Bandai Datach Joint ROM System
craiganderson
any of the MESS module experts able to tinker with this?
apparently MESS now is able to read the "cards" that come with the DATACH famicom games
this article describes the process
http://mamedev.emulab.it/etabeta/2014/02/12/barcode-scanning/
from the article
EDIT (2014-02-13): As of latest MAME/MESS svn, Datach games have been moved from NES softlist to a separate Datach softlist (because the carts are different, as you can see from the pictures). Also, the base unit has been properly implemented as a passthrough cart with a separate cartslot for its minicarts. This means that to test the improvements below you now have to launch MESS with the following command
mess nes -cart datach -cart2 gamename
i do not know how to add this to the module or WHETHER possible or not?
can anybody see if it is possible?
thanks
craig
cool site
http://retrostuff.org/tag/datach/
about datach
http://en.wikipedia.org/wiki/Datach
found an unofficial nesterj by takeda that allows one to enter the barcodes to play the Bandai Datach Joint ROM System games
download emulator here = https://mega.co.nz/#!vtwTmbgI!GM8JCVuWj9emI3wU2Lv1fPb_PIqWdWKtuVMpWLrF3Eo
i am picturing a cool bezel that displays all of the characters and the associated barcodes
see page = http://retrostuff.org/tag/datach/
see it in action
4Bq5MJpNG_Y
games - Famicom: Datach Joint ROM System[edit]
Datach Battle Rush[5]
Datach Crayon Shin-Chan[5] -- NO CARDS
Datach J.League Super Top Players[5] - has cards
Datach SD Gundam World[5]
Datach Ultraman Club[5] - has cards (http://retrostuff.org/2014/01/02/ultraman-club-spokon-fight-for-datach/)
Datach YuuYuu Hakusho[5]
Dragon Ball Z: Gekitou Tenkaichi Budokai[5] - has cards (http://retrostuff.org/category/bandai/datach/)
Not all games for the Datach used the barcode feature, most likely because it was a pain to use. So Bandai also released games that probably could have been normal cart releases, and some were released as normal game carts aswell, like Crayon Shin-Chan: Orato Poi Poi, another horrible game based off a popular character to make the Datach look attractive it seems.
do you think you'll be able to pull off a module that launches the games automatically?
maybe the pinball fx/pinball arcade modules can be used as a reference?
The commandline for this is:
I am working on my own MESS AHK module now and adding in systems that haven't already been added. Let me know if the command line works for you; you may not need it if you intend on adding this to the AHK because it is cart based and should be essentially plug in play. If you are running off software lists then you might want to run a folder check or ini check for a list of barcodes. Anyway, this is how I am coding it for my AHK.
You don't need a barcode scanner, a list of barcodes for this system are here: http://retrostuff.org/2014/02/14/bandai-datach-barcodes-for-mess/
You can even setup a two system fight using EAN-8 barcodes (find these through google and also add to a ini).
To have these codes read when the game asks for them, simply open up the UI Menu Tab, go to Barcode Reader, then when prompted enter it in.
I hope this helps some of you who don't understand much about how the barcode scanner works in MESS. Have a nice day!
How to guides and custom artwork sets @ https://www.youtube.com/user/MaxwellParadigm
Themes, Wheels, Carts and Database Downloads available @ http://spacevalkyrie.weebly.com/
DrMaxwell, please go to the hyperlaunch forum and get your changes included in the official release it's stupid to have unofficial versions of the mess ahk that gets overwritten as soone as you update hyperlaunch.
