Could Someone Please Test Tekken (1) in RetroArch + Mednafen Core?
newoski
Hi Guys,
I'm trying to play Tekken (1) in RetroArch using the Playstation Mednafen core. It works great for every other game I've tested, but with Tekken I'm getting stuck at the Galaga loading screen. No inputs are recognized at all and I can't reach the actual game. Could someone please test on their rig and let me know if they have the same problem?
Thanks so much
They are being loaded correctly with the mednafen core. Can anyone confirm that this happens on theirs?
Mine works fine, download what version of the core are you using?
This is so odd. On the latest build of RetroArch nightlies, I can bypass the loading screen if I press X.. however, X isn't even a mapped input in my config. Once I get past the loading Galaga game, I still can't use any inputs.
guyverjay, are you using keyboard/keyboard encoder or gamepad as your input?
Good point, Styphelus. I actually hadn't thought of that since it was getting so far along. I'll try a few variants and see how things go
Yup, same problem. I'm sure it works fine, as you've stated, using a gamepad. But with keyboard inputs it doesn't do anything at all. I'll probably have to use Mednafen native for that single game via Alternate Emulator.
In other news, I just discovered that my GTX 660 has coil whine on Visual Pinball. FML
I tried it and mine did the same thing, stuck on the galaga screen. I had an old version of retroarch so i just downloaded the latest stable version with the cores, moved over the psx bios from my old retroarch setup and sure enough it worked
