Gambino147 Posted April 13, 2015 Posted April 13, 2015 I have just installed the nulldc everything worked great even through hyperlaunchHQ but when I tried to run a game through hyperspin I got this problem... When I select dreamcast it doesn't go into the game wheel it just reboots back into the main game system menus again =/ Btw I have tried a search but the thread seems to be missing from the forum now, so don't crucify me. It's my first post on here so be gentle haha! edit.. I just realised that this might be in the wrong section, feel free to move it.
gigapig Posted April 13, 2015 Posted April 13, 2015 Welcome to the forum Gambino. You've probably set something in HyperHQ, either your set some wheel filter for Dreamcast or not added the Rom path. You shouldn't need any filtering for that system so remove any check marks under wheel filters. Also check the extensions box, which should also be empty unless you want to filter. I'd move the thread if I knew how, but I'm still learning the new site. Edit: I moved it, wasn't so hard
Gambino147 Posted April 14, 2015 Author Posted April 14, 2015 Thanks it was the filters I had ticked in HyperHQ
Gambino147 Posted April 14, 2015 Author Posted April 14, 2015 Can we rename the title [sOLVED] Dreamcast game wheel not working... Or something to that effect.
