controllerremap
Has anyone use the controllerremap program to fix the problem of random usb assignment? I just added two u360 joysticks and now windows screws up mame.
  • 1 year later...
I'm not sure what I'm doing wrong. ControllerRemap works perfectly outside of HS, but when I add it to the HyperHQ startup, I get nothing. Here is what my settings look like in HQ:
Startup Program: E:\ControllerRemap.exe
Params: -ctrlr MyArcade.cfg
Winstate: HIDDEN
According to the HS Log, here is what I have
09:56:31 AM | HyperSpin Started
09:56:31 AM | Going FullScreen
09:56:31 AM | Checking for updates
09:56:31 AM | Update Check Complete
09:56:31 AM | Startup program: ControllerRemap.exe
09:56:31 AM | Startup params: -ctrlr MyArcade.cfg
09:56:31 AM | Working directory: E:\
09:56:31 AM | Window State: HIDDEN
09:56:31 AM | Launching ControllerRemap.exe
09:56:31 AM | Command Line is ControllerRemap.exe -ctrlr MyArcade.cfg
09:56:31 AM | Playing intro video
09:56:32 AM | Menu Mode is multi
09:56:32 AM | Loading Main Menu.xml
09:56:32 AM | Main Menu.xml successfully loaded
09:56:33 AM | Main Menu wheel loaded successfully
09:56:35 AM | Loading MAME.xml
09:56:35 AM | Main Menu.xml successfully loaded
09:56:35 AM | MAME wheel loaded successfully
09:56:37 AM | Launching Game
09:56:37 AM | Running in normal rom mode
09:56:37 AM | Excecutable is mame.exe
09:56:37 AM | Command Line is: "E:\mame.exe" term2.zip
09:56:48 AM | Loading Main Menu.xml
09:56:48 AM | Main Menu.xml successfully loaded
09:56:49 AM | Main Menu wheel loaded successfully
09:56:51 AM | Exit program unavailable
09:56:51 AM | Quiting Hyperspin
09:56:51 AM | Bye!
I thought it seemed legit, but the correct code to put in a DOS window with ControllerRemap is
mame term2 -ctrlr MyArcade.cfg
Any ideas?
After a few cups of coffee and staring at the code, I realized what the problem was.
ControllerRemap.exe should be in the Startup programs for Hyperspin, but with no parameters.(I had previously put the parameter under the Startup program)
Under the MAME wheel, the parameters should be set similar to the DOS setup
-ctrlr MyArcade (with no cfg on the end)
I also removed the ".zip" parameter from HS, and presto, the game works perfectly now.
Check your log.txt in Hyperspin, it will show you how the system is reading the configurations. I made HS do exactly what a DOS prompt would do.
Hope this helps anyone who is attempting the same!
