Xpadder loading blank profile on emulator exit
fire10
Hi Hyperspinners, heres a strange issue I have that hopefully someone will have a fix for.
I load my hyperspin xpadder profile via startup script on my arcade cab running win 7 to control the main menu and hyperspin navigation which works flawlessly. When I load an emulator with an xpadder profile it switches profiles from the hyperspin profile to the emulator ive chosens profile.......all perfect so far. (I watch this happen in the taskbar so know it works)
Upon exiting the emulator back to the hyperspin frontend my "blank" profile is loaded in p1 and p2 which would originally have stopped me from navigating my menus as it should be blank lol. I tried everything including making sure I had a blank profile in my "_Default" xpadder profile folder within my "hyperlaunch - profiles - xpadder" folder and a p1.xpadderprofile and p2.xpadderprofile in my "HyperSpin" xpadder profile folder. No matter what I tried upon exit it would always load a blank profile. The only way I found around this was to actually set keys to my hyperspin menu keys in the "blank" profile which works. Know I would really like to not use a work around as its obviously not correct so if someone knows why it is loading a blank profile up rather than my p1.xpadderprofile and p2.xpadderprofile in my HyperSpin xpadder profile folder it would be a great help hopefully to myself and others.
Regards Fire10
Perhaps post your logs, that might show something. I've read your post a few times but nothing is springing to mind, which startup script version are you using?
Hi Giga ill try and et my log posted when I get home tomorrow, I think im using startup script 0.5.
Speak soon mate
Fire10
Found my solution mate I had go into Hyperlaunch.ini and set Keymapper_FrontEnd_Profile=false to Keymapper_FrontEnd_Profile=Xpadder after that everything started working as it should this has been driving me nuts for ages lol
