <manufacturer>Capcom</manufacturer> <year>2001</year> <genre>Shooter</genre> </game> <game name="gunsur2" index="" image=""> <description>Gun Survivor 2: Bio Hazard Code Veronica</description> <cloneof></cloneof> <manufacturer>Capcom / Namco</manufacturer> <year>2001</year> <genre>Shooter</genre> </game> <game name="gwing2" index="" image=""> <description>Giga Wing 2</description> <cloneof></cloneof> <manufacturer>Takumi / Capcom</manufacturer> <year>2000</year> <genre>Shooter</genre> </game> <!-- Heavy graphic and sound lag in demul 0.5.6 --> <game name="hmgeo" index="true" image="h"> <description>Heavy Metal Geomatrix</description> <cloneof></cloneof> <manufacturer>Capcom</manufacturer> <year>2001</year> <genre>Fighter</genre> <exe>NaomiMakaron</exe> </game> <!-- Vertical Game, has 300 second countdown, no way to disable it--> <game name="ikaruga" index="" image=""> <description>Ikaruga</description> <cloneof></cloneof> <manufacturer>Treasure</manufacturer> <year>2001</year> <genre>Shooter</genre> </game> <!-- Lever control (lasso) uses player2 digital controls --> <game name="jambo" index="true" image="j"> <description>Jambo! Safari (JPN, USA, EXP, KOR, AUS)</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Driving</genre> </game> <!-- Horrible sound lag in demul 0.5.6 <game name="jingystm" index="" image=""> <description>Jingi Storm - The Arcade</description> <cloneof></cloneof> <manufacturer>Atrativa Japan</manufacturer> <year>2005</year> <genre>Fighter</genre> </game> --> <game name="Jingi Storm - The Arcade" index="" image=""> <description>Jingi Storm - The Arcade</description> <cloneof></cloneof> <manufacturer>Atrativa Japan</manufacturer> <year>2005</year> <genre>Fighter</genre> <exe>NaomiMakaron</exe> </game> <!-- Vertical Game --> <game name="karous" index="true" image="k"> <description>Karous</description> <cloneof></cloneof> <manufacturer>Milestone</manufacturer> <year>2006</year> <genre>Shooter</genre> </game> <!-- Needs Export bios, I/O BD is not connected to Naomi BD error <game name="kick4csh" index="" image=""> <description>Kick '4' Cash</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2004</year> <genre></genre> </game> --> <game name="kurucham" index="" image=""> <description>Kurukuru Chameleon</description> <cloneof></cloneof> <manufacturer>Able</manufacturer> <year>2006</year> <genre>Puzzle</genre> </game> <!-- Vertical Game, no support in demul 0.5.6 yet & can't load decrypted roms--> <game name="mamonoro" index="true" image="m"> <description>Mamonoro</description> <cloneof></cloneof> <manufacturer>G.rev / Gulti</manufacturer> <year>2008</year> <genre>Shooter</genre> <exe>NaomiVertical</exe> </game> <!-- Bad sprite bugs in demul 0.5.6 <game name="meltyb" index="" image=""> <description>Melty Blood Act Cadenza Ver B</description> <cloneof></cloneof> <manufacturer>Ecole Software</manufacturer> <year>2006</year> <genre>Fighter</genre> </game> --> <game name="Melty Blood Act Cadenza Ver B" index="" image=""> <description>Melty Blood Act Cadenza Ver B</description> <cloneof></cloneof> <manufacturer>Ecole Software</manufacturer> <year>2006</year> <genre>Fighter</genre> <exe>NaomiMakaron</exe> </game> --> <game name="moeru" index="" image=""> <description>Burning Casino / Moeru Casinyo (JPN)</description> <cloneof></cloneof> <manufacturer>Altron</manufacturer> <year>2002</year> <genre>Casino</genre> </game> <!-- No Jamma support in Makaron yet, works in demul --> <game name="monkeyba" index="" image=""> <description>Monkey Ball</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Maze</genre> </game> <!-- Bad sprite bugs in demul 0.5.6 <game name="mvsc2" index="true" image="m"> <description>Marvel vs. Capcom 2</description> <cloneof></cloneof> <manufacturer>Capcom</manufacturer> <year>2000</year> <genre>Fighter</genre> </game> --> <game name="Marvel vs. Capcom 2" index="true" image="m"> <description>Marvel vs. Capcom 2</description> <cloneof></cloneof> <manufacturer>Capcom</manufacturer> <year>2000</year> <genre>Fighter</genre> <exe>NaomiMakaron</exe> </game> <!-- Makaron 12-5 boots jp text, unknown error, maybe missing controller, demul 0.5.6 only boots black screen <game name="otrigger" index="true" image="o"> <description>OutTrigger</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Shooter</genre> </game> --> <!-- Bad sound lag in demul 0.5.6 --> <game name="pjustic" index="" image=""> <description>Project Justice / Moero Justice Gakuen (JPN)</description> <cloneof></cloneof> <manufacturer>Capcom</manufacturer> <year>2000</year> <genre>Fighter</genre> <exe>NaomiMakaron</exe> </game> <!-- No inputs work in makaron --> <game name="pstone" index="" image=""> <description>Power Stone</description> <cloneof></cloneof> <manufacturer>Capcom</manufacturer> <year>1999</year> <genre>Fighter</genre> </game> <!-- Sound keeps cutting out in demul 0.5.6 --> <game name="pstone2" index="" image=""> <description>Power Stone 2</description> <cloneof></cloneof> <manufacturer>Capcom</manufacturer> <year>2000</year> <genre>Fighter</genre> <exe>NaomiMakaron</exe> </game> <!-- Vertical Game --> <game name="psyvar2" index="" image=""> <description>Psyvariar 2 - The Will To Fabricate</description> <cloneof></cloneof> <manufacturer>G-Rev</manufacturer> <year>2003</year> <genre>Shooter</genre> </game> <game name="puyofev" index="" image=""> <description>Puyo Puyo Fever</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2003</year> <genre>Puzzle</genre> </game> <!-- Need to know japanese to play <game name="qmegamis" index="true" image="q"> <description>Quiz Ah Megamisama</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2000</year> <genre>Quiz</genre> </game> --> <!-- Vertical Game, crashes demul, but works in makaron, Need to know japanese to play <game name="Quiz Keitai Q mode" index="" image=""> <description>Quiz Keitai Q mode</description> <cloneof></cloneof> <manufacturer>Amedio (Taito license)</manufacturer> <year>2002</year> <genre>Quiz</genre> <exe>NaomiVertical</exe> </game> --> <!-- Vertical Game --> <game name="radirgy" index="true" image="r"> <description>Radirgy</description> <cloneof></cloneof> <manufacturer>Milestone</manufacturer> <year>2005</year> <genre>Shooter</genre> </game> <!-- demul 0.5.6 does not support this game yet & load decrypted not working <game name="radirgnoa" index="true" image="r"> <description>Radirgy Noir</description> <cloneof></cloneof> <manufacturer>Milestone</manufacturer> <year>2009</year> <genre>Shooter</genre> </game> --> <game name="Radirgy Noir" index="true" image="r"> <description>Radirgy Noir</description> <cloneof></cloneof> <manufacturer>Milestone</manufacturer> <year>2009</year> <genre>Shooter</genre> <exe>NaomiMakaron</exe> </game> <!-- Difficult to control with analog sticks in demul 0.5.6, no analog sticks in makaron 12-5 --> <game name="samba" index="true" image="s"> <description>Samba De Amigo</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Rhythm</genre> </game> <!-- This is latest version --> <game name="senkosp" index="" image=""> <description>Senko No Ronde Special</description> <cloneof></cloneof> <manufacturer>G-Rev</manufacturer> <year>2005</year> <genre>Shooter</genre> </game> <!-- Bad sprite bugs in demul 0.5.6 <game name="sfz3ugd" index="" image=""> <description>Street Fighter Zero 3 Upper</description> <cloneof></cloneof> <manufacturer>Capcom</manufacturer> <year>2001</year> <genre>Fighter</genre> </game> --> <game name="Street Fighter Zero 3 Upper" index="" image=""> <description>Street Fighter Zero 3 Upper</description> <cloneof></cloneof> <manufacturer>Capcom</manufacturer> <year>2001</year> <genre>Fighter</genre> <exe>NaomiMakaron</exe> </game> <game name="sgtetris" index="" image=""> <description>Sega Tetris</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Puzzle</genre> </game> <!-- Vertical Game --> <game name="shikgam2" index="" image=""> <description>The Castle of Shikigami II / Shikigami No Shiro II (JPN)</description> <cloneof></cloneof> <manufacturer>Alpha System</manufacturer> <year>2003</year> <genre>Shooter</genre> </game> <!-- I/O BD connected to Naomi BD does not does not fulfill the game specs in makaron 12-5 and demul 0.5.6 <game name="shootpl" index="" image=""> <description>Shootout Pool (JPN) / Shootout Pool Prize</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Sports</genre> </game> --> <!-- Vertical Game, not supported in demul 0.5.6 & load decrypted not working <game name="shtnglv2k7" index="" image=""> <description>Shooting Love 2007</description> <cloneof></cloneof> <manufacturer>Triangle Service</manufacturer> <year>2007</year> <genre>Shooter</genre> </game> --> <game name="Shooting Love 2007" index="" image=""> <description>Shooting Love 2007</description> <cloneof></cloneof> <manufacturer>Triangle Service</manufacturer> <year>2007</year> <genre>Shooter</genre> <exe>NaomiVertical</exe> </game> <!-- Bad sound lag in demul 0.5.6 <game name="slashout" index="" image=""> <description>Slashout</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2000</year> <genre>Fighter</genre> </game> --> <game name="Slashout" index="" image=""> <description>Slashout</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2000</year> <genre>Fighter</genre> <exe>NaomiMakaron</exe> </game> <!-- Boots to black screen in makaron 12-5 and demul 0.5.6 <game name="smarinef" index="" image=""> <description>Sega Marine Fishing</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2000</year> <genre>Sports</genre> </game> --> <!-- Makaron 12-5 has no support for analog controls so you can't swing bat --> <game name="smlg99" index="" image=""> <description>Super Major League '99</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Sports</genre> </game> <!-- Graphic and sound lag in demul 0.5.6 <game name="spawn" index="" image=""> <description>Spawn - In the Demon's Hand</description> <cloneof></cloneof> <manufacturer>Capcom</manufacturer> <year>1999</year> <genre>Shooter</genre> </game> --> <game name="Spawn" index="" image=""> <description>Spawn - In the Demon's Hand</description> <cloneof></cloneof> <manufacturer>Capcom</manufacturer> <year>1999</year> <genre>Shooter</genre> <exe>NaomiMakaron</exe> </game> <!-- Crashes in makaron 12-5, plays fine in 12-3 and demul 0.5.6 --> <game name="spkrbtl" index="" image=""> <description>Spikers Battle</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Sports</genre> </game> <!-- Graphic and sound lag in demul 0.5.6 <game name="sprtjam" index="" image=""> <description>Sports Jam</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2000</year> <genre>Sports</genre> </game> --> <game name="Sports Jam" index="" image=""> <description>Sports Jam</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2000</year> <genre>Sports</genre> <exe>NaomiMakaron</exe> </game> <!-- Graphic missing and distorted on tiles in demul 0.5.6 <game name="ss2005a" index="" image=""> <description>Super Shanghai 2005</description> <cloneof></cloneof> <manufacturer>Starfish</manufacturer> <year>2005</year> <genre>Puzzle</genre> </game> --> <game name="Super Shanghai 2005 (Rev A)" index="" image=""> <description>Super Shanghai 2005</description> <cloneof></cloneof> <manufacturer>Starfish</manufacturer> <year>2005</year> <genre>Puzzle</genre> <exe>NaomiMakaron</exe> </game> <!-- No Analog support in makaron --> <game name="sstrkfgt" index="" image=""> <description>Sega Strike Fighter</description> <cloneof></cloneof> <manufacturer>Wow Entertainment</manufacturer> <year>2000</year> <genre>Simulation</genre> </game> <game name="takoron" index="" image=""> <description>Noukone Puzzle Takoron</description> <cloneof></cloneof> <manufacturer>Compile</manufacturer> <year>2006</year> <genre>Puzzle</genre> </game> <!-- Graphic and sound lag in demul 0.5.6 <game name="tetkiwam" index="true" image="t"> <description>Tetris Kiwamemichi</description> <cloneof></cloneof> <manufacturer>Success</manufacturer> <year>2004</year> <genre>Puzzle</genre> </game> --> <game name="Tetris Kiwamemichi" index="true" image="t"> <description>Tetris Kiwamemichi</description> <cloneof></cloneof> <manufacturer>Success</manufacturer> <year>2004</year> <genre>Puzzle</genre> <exe>NaomiMakaron</exe> </game> <game name="toyfight" index="" image=""> <description>Toy Fighter</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Fighter</genre> </game> <!-- Vertical Game, some transparency issues noticable on stage 1 on both makaron 12-5 & demul 0.5.6--> <game name="trizeal" index="" image=""> <description>Trizeal</description> <cloneof></cloneof> <manufacturer>Taito</manufacturer> <year>2004</year> <genre>Shooter</genre> </game> <!-- Vertical Game, makaron 12-5 has 5 sec control lag, demul 0.5.6 plays with some graphic glitches, using demul cart version for now --> <game name="trgheart" index="" image=""> <description>Trigger Heart Exelica</description> <cloneof></cloneof> <manufacturer>Warashi</manufacturer> <year>2005</year> <genre>Shooter</genre> </game> <!-- Vertical Game --> <game name="undefeat" index="true" image="u"> <description>Under Defeat</description> <cloneof></cloneof> <manufacturer>G-Rev</manufacturer> <year>2005</year> <genre>Shooter</genre> </game> <!-- Some graphic/sound issues in makaron --> <game name="vathlete" index="true" image="v"> <description>Virtua Athletics / Virtua Athlete (JPN)</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2002</year> <genre>Sports</genre> </game> <!-- Loud buzz only at game start on makaron 12-5, demul has severe graphic glitches in menus --> <game name="virnba" index="" image=""> <description>Virtua NBA</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2000</year> <genre>Sports</genre> </game> <!-- Crashes makaron 12-5 and boots to black screen in demul 0.5.6 <game name="vs2_2k" index="" image=""> <description>Virtua Striker 2 Ver. 2000</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Sports</genre> </game> --> <!-- makaron 12-5 graphic glitch will cause siezures --> <game name="vtennis" index="true" image="p"> <description>Virtua Tennis / Power Smash (JPN)</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Sports</genre> </game> <!-- makaron has small graphic glitches, but still tolerable enough to play --> <game name="vtennis2" index="" image=""> <description>Virtua Tennis 2 / Power Smash 2 (JPN)</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Sports</genre> </game> <!-- No analog control support in makaron 12-5 and buttons don't respond, demul 0.5.6 is missing half the textures <game name="wsbbgd" index="" image=""> <description>World Series Baseball / Super Major League (JPN)</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Sports</genre> </game> --> <game name="wwfroyal" index="" image=""> <description>WWF Royal Rumble</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2000</year> <genre>Sports</genre> </game> <!-- No response from any button in makaron 12-5 --> <game name="zombrvn" index="true" image="z"> <description>Zombie Revenge</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Fighter</genre> </game> <!--***************************************************** ******************** Light Gun games ******************** ******************************************************--> <game name="confmiss" index="" image=""> <description>Confidential Mission</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Shooter/Gun</genre> </game> <game name="deathcox" index="" image=""> <description>Death Crimson OX</description> <cloneof></cloneof> <manufacturer>Ecole</manufacturer> <year>2000</year> <genre>Shooter/Gun</genre> </game> <game name="hotd2" index="" image=""> <description>House of the Dead 2</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Shooter/Gun</genre> </game> <game name="lupinsho" index="" image=""> <description>Lupin The Third - The Shooting</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Shooter/Gun</genre> </game> <game name="mok" index="" image=""> <description>Maze of the Kings, The</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2002</year> <genre>Shooter/Gun</genre> </game> <!--***************************************************** *********************Keyboard games********************** ******************************************************--> <!-- Does not type correct characters on a US keyboard, need japanese <game name="keyboard" index="true" image="l"> <description>La Keyboardxyu</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Quiz</genre> </game> --> <game name="luptype" index="" image=""> <description>Lupin The Third - The Typing</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2002</year> <genre>Typing</genre> </game> <game name="totd" index="" image=""> <description>The Typing of the Dead</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2000</year> <genre>Typing</genre> </game> <!--***************************************************** ********************** Sega Naomi 2 ********************* ******************************************************--> <game name="beachspi" index="true" image="b"> <description>Beach Spikers</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2002</year> <genre>Sports</genre> </game> <!-- Crashes after a minute or so in demul 0.5.6 <game name="clubkrte" index="" image=""> <description>Club Kart: European Session</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2002</year> <genre>Driving</genre> </game> --> <!-- Not supported in demul 0.5.6 <game name="initdv2j" index="" image=""> <description>Initial D : Arcade Stage Ver. 2</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2002</year> <genre>Driving</genre> </game> --> <!-- Not supported in demul 0.5.6 <game name="initdv3j" index="" image=""> <description>Initial D : Arcade Stage Ver. 3 (Rev </description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2004</year> <genre>Driving</genre> </game> --> <!-- Only booted once, otherwise freezes at Sega logo in demul 0.5.6 <game name="initdexp" index="" image=""> <description>Initial D Arcade Stage (Export)</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2002</year> <genre>Driving</genre> </game> --> <game name="initd" index="" image=""> <description>Initial D Arcade Stage</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2002</year> <genre>Driving</genre> </game> <!-- Boots to black screen in demul 0.5.6 <game name="vf4cart" index="" image=""> <description>Virtua Fighter 4 (Cartridge)</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Fighter</genre> </game> --> <!-- Severe Graphics and sound issues in demul 0.5.6, "playable" but not worth it <game name="vf4" index="" image=""> <description>Virtua Fighter 4</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Fighter</genre> </game> --> <!-- Severe Graphics and sound issues in demul 0.5.6, "playable" but not worth it <game name="vf4b" index="" image=""> <description>Virtua Fighter 4 (Rev </description> <cloneof>vf4</cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Fighter</genre> </game> --> <!-- Severe Graphics and sound issues in demul 0.5.6, "playable" but not worth it <game name="vf4c" index="" image=""> <description>Virtua Fighter 4 (Rev C)</description> <cloneof>vf4</cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Fighter</genre> </game> --> <!-- crashes on start in demul 0.5.6 <game name="vf4evoct" index="" image=""> <description>Virtua Fighter 4 Evolution (Cartridge)</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Fighter</genre> </game> --> <!-- crashes during intro in demul 0.5.6 <game name="vf4evoa" index="" image=""> <description>Virtua Fighter 4 Evolution (Rev A)</description> <cloneof>vf4evo</cloneof> <manufacturer>Sega</manufacturer> <year>2002</year> <genre>Fighter</genre> </game> --> <!-- Severe Graphics and sound issues in demul 0.5.6, "playable" but not worth it <game name="vf4evo" index="" image=""> <description>Virtua Fighter 4 Evolution (Rev </description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2002</year> <genre>Fighter</genre> </game> --> <!-- Severe Graphics and sound issues in demul 0.5.6, "playable" but not worth it <game name="vf4tuneda" index="" image=""> <description>Virtua Fighter 4 Final Tuned (Rev A)</description> <cloneof>vf4tuned</cloneof> <manufacturer>Sega</manufacturer> <year>2004</year> <genre>Fighter</genre> </game> --> <!-- Severe Graphics and sound issues in demul 0.5.6, "playable" but not worth it <game name="vf4tunedd" index="" image=""> <description>Virtua Fighter 4 Final Tuned (Rev D)</description> <cloneof>vf4tuned</cloneof> <manufacturer>Sega</manufacturer> <year>2004</year> <genre>Fighter</genre> </game> --> <!-- Severe Graphics and sound issues in demul 0.5.6, "playable" but not worth it <game name="vf4tuned" index="" image=""> <description>Virtua Fighter 4 Final Tuned (Rev F)</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2004</year> <genre>Fighter</genre> </game> --> <!-- Some graphic issues but locks up after you score a goal in demul 0.5.6, "playable" but not worth it <game name="vstrik3c" index="" image=""> <description>Virtua Striker 3 (Cart)</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Sports/Soccer</genre> </game> --> <!-- Some graphic issues but locks up after you score a goal in demul 0.5.6, "playable" but not worth it <game name="vstrik3" index="" image=""> <description>Virtua Striker 3</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Sports/Soccer</genre> </game> --> <!-- Somewhat playable but must disable multigpu for lagfree response from controls in demul 0.5.6. --> <game name="wldrider" index="true" image="w"> <description>Wild Riders</description> <cloneof></cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Driving</genre> </game> <!--***************************************************** ********************* Mahjong Games ********************* ******************************************************--> <!-- Mahjong games suck and should not be on the list (they work though) <game name="shangril" index="" image=""> <description>Dengen Tenshi Taisen Janshi Shangri-la</description> <cloneof></cloneof> <manufacturer>Marvelous Ent.</manufacturer> <year>1999</year> <genre>Mahjong</genre> </game> <game name="suchie3" index="true" image="i"> <description>Idol Janshi Suchie-Pai 3</description> <cloneof></cloneof> <manufacturer>Jaleco</manufacturer> <year>1999</year> <genre>Mahjong</genre> </game> <game name="usagui" index="" image=""> <description>Usagi - Yamashiro Mahjong Hen</description> <cloneof></cloneof> <manufacturer>Warashi / Taito / Mahjong Kobo</manufacturer> <year>2003</year> <genre>Mahjong</genre> </game> --> <!--******************************************************** *********************** Clones ***************************** ************************************************************ <game name="alpilota" index="true" image="a"> <description>Airline Pilots (Rev A)</description> <cloneof>alpiltdx</cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Driving</genre> </game> <game name="capsnk" index="" image=""> <description>Capcom Vs. SNK Millennium Fight 2000</description> <cloneof></cloneof> <manufacturer>Capcom / SNK</manufacturer> <year>2000</year> <genre>Fighter</genre> </game> <game name="capsnka" index="" image=""> <description>Capcom Vs. SNK Millennium Fight 2000 (000804 JPN, USA, EXP, KOR, AUS)</description> <cloneof>capsnk</cloneof> <manufacturer>Capcom / SNK</manufacturer> <year>2000</year> <genre>Fighter</genre> </game> <game name="csmasho" index="" image=""> <description>Cosmic Smash (JPN, USA, EXP, KOR, AUS) (original)</description> <cloneof>csmash</cloneof> <manufacturer>Sega</manufacturer> <year>2001</year> <genre>Breakout</genre> </game> <game name="doa2" index="true" image="d"> <description>Dead or Alive 2</description> <cloneof></cloneof> <manufacturer>Tecmo</manufacturer> <year>1999</year> <genre>Fighter</genre> </game> <game name="gundmgd" index="" image=""> <description>Mobile Suit Gundam: Federation VS Zeon (GDL-0001)</description> <cloneof></cloneof> <manufacturer>Capcom</manufacturer> <year>2001</year> <genre>Shooter</genre> </game> <game name="hotd2o" index="" image=""> <description>House of the Dead 2 (original)</description> <cloneof>hotd2</cloneof> <manufacturer>Sega</manufacturer> <year>1999</year> <genre>Shooter/Gun</genre> </game> <game name="meltybld" index="" image=""> <description>Melty Blood Act Cadenza Ver A (Rev C)</description> <cloneof></cloneof> <manufacturer>Ecole Software</manufacturer> <year>2005</year> <genre>Fighter</genre> </game> <game name="meltyba" index="" image=""> <description>Melty Blood Act Cadenza Ver B (Rev A) (GDL-0039A)</description> <cloneof>meltyb</cloneof> <manufacturer>Ecole Software</manufacturer> <year>2006</year> <genre>Fighter</genre> </game> <game name="senko" index="" image=""> <description>Senko No Ronde NEW ver. (Rev A) (GDL-0030A)</description> <cloneof></cloneof> <manufacturer>G-Rev</manufacturer> <year>2005</year> <genre>Shooter</genre> </game> <game name="senkoo" index="" image=""> <description>Senko No Ronde (GDL-0030)</description> <cloneof>senko</cloneof> <manufacturer>G-Rev</manufacturer> <year>2005</year> <genre>Shooter</genre> </game> <game name="ss2005" index="" image=""> <description>Super Shanghai 2005 (GDL-0031)</description> <cloneof></cloneof> <manufacturer>Starfish</manufacturer> <year>2005</year> <genre>Puzzle</genre> </game> <game name="virnbao" index="" image=""> <description>Virtua NBA (JPN, USA, EXP, KOR, AUS) (original)</description> <cloneof>virnba</cloneof> <manufacturer>Sega</manufacturer> <year>2000</year> <genre>Sports/Basketball</genre> </game> <game name="Melty Blood Act Cadenza Ver B (Rev A)" index="" image=""> <description>Melty Blood Act Cadenza Ver B (Rev A)</description> <cloneof>meltyb</cloneof> <manufacturer>Ecole Software</manufacturer> <year>2006</year> <genre>Fighter</genre> </game> <game name="Mobile Suit Gundam - Federation VS Zeon" index="" image=""> <description>Mobile Suit Gundam: Federation VS Zeon</description> <cloneof></cloneof> <manufacturer>Capcom</manufacturer> <year>2001</year> <genre>Shooter</genre> </game> <game name="Senko No Ronde NEW Ver" index="" image=""> <description>Senko No Ronde NEW Ver.</description> <cloneof></cloneof> <manufacturer>G-Rev</manufacturer> <year>2005</year> <genre>Shooter</genre> </game> --> </menu>
ninja2bceen Posted January 6, 2015 Posted January 6, 2015 How do you know which one blocked it? Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
arshesney Posted January 6, 2015 Posted January 6, 2015 I used Process Monitor from Microsoft sysinternals suite, filtered by hypersearch.exe and noticed that the last opened file was naomi.xml, moved it out of the way and the database was succesfully created.
r0man0 Posted January 6, 2015 Author Posted January 6, 2015 Thank you arshesney for your xml , the problem of this xml was the info lines like <!-- information --> , i don't use this kind of information for my xml For better compatibility , i've made database creating skip those lines not really needed for hypersearch & hyperspin , i've also fixed the problem of Windows placement with screen changing resolution. You can re-add your xml ,delete your old Hypersearchdatabase.dat file and retry again, with this new fixed HyperSearch , it will be ok for you : http://hypermachine.free.fr/HyperSearch-fixed-v2.zip Ninja2bceen : try also this new fixed hypersearch , maybe it was the same problem than arshesney. edit : I've updated main post with new version package to download and instructions
ninja2bceen Posted January 7, 2015 Posted January 7, 2015 i'll be honest, I'm becoming a little frustrated. when I loaded the exe, I was able to select everything except within the lang dropdown I can't select anything other than English (fortunately I can speak that lang ;-* also I can't select anything from the list field dropdown, it just keeps displaying item list when you try and select from the dropdown. So my work around was to use an old version of hypersearch to create a ini file, then override the old hypersearch with this new version. I fired the new version up and I still get the hang at the same old place. I'm on windows 7 64 bit if that means anything Can you create a log file to see whats making the hang happen? I'm not familiar nor comfy with the software mentioned above to figure out where the hang is. I will say though that my xml files don't have any notes in them. They all follow this format below and the main menu looks like the below as well regular xmls <?xml version="1.0"?> <menu> <header> <listname>X</listname> <lastlistupdate>06/08/2013</lastlistupdate> <listversion>1.0 Ongoing</listversion> <exporterversion>HyperList XML Exporter Version 1.3 Copywrite © 2009-2011 William Strong</exporterversion> </header> <game name="X" index="" image=""> <description>X</description> <cloneof></cloneof> <crc></crc> <manufacturer></manufacturer> <year></year> <genre></genre> <rating></rating> <enabled></enabled> </game> </menu> main menu... <menu> <game name="XBMC"/> <game name="Comics"/> <game name="Help"/> <game name="MAME"/> </menu> Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
r0man0 Posted January 7, 2015 Author Posted January 7, 2015 hi , it seems to be more difficult for you than i expect , i understand you're worried about that. Hypersearch is a beta version and in order to increase compatibility your help is really usefull at this part of development. For the moment , no log file will be added. But with your comments i can define and change the problem. If you're still ok to test HyperSearch , download this new Hypersearch fixed executable : HyperSearch-fixed-v3.zip then delete Hypersearch.ini , and replace old HyperSearch.exe with the fixed one.
ninja2bceen Posted January 8, 2015 Posted January 8, 2015 Don't get me wrong, I really want this to work! I used the new file but it continues to hang at maybe 10% loading the databases now. Can you tell us exactly how this is working so I can troubleshoot? I have no idea what to tell you in terms of fixing the hang. The gui works now without error prior to getting to the loading database My root is on an external hard drive, could it be you only allow for c? Having a log file of simply just saying aae database found would be helpful so I can see where the hang is. What else do u need from me as this post probably isn't very helpful for you Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
r0man0 Posted January 8, 2015 Author Posted January 8, 2015 Don't get me wrong, I really want this to work! I used the new file but it continues to hang at maybe 10% loading the databases now.Can you tell us exactly how this is working so I can troubleshoot? I have no idea what to tell you in terms of fixing the hang. The gui works now without error prior to getting to the loading database My root is on an external hard drive, could it be you only allow for c? Having a log file of simply just saying aae database found would be helpful so I can see where the hang is. What else do u need from me as this post probably isn't very helpful for you Well , your hard drive installation can be witch one you want , doesn't matter. For the rest , i've PM you in order to not flood forum with all your xml.
ninja2bceen Posted January 10, 2015 Posted January 10, 2015 Testing.... Please fix these and thanks! You can't click with your mouse in both the fields, tab works though If you click all genre, all system, or all years to uncheck the checkbox you see more options appear but they aren't with a white background so it's hard to see the options When I click all favorites, it shows no results found, try a different keyword or options. I want this button to crest a favorites wheel. Basically I sant it to look at all my favorites from my system and create one ultimate favorites wheel. Outside of this request, how do you use the show all favorites button now? When I try and start a game from the results wheel, the emulator doesn't start or the game doesn't run, it just stays on the theme display. Notes that in hyperhq I have Pc game enabled and executionis set to normal When you select go a pop up comes. I see a chech box for select to select your games. Get rid of the check box to display games and just by default display it I want this on a complete hyperspin setup, therefore I don't like and I want to hide the param. Button and donate button on the digital keyboard. I don't want things to leave this screen. Can you put a donate link at the beginning of this post instead? I think most hyperspinners here will agree that it takes away from the arcade feel When you create a genre aka custom wheel, the game themes stick however the MP4 /flv and or png doesn't display in the video display within the theme. It's because the naming convention in the video folder of hypersearch is not correct. I'm finding this to sometimes work. So far I think the only ones that does display videos are Nintendo and Nintendo 64 and Super Nintendo and 3d0 and Atari jaguar and atari 2600 and atari 7800 and mame and swag game gear and sega genesis and sega master system and Atari Lynx and nec turbographix 16 and sega cd and sega dreamcasts and could be others. Some systems did work When you are selecting games for a new wheel, I see a list of games, it would be nice to have two columns here. One for the game name and one for the system name corresponding to the game. This is particularly helpful when you search all systems within the result genre results, and in the resultant genre xml, I see at the top hypersearch, your name and !!!!hypersearch!!!! As part of the wheel. I tried to delete it but it crashes the result genre wheel and hyperspin. If I add the info back to the result xml things work great but I'd like to not have that random item in the result wheel What's the option add do? How is that different from edit? When you select save in the dropdown I see a outline of an invisible dropdown that I can't click. I can tab to it but can't see what I type When selecting games, I sort of want to press and hold shift to highlight multiples quickly. Clicking each one works though! I'd like to use xpadder with this aka need to be able to run this through hyperlaunch within hyperhq I think. How can I do that? I had created a Zelda wheel then I had to edit it. When I did it actually deleted the wheel I created multiple wheels but they are not in alphabetical order Alphabetize games in wheel by system the by name Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
r0man0 Posted January 14, 2015 Author Posted January 14, 2015 You can't click with your mouse in both the fields, tab works though Left Click works well, but right click works not verywell because of Hypersearch status Windows alwaysontop --> not fixed If you click all genre, all system, or all years to uncheck the checkbox you see more options appear but they aren't with a white background so it's hard to see the options Color white was the problem --> fixed When I click all favorites, it shows no results found, try a different keyword or options. I want this button to crest a favorites wheel. Basically I sant it to look at all my favorites from my system and create one ultimate favorites wheel. Outside of this request, how do you use the show all favorites button now? Button All favorites checks all your favorites.txt on every systems and also on hypersearch , if you plan to save them on a genre list , select "save" before. When I try and start a game from the results wheel, the emulator doesn't start or the game doesn't run, it just stays on the theme display. Notes that in hyperhq I have Pc game enabled and executionis set to normal? Problem was the spaces on romName , space are replaced with another symbol --> fixed When you select go a pop up comes. I see a chech box for select to select your games. Get rid of the check box to display games and just by default display it? I prefer let this checkbox before copying results , because if there is too many results you can cancel or edit them ,instead of abord copying by exiting hyperspin then relaunch. I want this on a complete hyperspin setup, therefore I don't like and I want to hide the param. Button and donate button on the digital keyboard. I don't want things to leave this screen. Can you put a donate link at the beginning of this post instead? I think most hyperspinners here will agree that it takes away from the arcade feel Ok , now donate link button is on options panel , and an option key/button to open option panel can be defined. --> fixed When you create a genre aka custom wheel, the game themes stick however the MP4 /flv and or png doesn't display in the video display within the theme. It's because the naming convention in the video folder of hypersearch is not correct. I'm finding this to sometimes work. So far I think the only ones that does display videos are Nintendo and Nintendo 64 and Super Nintendo and 3d0 and Atari jaguar and atari 2600 and atari 7800 and mame and swag game gear and sega genesis and sega master system and Atari Lynx and nec turbographix 16 and sega cd and sega dreamcasts and could be others. Some systems did work I'm not sure but hypersearch use the option "Use Parent vids and themes" , you need to check this option. When you are selecting games for a new wheel, I see a list of games, it would be nice to have two columns here. One for the game name and one for the system name corresponding to the game. This is particularly helpful when you search all systems Ok , now you can select , sort and edit as you want : game's name , description , years , genre , clones .... --> fixed within the result genre results, and in the resultant genre xml, I see at the top hypersearch, your name and !!!!hypersearch!!!! As part of the wheel. I tried to delete it but it crashes the result genre wheel and hyperspin. If I add the info back to the result xml things work great but I'd like to not have that random item in the result wheel Ok , now the hypersearch's wheel will not appears on genre results , to relaunch hypersearch just come back to main wheel. --> fixed What's the option add do? How is that different from edit? Option "Add" is to add new results to an existing list genre , "Edit" can be used to change game's list order and/or delete games. When you select save in the dropdown I see a outline of an invisible dropdown that I can't click. I can tab to it but can't see what I type When you select "Save" a field appears , where you have to enter the name to use for the genre saved list. This field still appears when selecting another option , now --> fixed When selecting games, I sort of want to press and hold shift to highlight multiples quickly. Clicking each one works though! Well , now it is possible , i've added 2 more mapped buttons in order to emulate Ctrl+Click Left and Shift+Click Left with joystick --> fixed I'd like to use xpadder with this aka need to be able to run this through hyperlaunch within hyperhq I think. How can I do that? I use it also , that's why i've added in option panel program selection with parameters to launch on Hypersearch start and exit. For example : select the c:\program files\xpadder\xpadder.exe program , and type on param. the profil to launch : "c:\program files\xpadder\HyperSearch.xpadderprofile" I had created a Zelda wheel then I had to edit it. When I did it actually deleted the wheel "Edit" function have been updated , this problem don't seem existing. --> fixed I created multiple wheels but they are not in alphabetical order Genre list are now in alphabetical order. --> fixed Alphabetize games in wheel by system the by name Use "Edit" to sort games by alphabetical order by genre,description,year,game's name,manufacturer,clone... Here is the link for the Hypersearch v9.4 fixed (you need to delete Hypersearch.ini) : HyperSearch-fixed-v4.zip Thanks for your help, R0m@n0
ninja2bceen Posted January 15, 2015 Posted January 15, 2015 Thanks I'll try and test tonight Something I don't think I saw was when you create a genre and you select games currently it just shows names of games. Can we get a second column in this list to display the system name so that we can distinguish what games are what if there are similar names across multiple systems before. Adding it tot the wheel? Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted January 16, 2015 Posted January 16, 2015 Amazing friend, I'll test as soon as able Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted January 16, 2015 Posted January 16, 2015 Great improvements. Things that are still busted Unable to launch any game from the created wheels. When I click add all favorites I get an error saying change my criteria. I want to compile all my favorites from all my systems into one wheel. How do I do that? Videos as previously stated don't display for the systems mentioned above. Hyperhq looks fine. I'm finding this to sometimes work. So far I think the only ones that does NOT display videos are Nintendo and Nintendo 64 and Super Nintendo and 3d0 and Atari jaguar and atari 2600 and atari 7800 and mame and game gear and sega genesis and sega master system and Atari Lynx and nec turbographix 16 and sega cd and sega dreamcasts and could be others. The videos just arnt displaying in the video folder. When I created a new wheel called teenage mutant ninja turtles the wheel got created but the wheel art is missing for all games and themes and videos are not displaying. Other wheels are fine maybe the name is too long? How do I utilize xpadder? I get you want my to add xpadder exe to start up option here but how do I get it to load a custom control setting when this runs as an executable from hyperspin and not through hyperlaunch. How do you get the huperspin profile to come back after you close hyperseach I'd like to add multiple system wheel into one. For example, all handheld games. I think you should be able to search amd add with keywords as blank and allow to select your systems. If no keywords then by default display complete wheel Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
r0man0 Posted January 17, 2015 Author Posted January 17, 2015 Great improvements. Things that are still bustedUnable to launch any game from the created wheels. When I click add all favorites I get an error saying change my criteria. I want to compile all my favorites from all my systems into one wheel. How do I do that? Videos as previously stated don't display for the systems mentioned above. Hyperhq looks fine. I'm finding this to sometimes work. So far I think the only ones that does NOT display videos are Nintendo and Nintendo 64 and Super Nintendo and 3d0 and Atari jaguar and atari 2600 and atari 7800 and mame and game gear and sega genesis and sega master system and Atari Lynx and nec turbographix 16 and sega cd and sega dreamcasts and could be others. The videos just arnt displaying in the video folder. When I created a new wheel called teenage mutant ninja turtles the wheel got created but the wheel art is missing for all games and themes and videos are not displaying. Other wheels are fine maybe the name is too long? How do I utilize xpadder? I get you want my to add xpadder exe to start up option here but how do I get it to load a custom control setting when this runs as an executable from hyperspin and not through hyperlaunch. How do you get the huperspin profile to come back after you close hyperseach I'd like to add multiple system wheel into one. For example, all handheld games. I think you should be able to search amd add with keywords as blank and allow to select your systems. If no keywords then by default display complete wheel I've got the same problem when i search for tmnt , i've recompiled exe , and this error has disapeared , maybe was the same for video -> need to test new version fixed For xpadder : to load a profile when hypersearch start : select xpadder.exe then on param : type "Fullpathofprofile\nameOfYourProfile.xpadderprofile" ---> don't forget the " " same thing to launch a profile on exit. The only limit for search result is at least 1 filter activated (game keyword or manufacterer keyword or year or genre or system) . that will give you a maximum of possibility. For favorites , you need at least 1 favorite game added to any system in a file placed on databases\%systemname%\favorites.txt , if you save your favorites in other place they will not be recognized. if videos problem persist , send me your hyperspin settings folder. Hypersearch-Fixed-v5.zip R0m@n0
