jono1250 Posted December 25, 2014 Posted December 25, 2014 I have setup both guns As Device 1 and Device2 in the software setup. Mame sees them as the same controller Dual light guns is on Multimice is on Using mame64 from jumpstile's folder
jono1250 Posted December 27, 2014 Author Posted December 27, 2014 This is now sorted. Used a vanilla version of MamepUi (0.139) and everything works from the get go.
what2be Posted March 7, 2015 Posted March 7, 2015 jono1250 said: This is now sorted. Used a vanilla version of MamepUi (0.139) and everything works from the get go. Ive read twice now in these forums that hyperspin should be used with mame and not mameui (or derivatives such as mameuifx) Ive been having the exact same problem as you and its driving me crazy, so Im going to try a mame command line version that i see in Jumpstiles FTP folder that is NOT the mameuifx version but still has the same features, which is: MAME .159 x64 NoNag+HiScore+NeoGeoXtra+Autofire+DirectInput My question is, what is it in the mameuifx version that causes it to have problems with 2 lightguns in mame (or multiple mice really) since both my aimtraks are seen as one device inside mame but as 2 devices outside mame?
Dime333 Posted March 7, 2015 Posted March 7, 2015 You must use a raw input build in order to use two guns not direct input.
what2be Posted March 7, 2015 Posted March 7, 2015 Thank you for the reply, I will now use the non Direct Input version and try that. Curious though, Is there a limit on the number of mouse devices you can have with the direct input version? (i have 5, 2 as lightguns, 1 as trackball, 1 as spinner and 1 as my computers mouse) And if thats true, then it shouldnt matter what RAW input build I use of mame, correct? (either mameuifx without DI or MAME command line without DI)
Dime333 Posted March 7, 2015 Posted March 7, 2015 what2be said: Thank you for the reply, I will now use the non Direct Input version and try that. Curious though, Is there a limit on the number of mouse devices you can have with the direct input version? (i have 5, 2 as lightguns, 1 as trackball, 1 as spinner and 1 as my computers mouse) And if thats true, then it shouldnt matter what RAW input build I use of mame, correct? (either mameuifx without DI or MAME command line without DI) No, that shouldn't matter. I just tried my setup with Jumptiles 0.158 build. Something seems to be wrong with it, since it sees both guns as Gun 1. I will try 0.159 later and see if t's working with that.
Roc Posted May 13, 2015 Posted May 13, 2015 On 3/7/2015 at 7:55 PM, Dime333 said: No, that shouldn't matter. I just tried my setup with Jumptiles 0.158 build. Something seems to be wrong with it, since it sees both guns as Gun 1. I will try 0.159 later and see if t's working with that. I'm having the same issue even with 0.160
dougan78 Posted May 28, 2015 Posted May 28, 2015 Same here. Is there a thread with how to setup properly?
sevenseal Posted May 28, 2015 Posted May 28, 2015 I found myself usually have to build my own mameuifx for my aim track guns because something is odd with jumpstile's mods when you try out lightguns
Jumpstile Posted May 31, 2015 Posted May 31, 2015 There's nothing odd or wrong. For more than one lightgun make sure you are using one of my MAME builds WITHOUT directinput, and make sure it's one of the last two versions that were released (.160 or .161 or the soon to be released .162). Any others and you will have issues. - J* How to rebuild your MAME ROM set using CLRMAMEPRO - Walkthrough HERE!
sevenseal Posted June 1, 2015 Posted June 1, 2015 On 5/31/2015 at 10:16 PM, Jumpstile said: There's nothing odd or wrong. For more than one lightgun make sure you are using one of my MAME builds WITHOUT directinput, and make sure it's one of the last two versions that were released (.160 or .161 or the soon to be released .162). Any others and you will have issues. - J* i tried your non directinput versions before, i am fully aware of that lightgun (especially aimtraks) require raw input to function correctly. oddly aimtraks have a hard time with multiple guns was my experience.
Jumpstile Posted June 1, 2015 Posted June 1, 2015 Again, there were problems with earlier versions. Whatever... Hope you fix your issue. - J* How to rebuild your MAME ROM set using CLRMAMEPRO - Walkthrough HERE!
dougan78 Posted June 7, 2015 Posted June 7, 2015 On 6/1/2015 at 1:52 AM, Jumpstile said: Again, there were problems with earlier versions. Whatever... Hope you fix your issue. - J* I love your builds and stopped upgrading at .153 due to this issue. I just tested .162 and can confirm it still puts both lightguns as Gun1. When I run the latest regular mame from mamedev it recognizes both guns properly. So I believe something is wacky still.
Jumpstile Posted June 7, 2015 Posted June 7, 2015 It's in your settings. Works fine for me, as well as others. - J* How to rebuild your MAME ROM set using CLRMAMEPRO - Walkthrough HERE!
dougan78 Posted June 7, 2015 Posted June 7, 2015 On 6/7/2015 at 1:42 PM, Jumpstile said: It's in your settings. Works fine for me, as well as others. - J* Certainly possible. I downloaded your mame not direct input one.. Exracted it to a new folder. Ran mame -cc. Put your other zip contents in the same folder the zip for put in mame folder. I tested beast busters world. Only input selected was lightgun = 1. Tested and both guns are gun 1. Downloaded mame from mamedev put in same folder and tested with all same stuff and guns show up as gun3 and gun4 just fine. So if you could elaborate on these settings it would be helpful.
Jumpstile Posted June 7, 2015 Posted June 7, 2015 Sorry, not home to be able to do that. Maybe someone else can assist you. - J* How to rebuild your MAME ROM set using CLRMAMEPRO - Walkthrough HERE!
sevenseal Posted June 7, 2015 Posted June 7, 2015 On 6/7/2015 at 1:59 PM, dougan78 said: Certainly possible. I downloaded your mame not direct input one.. Exracted it to a new folder. Ran mame -cc. Put your other zip contents in the same folder the zip for put in mame folder. I tested beast busters world. Only input selected was lightgun = 1. Tested and both guns are gun 1. Downloaded mame from mamedev put in same folder and tested with all same stuff and guns show up as gun3 and gun4 just fine. So if you could elaborate on these settings it would be helpful. hi dougan78, just to let you know that game beast busters world is a yellow status rom which mean partially working, aiming on that game is not accurate so you should try a game with a green status i do have experience with dual lightguns Sevenseal
dougan78 Posted June 7, 2015 Posted June 7, 2015 On 6/7/2015 at 2:15 PM, Jumpstile said: Sorry, not home to be able to do that. Maybe someone else can assist you. - J* Whenever is fine no rush. Thanks. Like I said I have .153 working so I am good. Just wanted to check out golden tee 2004.
dougan78 Posted June 9, 2015 Posted June 9, 2015 On 6/7/2015 at 2:40 PM, sevenseal said: hi dougan78, just to let you know that game beast busters world is a yellow status rom which mean partially working, aiming on that game is not accurate so you should try a game with a green status i do have experience with dual lightguns Sevenseal I have beat it before no problem 2 player. Never noticed. ThanksS
