Switching between Xbox Controller and SNES USB controller
Yardley
Hey guys, when switching between an Xbox controller and a Super Nintendo USB controller (using Xpadder) the mapping gets flipped since the A/B buttons are placed differently on both controllers. As I'm sure most of you know, on the SNES controller its B/A and on the Xbox controller it's A/B. So If I map the controls using the Xbox controller jump will be assigned to the "B" button furthest to the right which is where it should be, but if I switch to the SNES controller the mapping "follows" the B button and since it's backwards on the SNES controller, jump ends up being in the wrong place. Any way to get around this?
I can obviously map the buttons to the SNES controller in Xpadder but then if I switch to the Xbox controller it will again be backwards. My goal is to make both interchangeable.
  guyverjay said:
Shouldn't you be mapping the snes buttons to the correct positions and ignore what letters are where?
Yes but if I map lets say A/B on the SNES controller, when I plug in and Xbox controller it will automatically switch to B/A on the Xbox controller. I want it to remain consistent across controllers.
