andyco40 Posted March 9, 2015 Posted March 9, 2015 Hi all Just upgrade my cab with a i7 4770k cpu and a gigabyte z97x gamer 5 mboard plus added a ssd for the os for fast boot. so now got to change hyperspin settings and emulators to d drive cus ssd is c drive now lol.
andyco40 Posted March 10, 2015 Author Posted March 10, 2015 hyperhq wos setup on c drive so when I run hyperspin it does no see the xmls cus its d drive now. I can run any system thro hyperlaunchhq don't have to change owt there.
gigapig Posted March 10, 2015 Posted March 10, 2015 So you need to run through Hyperlaunch HQ, Global emulators and change paths to all emulators. Also change the path to HyperLaunch in the Hyperspin setting.ini found in :Hyperspin\Settings.
Nexus23 Posted March 10, 2015 Posted March 10, 2015 Hi, set the Drive letter to the same before! That is the easy way, after that you don't need to change anything! My rom drive was on F: after new installatin befor was on G:... Go to disk management and give them the same letter as before and all is fine!
gigapig Posted March 10, 2015 Posted March 10, 2015 That would not work in this case, as his original install was on C drive.
Nexus23 Posted March 10, 2015 Posted March 10, 2015 Oh, that is bad Open Global Emulators.ini and set change all C: to D: with a text editor should work? Edit: Make some place on C: and put the Frontend completely back. I would make it! Or edit the .ini and set the path to HL,HLHQ, and third party tools. then it would have to run.
