retroarch help psx
rjtebble
Hi, I have retroarch somewhat working in hyperspin with psx, but when I load a game, it will either:
A: take 30sec to a min to load then is fine, or
B: take 30 sec to a min, then just says error, check ahk module.
I though it might have to do with the different rom formats, are some are bin/cue and some are ccd/img, however it seems random to whcih ones work and which ones dont.
If your Roms are zipped they will take time to start due to the extraction process. Your best and easiest thing to do is follow goofers offer, but be quick, time is running out, you've got until January 15th.
Retroarch also only supports certain disc formats and that's probably why you are seeing some work and others not.
To my knowledge (not sure about the newer nightly versions) Retroarch's Mednafen PSX core does not support IMG files, or Bin files, or ISO files... at least not by themselves. You pretty much need a cue file to point to these. Giga, what happens on January 15?!
Edit: Mednafen PSX Supported Extensions: supported_extensions = "cue|toc|m3u|ccd|exe"
Walter:beerglass:
m3u is related to muti disc support? does anybody manage to make this work with hyperpause feature? tried some month ago with no luck and didn't found that much info except the wiki that didn't worked in my case...
I'll say what I was going to say anyhow.
Being the local bacon moderator and not wishing to break any rules, thus ended my short term as bacon mod, this being the open forum not gold. I was eluding to something that was free and is no longer free on the 15th of Jan, so Tribble better get in there quick and get the no hassle set.
Basically what Jeremy said. ;)
I'm off to watch Noobz.
