Problem with demul 0.582
jcrowley30
The error I get is .zip is not supported and I have it listed in the module. I have included the log, its long though
Code:
BuildScript - Module:
MEmu = Demul
MEmuV = v0.5.8.2
MURL = [url]http://demul.emulation64.com/[/url]
MAuthor = djvj
MVersion = 2.0.3
MCRC = EFEE7501
iCRC = F43FB746
mId = 635211874656892855
MSystem = "Sammy Atomiswave","Sega Dreamcast","Sega Naomi","Gaelco"
; Notes:
; Required - control and nvram files can be found in my user dir on the FTP at /Upload Here/djvj/Sega Naomi\Emulators. Additonal instructions from my orignal HL1.0 script at [url]http://www.hyperspin-fe.com/forum/showpost.php?p=86093&postcount=104[/url]
; Required - moduleName ini: can be found in my user dir on the FTP at /Upload Here/djvj/Sega Naomi\Modules\Sega Naomi
; moduleName ini must be placed in same folder as this module
; GDI images must match mame zip names and be extracted and have a .dat extension
; Rom_Extension should be zip
; Place the naomi.zip bios archive in the demul\roms subdir
; Set your Video Plugin to gpuOglv3 and set your desired resolution there
; In case your control codes do not match mine, set your desired control type in demul, then open the demul.ini and find section PORTB and look for the device key. Use this number instead of the one I provided
; gpuDX11, gpuDXv3, and gpuDXLegacy are all supported. Define what plugin you want to use for each game in the moduleName ini.
; Read the notes at the top of the moduleName ini on how to control windowed fullscreen, true fullscreen, or windowed mode
; Windowed fullscreen will take effect the 2nd time you run the emu. It has to calculate your resolution on first run.
; Controls:
; Start a game of each control type (look in the moduleName ini for these types) and configure your controls to play the game. Copy paste the JAMMA0_0 and JAMMA0_1 (for naomi) or the ATOMISWAVE0_0 and ATOMISWAVE0_1 (for atomiswave) sections into the moduleName ini under the matching controls section.
; Troubleshooting:
; For some reason demul's ini files can get corrupted and ahk can't read/write to them correctly.
; If your ini keys are not being read or not writing to their existing keys in the demul inis, create a new file and copy/paste everything from the old ini into the new one and save.
; If you use Fade_Out, the module will force close demul because you cannot send ALT+F4 to demul if another GUI is covering it. Otherwise demul should close cleanly when Fade_Out is disabled. I suggest keeping Fade_Out disabled if you use this emu.
StartModule()
FadeInStart()
; This object controls how the module reacts to different systems. Demul can play a few systems, but needs to know what system you want to run, so this module has to adapt.
mType := Object("Sammy Atomiswave","atomiswave","Sega Dreamcast","dc","Sega Naomi","naomi","Gaelco","gaelco")
ident := mType[systemName] ; search object for the systemName identifier Demul uses
If !ident
ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this Demul module: " . moduleName)
demulFile := CheckFile(emuPath . "\Demul.ini")
padFile := CheckFile(emuPath . "\padDemul.ini")
controls := IniReadCheck(settingsFile, romname, "controls","standard",,1) ; have to read this first so the below loop works
; Read all the keys from the moduleName ini. Format is:
; Section, Key, Default Value, unique var
iniLookup =
( ltrim c
Settings, GlobalMax, false
Settings, MaxHideTaskbar
Settings, ControllerCode, 16777216
Settings, MouseCode, 131072
Settings, KeyboardCode, 1073741824
Settings, LightgunCode, -2147483648
Settings, LastControlUsed, standard
Settings, GlobalPlugin, gpuDX11
Settings, GlobalShaderUsePass1, false
Settings, GlobalShaderUsePass2, false
Settings, GlobalShaderNamePass1
Settings, GlobalShaderNamePass2
%romName%, Max
%romName%, LoadDecrypted
%romName%, Bios
%romName%, ShaderUsePass1
%romName%, ShaderUsePass2
%romName%, ShaderNamePass1
%romName%, ShaderNamePass2
%romName%, Plugin
%romName%, ListSorting
%controls%_JAMMA0_0, push1,,push1_0
%controls%_JAMMA0_0, push2,,push2_0
%controls%_JAMMA0_0, push3,,push3_0
%controls%_JAMMA0_0, push4,,push4_0
%controls%_JAMMA0_0, push5,,push5_0
%controls%_JAMMA0_0, push6,,push6_0
%controls%_JAMMA0_0, push7,,push7_0
%controls%_JAMMA0_0, push8,,push8_0
%controls%_JAMMA0_0, SERVICE,,service_0
%controls%_JAMMA0_0, START,,start_0
%controls%_JAMMA0_0, COIN,,coin_0
%controls%_JAMMA0_0, DIGITALUP,,digitalup_0
%controls%_JAMMA0_0, DIGITALDOWN,,digitaldown_0
%controls%_JAMMA0_0, DIGITALLEFT,,digitalleft_0
%controls%_JAMMA0_0, DIGITALRIGHT,,digitalright_0
%controls%_JAMMA0_0, ANALOGUP,,analogup_0
%controls%_JAMMA0_0, ANALOGDOWN,,analogdown_0
%controls%_JAMMA0_0, ANALOGLEFT,,analogleft_0
%controls%_JAMMA0_0, ANALOGRIGHT,,analogright_0
%controls%_JAMMA0_0, ANALOGUP2,,analogup2_0
%controls%_JAMMA0_0, ANALOGDOWN2,,analogdown2_0
%controls%_JAMMA0_0, ANALOGLEFT2,,analogleft2_0
%controls%_JAMMA0_0, ANALOGRIGHT2,,analogright2_0
%controls%_JAMMA0_1, push1,,push1_1
%controls%_JAMMA0_1, push2,,push2_1
%controls%_JAMMA0_1, push3,,push3_1
%controls%_JAMMA0_1, push4,,push4_1
%controls%_JAMMA0_1, push5,,push5_1
%controls%_JAMMA0_1, push6,,push6_1
%controls%_JAMMA0_1, push7,,push7_1
%controls%_JAMMA0_1, push8,,push8_1
%controls%_JAMMA0_1, SERVICE,,service_1
%controls%_JAMMA0_1, START,,start_1
%controls%_JAMMA0_1, COIN,,coin_1
%controls%_JAMMA0_1, DIGITALUP,,digitalup_1
%controls%_JAMMA0_1, DIGITALDOWN,,digitaldown_1
%controls%_JAMMA0_1, DIGITALLEFT,,digitalleft_1
%controls%_JAMMA0_1, DIGITALRIGHT,,digitalright_1
%controls%_JAMMA0_1, ANALOGUP,,analogup_1
%controls%_JAMMA0_1, ANALOGDOWN,,analogdown_1
%controls%_JAMMA0_1, ANALOGLEFT,,analogleft_1
%controls%_JAMMA0_1, ANALOGRIGHT,,analogright_1
%controls%_JAMMA0_1, ANALOGUP2,,analogup2_1
%controls%_JAMMA0_1, ANALOGDOWN2,,analogdown2_1
%controls%_JAMMA0_1, ANALOGLEFT2,,analogleft2_1
%controls%_JAMMA0_1, ANALOGRIGHT2,,analogright2_1
Loop, Parse, iniLookup, `n
StringSplit, split, A_LoopField, `,, %A_Space%%A_Tab%
If split4
%split4% := IniReadCheck(settingsFile, split1, split2, split3,,1)
Else
%split2% := IniReadCheck(settingsFile, split1, split2, split3,,1)
; need to empty the vars for the next loop otherwise they will still have values from the previous loop
split3:=
split4:=
; Now compare global & rom keys to get final value
max := If (max = "" or max = "ERROR") ? globalMax : max
plugin := If (plugin = "" or plugin = "ERROR") ? globalPlugin : plugin
shaderUsePass1 := If (shaderUsePass1 = "" or shaderUsePass1 = "ERROR") ? globalShaderUsePass1 : shaderUsePass1
shaderUsePass2 := If (shaderUsePass2 = "" or shaderUsePass2 = "ERROR") ? globalShaderUsePass2 : shaderUsePass2
shaderNamePass1 := If (shaderNamePass1 = "" or shaderNamePass1 = "ERROR") ? globalShaderNamePass1 : shaderNamePass1
shaderNamePass2 := If (shaderNamePass2 = "" or shaderNamePass2 = "ERROR") ? globalShaderNamePass2 : shaderNamePass2
; Verify user set desired gpu plugin name correctly
If ( plugin != "gpuDX11" And plugin != "gpuDX10" ) or ( plugin = "" or plugin = "ERROR" )
ScriptError(plugin . " is not a supported gpu plugin.`nLeave the plugin blank to use the default ""gpuDX11"".`nValid options are gpuDX11, or gpuDX10.")
; check for the specified gpu plugin
gpuFile := CheckFile(emuPath . "\" . plugin . ".ini")
; This updates the DX11gpu ini file to turn List Sorting on or off. Depending on the games, turning this on for some games may remedy missing graphics, having it off on other games may fix corrupted graphics. Untill they improve the DX11gpu, this is the best it's gonna get.
;If plugin = gpuDX11
If ( plugin = "gpuDX11" ) Or ( plugin = "gpuDX10" )
If ListSorting = true
IniWrite, 0, %gpuFile%, main, AutoSort ; 0 enables Auto Sort in demul 0.5.7, opposite from 0.5.6
Else
IniWrite, 1, %gpuFile%, main, AutoSort ; Disabling Auto Sort unless someone specifies it to be on or off in settings
; This updates the demul.ini with your gpu plugin choice for the selected rom
IniWrite, %plugin%.dll, %demulFile%, plugins, gpu
; Shader Effects
If ( plugin = "gpuDX11" ) Or ( plugin = "gpuDX10" ) ; Demul 0.5.7 only supports shaders using the gpuDX11 plugin
Loop, 2 {
shaderUsePass%A_Index% := If (ShaderUsePass%A_Index% != "" and ShaderUsePass%A_Index% != "ERROR" ? (ShaderUsePass%A_Index%) : (GlobalShaderUsePass%A_Index%)) ; determine what shaderUsePass to use
IniRead, currentusePass%A_Index%, %gpuFile%, shaders, usePass%A_Index%
If (shaderUsePass%A_Index% = "true")
shaderNamePass%A_Index% := If (ShaderNamePass%A_Index% != "" and ShaderNamePass%A_Index% != "ERROR" ? (ShaderNamePass%A_Index%) : (GlobalShaderNamePass%A_Index%)) ; determine what shaderNamePass to use
If shaderNamePass%A_Index% not in FXAA,HDR-TV,SCANLINES,CARTOON,RGB DOT(MICRO),RGB DOT(TINY),BLUR
ScriptError(shaderNamePass%A_Index% . " is not a valid choice for a shader. Your options are FXAA, HDR-TV, SCANLINES, CARTOON, RGB DOT(MICRO), RGB DOT(TINY), or BLUR.")
If (currentusePass%A_Index% = 0)
IniWrite, 1, %gpuFile%, shaders, usePass%A_Index% ; turn shader on in gpuDX11 ini
IniWrite, % shaderNamePass%A_Index%, %gpuFile%, shaders, shaderPass%A_Index% ; update gpuDX11 ini with the shader name to use
}Else If (shaderUsePass%A_Index% != "true" and currentusePass%A_Index% = 1)
IniWrite, 0, %gpuFile%, shaders, usePass%A_Index% ; turn shader off in gpuDX11 ini
If ident = dc
If ( romExtension = ".cdi" || romExtension = ".mds" || romExtension = ".ccd" || romExtension = ".nrg" || romExtension = ".gdi" || romExtension = ".cue" ) {
gdrImageFile := CheckFile(emuPath . "\gdrImage.ini")
FileDelete, %gdrImageFile%
Sleep, 500
IniWrite, gdrImage.dll, %demulFile%, plugins, gdr
IniWrite, false, %gdrImageFile%, Main, openDialog
IniWrite, %romPath%\%romName%%romExtension%, %gdrImageFile%, Main, imagefilename
} Else If romExtension = .chd
gdrCHDFile := CheckFile(emuPath . "\gdrCHD.ini")
FileDelete, %gdrCHDFile%
Sleep, 500
IniWrite, false, %gdrCHDFile%, Main, openDialog
IniWrite, gdrCHD.dll, %demulFile%, plugins, gdr
IniWrite, %romPath%\%romName%%romExtension%, %gdrCHDFile%, Main, imagefilename
} Else
ScriptError(romExtension . " is not a supported file type for this " . moduleName . " module.")
IniWrite, 1, %demulFile%, main, region ; Set BIOS to Auto Region
} Else { ; all other systems, Naomi and Atomiswave
; This updates the demul.ini with your Bios choice for the selected rom
If ( Bios != "" and Bios != "ERROR" ) {
Bios := RegExReplace(Bios,"\s.*") ; Cleans off the added text from the key's value so only the number is left
IniWrite, false, %demulFile%, main, naomiBiosAuto ; turning auto bios off so we can use a specific one instead
IniWrite, %Bios%, %demulFile%, main, naomiBios ; setting specific bios user has set from the moduleName ini
} Else
IniWrite, true, %demulFile%, main, naomiBiosAuto ; turning auto bios on if user did not specify a specific one
; This section writes your custom keys to the padDemul.ini. Naomi games had many control panel layouts. The only way we can accomodate these differing controls, is to keep track of them all and write them to the ini at the launch of each game.
; First we check if the last controls used are the same as the game we want to play, so we don't waste time updating the ini if it is not necessary. For example playing 2 sfstyle type games in a row, we wouldn't need to write to the ini.
; This section tells demul what arcade control type should be connected to the game. Options are standard (aka controller), mouse, lightgun, or keyboard
If ( controls = "lightgun" || controls = "mouse" )
IniWrite, %MouseCode%, %demulFile%, PORTB, device
Else If ( controls = "keyboard" )
IniWrite, %KeyboardCode%, %demulFile%, PORTB, device
Else ; accounts for all other control types
IniWrite, %ControllerCode%, %demulFile%, PORTB, device
If ( LastControlUsed != controls ) { ; find out last controls used for the system we are launching
WriteControls(padFile, 0,push1_0,push2_0,push3_0,push4_0,push5_0,push6_0,push7_0,push8_0,SERVICE_0,START_0,COIN_0,DIGITALUP_0,DIGITALDOWN_0,DIGITALLEFT_0,DIGITALRIGHT_0,ANALOGUP_0,ANALOGDOWN_0,ANALOGLEFT_0,ANALOGRIGHT_0,ANALOGUP2_0,ANALOGDOWN2_0,ANALOGLEFT2_0,ANALOGRIGHT2_0)
WriteControls(padFile, 1,push1_1,push2_1,push3_1,push4_1,push5_1,push6_1,push7_1,push8_1,SERVICE_1,START_1,COIN_1,DIGITALUP_1,DIGITALDOWN_1,DIGITALLEFT_1,DIGITALRIGHT_1,ANALOGUP_1,ANALOGDOWN_1,ANALOGLEFT_1,ANALOGRIGHT_1,ANALOGUP2_1,ANALOGDOWN2_1,ANALOGLEFT2_1,ANALOGRIGHT2_1)
IniWrite, %controls%, %settingsFile%, Settings, LastControlUsed
; Setting demul to use true fullscreen if defined in settings.ini, otherwise sets demul to run windowed. This is for gpuDX11 plugin only
If plugin = gpuDX11
If Max = fullscreen
IniWrite, 1, %gpuFile%, main, UseFullscreen
Else
IniWrite, 0, %gpuFile%, main, UseFullscreen
If Max = true
If maxHideTaskbar = true
WinHide, ahk_class Shell_TrayWnd
WinHide, Start ahk_class Button
; Create black background to give the emu the fullscreen look
Gui 2: -Caption +ToolWindow
Gui 2: Color, Black
Gui 2: Show, x0 y0 h%A_ScreenHeight% w%A_ScreenWidth%
Sleep, 250
; Construct the CLI for demul and send romName if naomi or atomiswave. Dreamcast needs a full path and romName.
If LoadDecrypted = true ; decrypted naomi rom
romCLI := "-customrom=" . """" . romPath . "\" . romName . ".bin"""
Else If ident = dc ; dreamcast game
romCLI := " -image=" . """" . romPath . "\" . romName . romExtension . """"
Else ; standard naomi rom
romCLI := "-rom=" . romName
Run(executable . " -run=" . ident . " " . romCLI, emuPath,, emuPID)
;Sleep, 1000 ; need a second for demul to launch, increase if yours takes longer and the emu is appearing too soon
Loop { ; looping until demul is done loading rom and gpu starts showing frames
Sleep, 200
WinGetTitle, winTitle, ahk_class window
StringSplit, winTextSplit, winTitle, %A_Space%
If ( winTextSplit5 = "gpu:" And winTextSplit6 != "0" And winTextSplit6 != "1" )
break
WinActivate ahk_class window
If ( ( mType = "Gaelco" Or mType = "gaelco" ) && Max = "fullscreen" )
Send !{ENTER} ; Automatic fullscreen seems to be broken in the Gaelco driver, must alt+Enter to get fullscreen
; This is where we calculate and maximize demul's window using our pseudo fullscreen code
If Max = true
WinSet, Style, -0x40000, ahk_class window ; Removes the border of the game window
WinSet, Style, -0xC00000, ahk_class window ; Removes the TitleBar
Send, {F3} ; Removes the MenuBar
MaximizeWindow("ahk_class window") ; this will take effect after you run demul once because we cannot stretch demul's screen while it is running.
FadeInExit()
Gui 2: Destroy
FadeOutExit()
If (Max = "true" and maxHideTaskbar = "true") {
WinShow,ahk_class Shell_TrayWnd
WinShow,Start ahk_class Button
ExitModule()
; Write new controls to padDemul.ini
WriteControls(file, player,push1,push2,push3,push4,push5,push6,push7,push8,service,start,coin,digitalup,digitaldown,digitalleft,digitalright,analogup,analogdown,analogleft,analogright,analogup2,analogdown2,analogleft2,analogright2) {
IniWrite, %push1%, %file%, JAMMA0_%player%, PUSH1
IniWrite, %push2%, %file%, JAMMA0_%player%, PUSH2
IniWrite, %push3%, %file%, JAMMA0_%player%, PUSH3
IniWrite, %push4%, %file%, JAMMA0_%player%, PUSH4
IniWrite, %push5%, %file%, JAMMA0_%player%, PUSH5
IniWrite, %push6%, %file%, JAMMA0_%player%, PUSH6
IniWrite, %push7%, %file%, JAMMA0_%player%, PUSH7
IniWrite, %push8%, %file%, JAMMA0_%player%, PUSH8
IniWrite, %service%, %file%, JAMMA0_%player%, SERVICE
IniWrite, %start%, %file%, JAMMA0_%player%, START
IniWrite, %coin%, %file%, JAMMA0_%player%, COIN
IniWrite, %digitalup%, %file%, JAMMA0_%player%, DIGITALUP
IniWrite, %digitaldown%, %file%, JAMMA0_%player%, DIGITALDOWN
IniWrite, %digitalleft%, %file%, JAMMA0_%player%, DIGITALLEFT
IniWrite, %digitalright%, %file%, JAMMA0_%player%, DIGITALRIGHT
IniWrite, %analogup%, %file%, JAMMA0_%player%, ANALOGUP
IniWrite, %analogdown%, %file%, JAMMA0_%player%, ANALOGDOWN
IniWrite, %analogleft%, %file%, JAMMA0_%player%, ANALOGLEFT
IniWrite, %analogright%, %file%, JAMMA0_%player%, ANALOGRIGHT
IniWrite, %analogup2%, %file%, JAMMA0_%player%, ANALOGUP2
IniWrite, %analogdown2%, %file%, JAMMA0_%player%, ANALOGDOWN2
IniWrite, %analogleft2%, %file%, JAMMA0_%player%, ANALOGLEFT2
IniWrite, %analogright2%, %file%, JAMMA0_%player%, ANALOGRIGHT2
MaximizeWindow(class) {
Global
WinGetPos, appX, appY, appWidth, appHeight, %class%
widthMaxPercenty := ( A_ScreenWidth / appWidth )
heightMaxPercenty := ( A_ScreenHeight / appHeight )
If ( widthMaxPercenty < heightMaxPercenty )
percentToEnlarge := widthMaxPercenty
Else
percentToEnlarge := heightMaxPercenty
appWidthNew := appWidth * percentToEnlarge
appHeightNew := appHeight * percentToEnlarge
Transform, appX, Round, %appX%
Transform, appY, Round, %appY%
Transform, appWidthNew, Round, %appWidthNew%
Transform, appHeightNew, Round, %appHeightNew%
appXPos := ( A_ScreenWidth / 2 ) - ( appWidthNew / 2 )
appYPos := ( A_ScreenHeight / 2 ) - ( appHeightNew / 2 )
If ( plugin = "gpuDX11" ) {
IniWrite, %appWidthNew%, %gpuDX11File%, resolution, Width
IniWrite, %appHeightNew%, %gpuDX11File%, resolution, Height
} Else {
IniWrite, %appWidthNew%, %gpuFile%, resolution, wWidth
IniWrite, %appHeightNew%, %gpuFile%, resolution, wHeight
WinMove, %class%,, appXPos, appYPos
HaltEmu:
If Max = fullscreen
Send !{ENTER}
Return
RestoreEmu:
If Max = fullscreen
Send !{ENTER}
Return
CloseProcess:
FadeOutStart()
If fadeOut != true ; cannot send ALT+F4 to a background window (controlsend doesn't work), so we have to force close instead.
; demul 0.5.7 crashes 50% of the time if you try to close it any other way
Send, {F3}{Alt}{Up}s{Enter}
Sleep, 50
Process("Close", emuPID) ; we have to close this way otherwise demul crashes with WinClose
Return
23:06:59:409 HL INFO +0 BuildScript - Loaded Statistics.ahk script
23:06:59:409 HL INFO +0 BuildScript - Loaded User Functions.ahk script
23:06:59:409 HL INFO +0 BuildScript - Finished injecting functions into module
23:06:59:409 HL INFO +0 Main - Module is built
23:06:59:409 HL INFO +0 CheckFile - Checking if C:\Hyperspin\HyperLaunch\AutoHotkey.dll exists
23:06:59:410 HL INFO +0 Main - Running module
23:06:59:484 MD INFO +N/A Module initialized
23:06:59:485 MD INFO +0 StartModule - Started
23:06:59:485 MD INFO +0 StartModule - MEmu: Demul
MEmuV: v0.5.8.2
MURL: [url]http://demul.emulation64.com/[/url]
MAuthor: djvj
MVersion: 2.0.3
MCRC: EFEE7501
iCRC: F43FB746
MID:
MSystem: "Sammy Atomiswave","Sega Dreamcast","Sega Naomi","Gaelco"
23:06:59:485 MD INFO +0 StartModule - You have a supported System Name for this module: "Sega Dreamcast"
23:06:59:486 MD INFO +0 StartModule - Ended
23:06:59:486 MD INFO +0 StartGlobalUserFeatures - Starting
23:06:59:486 MD INFO +0 StartGlobalUserFeatures - Ending
23:06:59:486 MD INFO +0 CheckFile - Checking if C:\Hyperspin\Emulators\Sega Dreamcast\DeMul\Demul.ini exists
23:06:59:487 MD INFO +0 CheckFile - Checking if C:\Hyperspin\Emulators\Sega Dreamcast\DeMul\padDemul.ini exists
23:06:59:488 MD INFO +0 Module Setting - [Crazy Taxi 2 (USA)] - controls: standard
23:06:59:488 MD INFO +0 Module Setting - [settings] - GlobalMax: false
23:06:59:488 MD INFO +0 Module Setting - [settings] - MaxHideTaskbar:
23:06:59:488 MD INFO +0 Module Setting - [settings] - ControllerCode: 16777216
23:06:59:488 MD INFO +0 Module Setting - [settings] - MouseCode: 131072
23:06:59:488 MD INFO +0 Module Setting - [settings] - KeyboardCode: 1073741824
23:06:59:488 MD INFO +0 Module Setting - [settings] - LightgunCode: -2147483648
23:06:59:488 MD INFO +0 Module Setting - [settings] - LastControlUsed: standard
23:06:59:488 MD INFO +0 Module Setting - [settings] - GlobalPlugin: gpuDX11
23:06:59:488 MD INFO +0 Module Setting - [settings] - GlobalShaderUsePass1: false
23:06:59:488 MD INFO +0 Module Setting - [settings] - GlobalShaderUsePass2: false
23:06:59:488 MD INFO +0 Module Setting - [settings] - GlobalShaderNamePass1:
23:06:59:488 MD INFO +0 Module Setting - [settings] - GlobalShaderNamePass2:
23:06:59:488 MD INFO +0 Module Setting - [Crazy Taxi 2 (USA)] - Max:
23:06:59:488 MD INFO +0 Module Setting - [Crazy Taxi 2 (USA)] - LoadDecrypted:
23:06:59:488 MD INFO +0 Module Setting - [Crazy Taxi 2 (USA)] - Bios:
23:06:59:488 MD INFO +0 Module Setting - [Crazy Taxi 2 (USA)] - ShaderUsePass1:
23:06:59:488 MD INFO +0 Module Setting - [Crazy Taxi 2 (USA)] - ShaderUsePass2:
23:06:59:488 MD INFO +0 Module Setting - [Crazy Taxi 2 (USA)] - ShaderNamePass1:
23:06:59:488 MD INFO +0 Module Setting - [Crazy Taxi 2 (USA)] - ShaderNamePass2:
23:06:59:488 MD INFO +0 Module Setting - [Crazy Taxi 2 (USA)] - Plugin:
23:06:59:488 MD INFO +0 Module Setting - [Crazy Taxi 2 (USA)] - ListSorting:
23:06:59:488 MD INFO +0 Module Setting - [standard_JAMMA0_0] - push1:
23:06:59:488 MD INFO +0 Module Setting - [standard_JAMMA0_0] - push2:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - push3:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - push4:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - push5:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - push6:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - push7:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - push8:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - SERVICE:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - START:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - COIN:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - DIGITALUP:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - DIGITALDOWN:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - DIGITALLEFT:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - DIGITALRIGHT:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - ANALOGUP:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - ANALOGDOWN:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - ANALOGLEFT:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - ANALOGRIGHT:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - ANALOGUP2:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - ANALOGDOWN2:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - ANALOGLEFT2:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_0] - ANALOGRIGHT2:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_1] - push1:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_1] - push2:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_1] - push3:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_1] - push4:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_1] - push5:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_1] - push6:
23:06:59:489 MD INFO +0 Module Setting - [standard_JAMMA0_1] - push7:
23:06:59:490 MD INFO +0 Module Setting - [standard_JAMMA0_1] - push8:
23:06:59:490 MD INFO +0 Module Setting - [standard_JAMMA0_1] - SERVICE:
23:06:59:490 MD INFO +0 Module Setting - [standard_JAMMA0_1] - START:
23:06:59:490 MD INFO +0 Module Setting - [standard_JAMMA0_1] - COIN:
23:06:59:490 MD INFO +0 Module Setting - [standard_JAMMA0_1] - DIGITALUP:
23:06:59:490 MD INFO +0 Module Setting - [standard_JAMMA0_1] - DIGITALDOWN:
23:06:59:490 MD INFO +0 Module Setting - [standard_JAMMA0_1] - DIGITALLEFT:
23:06:59:490 MD INFO +0 Module Setting - [standard_JAMMA0_1] - DIGITALRIGHT:
23:06:59:490 MD INFO +0 Module Setting - [standard_JAMMA0_1] - ANALOGUP:
23:06:59:490 MD INFO +0 Module Setting - [standard_JAMMA0_1] - ANALOGDOWN:
23:06:59:490 MD INFO +0 Module Setting - [standard_JAMMA0_1] - ANALOGLEFT:
23:06:59:490 MD INFO +0 Module Setting - [standard_JAMMA0_1] - ANALOGRIGHT:
23:06:59:490 MD INFO +0 Module Setting - [standard_JAMMA0_1] - ANALOGUP2:
23:06:59:490 MD INFO +0 Module Setting - [standard_JAMMA0_1] - ANALOGDOWN2:
23:06:59:490 MD INFO +0 Module Setting - [standard_JAMMA0_1] - ANALOGLEFT2:
23:06:59:490 MD INFO +0 Module Setting - [standard_JAMMA0_1] - ANALOGRIGHT2:
23:06:59:490 MD INFO +0 CheckFile - Checking if C:\Hyperspin\Emulators\Sega Dreamcast\DeMul\gpuDX11.ini exists
23:07:03:311 MD ERROR +3822 .zip is not a supported file type for this Demul (v0.5.8) module.
23:07:03:311 MD INFO +0 ExitModule - Started
23:07:03:311 MD INFO +0 Starting Updating Statistics:
23:07:03:311 MD INFO +0 CreateRomTable - Started
23:07:03:311 MD INFO +0 CreateRomTable - Ended, 7 Loops to create table.
23:07:03:346 MD INFO +31 Game section statistics updated.
23:07:03:346 MD INFO +0 ExitModule - Ended
23:07:03:346 MD INFO +0 End of Module Logs
23:07:03:398 HL INFO +3994 Main - Module ended, exiting HyperLaunch normally
23:07:03:398 HL INFO +0 ExitScript - Started
23:07:03:406 HL INFO +0 SystemCursor - Restoring mouse cursor
23:07:03:410 HL INFO +0 ExitScript - Ended
Like I said in your other thread, http://www.hyperspin-fe.com/forum/showthread.php?37023-Help-with-demul057&p=353497&viewfull=1#post353497 get your system up to date first otherwise no one can help.
Your module is out of date, so the new one probably has zip support.
MEmu = Demul
MEmuV =  v0.5.8.2
MURL = http://demul.emulation64.com/
MAuthor = djvj
[color="#FF0000"]MVersion = 2.0.4 BETA[/color]
MCRC = EFEE7501
iCRC = F43FB746
My apologies, I must have missed something when I updated the system. I will go through the update again tonight. Thanks for the help and sorry for the waste of time.
No actually, my apologies to you, you seem to have the latest module that is available through GIT, I'm not entirely sure what I have as I can't find a thread about a beta version; It may be a version with bezel support?
Anyway your problem is probably linked to 7z, make sure it's set to True in HLHQ for Dreamcast. My Roms are all 7z, but I renamed 1 to .zip and switch 7z to false in HLHQ and got your error.
Worked like a charm. Thanks yet again. I can't tell you how many posts Ive read and youtube videos I have watched that you have helped me with.
