olfenite Posted February 7, 2017 Posted February 7, 2017 Hello, I'm sorry for bringing up an old topic, but this project really intrigues me. Years ago, I was going to build a NES PC, but never followed through. I've finally decided that I want to do it now, but everything is so different in the computer world than when I was first wanting to do this about a decade ago. I have never built a computer before and I'm very nervous about doing so. This tutorial is a great starting point. However, it is also several years old and that is a lifetime in computer years. I'm sure that there are different and better components that are available. Would anybody take the time to help me go shopping? I'm probably looking at a $400 budget, but can go to $500 if necessary. What I would hope to do is build a machine that allows me to play the classic consoles like NES, SNES, N64, Genesis, and maybe Dreamcast. Arcade games are not that important to me. Things that I like about this NES PC is the hard drive out and having the option to use a 19v adapter instead of trying to put in my own power supply. I even figured if it uses bluetooth gamepads, maybe I could use wiimotes and NES classic controllers attached to them to play old NES games, but I'm getting ahead of myself here. Thank you for taking the time to read. I look forward to hearing my options.
Snakerake Posted February 7, 2017 Posted February 7, 2017 Very cool! I was thinking about cramming my RetroPi setup into my old NES, but haven't had the nerve to rip it apart yet.
jq_quint Posted February 13, 2017 Posted February 13, 2017 For my birthday (41) I've actually asked my misses to source me a mint boxed NES, ha I'm such a child!Such a retro looking console Sent from my iPhone using Tapatalk
32assassin Posted February 16, 2017 Posted February 16, 2017 On 2/7/2017 at 1:07 PM, Snakerake said: Very cool! I was thinking about cramming my RetroPi setup into my old NES, but haven't had the nerve to rip it apart yet. its easier then what it looks parts needed 1 broken NES case: I bought 3 for $25 1 HDMI Coupler http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR12.TRC2.A0.H0.Xhdmi+coupler.TRS0&_nkw=hdmi+coupler&_sacat=0 1 Female Micro USB to Female USB http://www.ebay.com/itm/272313681930?_trksid=p2060353.m2749.l2649&var=571156014937&ssPageName=STRK%3AMEBIDX%3AIT 1 1FT HDMI cable 1 USB to Micro USB (PHONE charger) cable Optional CAT 5 Coupler ( if you do not want or cant use WIFI) http://www.ebay.com/itm/201637422756?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT 1 10 OHM resister to power Original NES LED 1 5V 3A phone charger: YOU need a high amp input if you wan to power the NES LED Trim all the exes mounting brackets from the NES https://www.dropbox.com/s/u82opoz6kp38lwp/DSCF2472.JPG?dl=0 MAKE some ABS cement http://modretro.com/xen/index.php?threads/how-to-make-abs-cement.332/ use the goo to fill in the holes Add painters tape and brush in some cement I only had clear tape but the end result is the same https://www.dropbox.com/s/thmnb5m976v51lv/DSCF2493.JPG?dl=0 when dry cut the holes for your 3 couplers and add glue not a pretty sight but NOBODY IS GOING TO SEE THIS!!!!! https://www.dropbox.com/s/x52cxnih2c55w9r/DSCF2499.JPG?dl=0 thats all you have to do but if you wan't a working cart mechanism you will have to cut into the case and ill in the hole this is my finished case https://www.dropbox.com/s/rot6r4oup5gwqyw/DSCF2495.JPG?dl=0 USE the Original NES Power Buttons cut your USB to Micro USB cable cord in HALF (trim exes) Solder the red and black wire to the power switch board https://www.dropbox.com/s/2fhtxtlat8r4dc6/DSCF2474.JPG?dl=0 you will need to modify the NES switch circuit board and solder your resister https://www.dropbox.com/s/7slpkwspu5fe0q7/DSCF2476.JPG?dl=0 if you need the schematics on what I did just ask the power switch will cut the power and it will also light up the LED when ON https://www.dropbox.com/s/juqt22cv48ppth2/DSCF2478.JPG?dl=0 You can buy a low volt/amp LED and run it directly from the power found on the IO pins of the Pi, but this works just as well. finaly build your image this is my old setup, I found the Hyperspin.Nut plugin and I'm in the process of going FULL Hyperspin Default theme on my image.
Snakerake Posted February 16, 2017 Posted February 16, 2017 haha, wow, thank you for the very thorough follow up! maybe not so hard
Snakerake Posted February 16, 2017 Posted February 16, 2017 You inspired me! I just bought 2 on ebay, I still don't have the nerve to hack up mine from childhood, as it still works. I'll hack someone else's then!
