zippo81 Posted January 5, 2015 Posted January 5, 2015 Hi Everyone!! I bought Hyperspin packs, some of the emulators works fine (like MAME); but I try to run Dreamcast.... and it´s doesn´t work. I find de emulator (Demul), roms folder.... but I need some help, step by step to make it run..... Can Anyone give me some help or advice??? Thanks!!!
gigapig Posted January 5, 2015 Posted January 5, 2015 Hi Zippo, welcome to the forum. What do you mean you bought Hyperspin packs? What are they?
zippo81 Posted January 6, 2015 Author Posted January 6, 2015 Hi, GIGAPIG! Someone who made hyperspin and sells by internet (page like ebay). As I did not have time to build it I must to buy it. When I try to run Dreamcast I can´t..... thats why I need some help!!! Thank you for the answer.
gigapig Posted January 6, 2015 Posted January 6, 2015 The normal thing to do in this case is to speak to the person you bought Hyperspin from. Please read the EULA below. If you wish to support the community, you can click the donate button above, or ask the seller for your Platinum member log in details. The software HyperSpin,HyperTheme and HyperHQ are property of their authors. [email protected] INSTALLATION OR USE OF THE ENCLOSED SOFTWARE INDICATES YOUR ASSENT TO THE FOLLOWING LICENSE AGREEMENT. The software HyperSpin,HyperTheme and HyperHQ are freeware and can be used freely, copied and given to third parties under the following terms: 1.You can use the software free of charge for private purposes. You may not however sell it for profit and you may not bundle HyperSpin in other software packages without affirmation of the author. 2.You are allowed to offer the program on a website that is free of charges. 3.For any other form of publication, the author’s written permission is necessary. 4.The software remains property of the author also in case of dissemination to third parties. 5.The software, especially the name of the software and the name of the author must remain unmodified. 6.THIS SOFTWARE IS PROVIDED FREE OF CHARGE AND ON AN "AS IS" BASIS, WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR IMPLIED INCLUDING WITHOUT LIMITATION THE WARRANTIES THAT IT IS FREE OF DEFECTS, MERCHANTABLE, FIT FOR A PARTICULAR PURPOSE OR NON-INFRINGING. THE ENTIRE RISK AS TO THE QUALITY AND PERFORMANCE OF THE SOFTWARE IS WITH YOU. SHOULD THE SOFTWARE PROVE DEFECTIVE, YOU ASSUME THE COST OF ALL NECESSARY SERVICING, REPAIR, OR CORRECTION. 7.IN NO EVENT SHALL THE AUTHOR, COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY REDISTRIBUTE THE SOFTWARE BE LIABLE TO YOU FOR DAMAGES, INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES ARISING OUT OF THE USE OR INABILITY TO USE THE SOFTWARE (INCLUDING, BUT NOT LIMITED TO, LOSS OF DATA, DATA BEING RENDERED INACCURATE, LOSS OF BUSINESS PROFITS, LOSS OF BUSINESS INFORMATION, BUSINESS INTERRUPTIONS, LOSS SUSTAINED BY YOU OR THIRD PARTIES, OR A FAILURE OF THE SOFTWARE TO OPERATE WITH ANY OTHER SOFTWARE) EVEN IF THE AUTHOR, COPYRIGHT HOLDER, OR OTHER PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. 8.VIOLATION OR NON-ACCEPTANCE OF ANY OF THE ABOVE TERMS IMMEDIATELY AND UNCONDITIONALLY WILL TERMINATE YOUR LICENSE. By downloading and using the software, you agree to be legally bound by these terms of license.
gigapig Posted January 6, 2015 Posted January 6, 2015 Further to the above, others peoples hard drives can not be supported. They are usually badly put together, and if you have not configured it yourself, how would you be able to describe the issues or fix them. Please first go back to the sellers support forum or technical help department.
zippo81 Posted January 6, 2015 Author Posted January 6, 2015 Ok. I can´t find who sold me it. thats why I try to figure it out by myself. Where it´s those forums that you mentions?
32assassin Posted January 6, 2015 Posted January 6, 2015 if you don't have time to build it, you are not going to have time to play it. if you learn how to set up other systems, you will see that setting up Demul for dreamcast is very easy. here is a step by step to setting this system 1. set up the emulator to run with your computer 2. you should be able to: MANUALLY! open the emulator MANUALLY! load a dreamcast image into the emulator MANUALLY! run the emulator with the game and wait for the load screen to load. after you verified that the emulator is working outside of Hypersipn. 3. set up a global emulator for your version of Demul ver 57 or 58 4. set your rom path 4a. decide if you are using demon tools or not; Set your system for one or the other. 5. select your global emulator as the default emulator 6. rename your roms to match the official XML OR create your own XML 7. Audit your roms with Hyperlaunch 8. if your roms are all in green, test launch 1 game to make sure emulator is fully configured. 9. if you get any errors, post your Hyperlaunch log and ask for help 10. no errors launch Hyperspin and see if it works.
gigapig Posted January 6, 2015 Posted January 6, 2015 Ok. I can´t find who sold me it. thats why I try to figure it out by myself.Where it´s those forums that you mentions? I don't know who sold you the drive either, so I won't know the support forum for the seller. If you have no technical knowledge then you should enjoy your purchase as it is, I'm sure it has many games on it. If however you can come back and explain your problem, that's fine. Please supply what versions of Hyperspin and Hyperlaunch the drive contains. Please supply any relevant logs and post them according to the "Newbie guide to posting" on the main forum. Please search for your problem on the forum, someone may have had the same fault. Also if the drive contains Hyperlaunch 2.5, this version is no longer supported, but there are many guides that ciuld help you. Good luck.
sonicboom88 Posted January 6, 2015 Posted January 6, 2015 I don't know who sold you the drive either, so I won't know the support forum for the seller.If you have no technical knowledge then you should enjoy your purchase as it is, I'm sure it has many games on it. If however you can come back and explain your problem, that's fine. Please supply what versions of Hyperspin and Hyperlaunch the drive contains. Please supply any relevant logs and post them according to the "Newbie guide to posting" on the main forum. Please search for your problem on the forum, someone may have had the same fault. Also if the drive contains Hyperlaunch 2.5, this version is no longer supported, but there are many guides that ciuld help you. Good luck. I bet its Chris Upchurch lool Hyper Helper Ready To Help
gigapig Posted January 6, 2015 Posted January 6, 2015 I bet its Chris Upchurch lool Chris Who? I'm sure he has a returns policy and a 1 year warranty. I'd return it and box a PS4
