shadowsword501 Posted March 10, 2015 Posted March 10, 2015 im trying to use the nes on it with jnes every thing has been fine, i can test the games in hyperlaunchHQ and it works without trouble, it dectects all my roms and my emulator but my one problem i did not expect to happen is that when i go into hyperspin and click a game in nes Nothing happens, no error, no game loading, nothing! please help me
gigapig Posted March 10, 2015 Posted March 10, 2015 Check your HyperHQ settings Have you got speakers connected? Is HyperLaunch still running in the system tray? If so close it.
showstopper Posted March 10, 2015 Posted March 10, 2015 If it works in hlhq but not hs it is usually a hyperlaunch issue. Do you have hl in the root of your hyperspin folder? Is this a new setup? How to update HyperLaunch
shadowsword501 Posted March 10, 2015 Author Posted March 10, 2015 i use earphones, and hyperHQ is always closed when i launch, i dont normaly mess with hyperhq, i mainly use hyperlaunchHQ
shadowsword501 Posted March 10, 2015 Author Posted March 10, 2015 just checked half of them and they are all correct in the xml and in the folder.
shadowsword501 Posted March 10, 2015 Author Posted March 10, 2015 its sorta new, there is a hyperlaunch in the folder
gigapig Posted March 10, 2015 Posted March 10, 2015 Yes if you've just installed it you probably need to change the path to HyperLaunch in the Hyperspin setting.ini found in the :\Hyperspin\settings, folder.
shadowsword501 Posted March 10, 2015 Author Posted March 10, 2015 I fixed it thanks, it turns out i was missing the exe path and the module in hyperlaunch
