samcraig Posted April 17, 2015 Posted April 17, 2015 How do I get an image file to mount in daemon tools lite? Ive watched a ton of youtube videos that show you have to go into the hyperlaunch.ahk file and edit it but I have no hyperlaunch.ahk file, only the exe. Im trying to set up sega saturn and it does load ssf but in the bottom right next to the flashing red light it says drive emptyand all that show up are the bios. I know it says in the little ? next to CDDrive in hyperlaunchhq that if all I see are bios then the cddrive variables are wrong but I dont know what they are talking about. I have changed the nuber from 0 all the way to 18 and it never changes, I have also tried both dt and scsi. If I premount a game then start hyperspin it loads up fine but thats only because I loaded the image. So how do I get it to load the image itself? BTW I am using HyperSpin Install v1.3.3.0 and HyperlaunchHQ 3. Can someone help Please
iNTiGOD Posted April 17, 2015 Posted April 17, 2015 Have you seen Ron's excellent guide on setting up Daemon tools? It worked for me. Also please don't use daemon tools lite version 5. Stick with version 4. MAME High Score Tutorial For HyperSpin
samcraig Posted April 17, 2015 Author Posted April 17, 2015 Thank you very much. I will try as soon as I get home. Been pulling my hair out trying to get hyperspin to work and Google searches don't lead to the links and searching this page doesn't bring up what I'm looking for. Another question, I have hyperhq set to get my snes roms and my snes emulator but when I try in hyperspin it says I don't have the super Nintendo entertainment center ahk and there is no ahk on hyperlist site so where do I get the ahk files
iNTiGOD Posted April 17, 2015 Posted April 17, 2015 I'm sure we can get this working. Firstly, I noticed you mentioned hyperhq is setup for ones rooms and emulator. Remember hyperhq is for the hyperspin front end (all the artwork etc) not the launching of emulators. You need to be using hyperlaunchhq (found in your hyper launch folder)..... now known as rocketlauncher. Here is a great from gigapig on setting up the correct folder structure and setup for hyperlaunch. Even though its for MAME the fundamentals are the same for SNES.If you still have trouble post a hyperlaunch logfile as outlined here which will help diagnose the issue. MAME High Score Tutorial For HyperSpin
samcraig Posted April 17, 2015 Author Posted April 17, 2015 still no luck with saturn. Heres the log file DEBUG 2015-04-17 02:57:49 [1] HyperEmu.Ini.HyperLaunchHQIni HyperEmu.Ini.HyperLaunchHQIni..ctor(:0) – HyperLaunchHQ ini file path is D:\HyperSpin Install v1.3.3.0\hyperlaunchhq v1.0.13.0\Settings\HyperLaunchHQ.ini DEBUG 2015-04-17 02:57:50 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\hyperlaunchhq v1.0.13.0\Settings\HyperLaunchHQ.ini DEBUG 2015-04-17 02:57:50 [1] HyperEmu.Ini.HyperLaunchHQIni HyperEmu.Ini.HyperLaunchHQIni.readIniValues(:0) – Window coordinates are : 1150|960|125|125 DEBUG 2015-04-17 02:57:50 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\Settings\HyperLaunch.ini DEBUG 2015-04-17 02:57:51 [1] HyperEmu.Ini.HyperLaunchHQIni HyperEmu.Ini.HyperLaunchHQIni..ctor(:0) – HyperLaunchHQ ini file path is D:\HyperSpin Install v1.3.3.0\hyperlaunchhq v1.0.13.0\Settings\HyperLaunchHQ.ini DEBUG 2015-04-17 02:57:51 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\hyperlaunchhq v1.0.13.0\Settings\HyperLaunchHQ.ini DEBUG 2015-04-17 02:57:51 [1] HyperEmu.Ini.HyperLaunchHQIni HyperEmu.Ini.HyperLaunchHQIni.readIniValues(:0) – Window coordinates are : 1150|960|125|125 DEBUG 2015-04-17 02:57:51 [1] HyperEmu.Forms.BaseWindow HyperEmu.Forms.BaseWindow..ctor(:0) – Main Folder is D:\HyperSpin Install v1.3.3.0 DEBUG 2015-04-17 02:57:51 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\Settings\HyperLaunch.ini DEBUG 2015-04-17 02:57:57 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\Settings\Global Emulators.ini DEBUG 2015-04-17 02:57:57 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\Settings\Global HyperLaunch.ini DEBUG 2015-04-17 02:57:57 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\Settings\Global HyperPause.ini DEBUG 2015-04-17 02:57:57 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\Settings\Global Bezel.ini DEBUG 2015-04-17 02:59:18 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\Settings\Sega Saturn\Emulators.ini DEBUG 2015-04-17 02:59:18 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\Settings\Sega Saturn\Games.ini DEBUG 2015-04-17 02:59:18 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\Settings\Sega Saturn\HyperLaunch.ini DEBUG 2015-04-17 02:59:19 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\Settings\Sega Saturn\HyperPause.ini DEBUG 2015-04-17 02:59:19 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\Settings\Sega Saturn\Bezel.ini DEBUG 2015-04-17 03:00:09 [7] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\Settings\Global Emulators.ini DEBUG 2015-04-17 03:00:09 [7] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\Settings\Sega Saturn\Emulators.ini DEBUG 2015-04-17 03:01:02 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\Settings\Global Emulators.ini DEBUG 2015-04-17 03:01:02 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\Settings\Sega Saturn\Emulators.ini DEBUG 2015-04-17 03:01:02 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\HyperSpin Install v1.3.3.0\Modules\Sega Saturn\SSF.ini
samcraig Posted April 17, 2015 Author Posted April 17, 2015 Ok at this point I have 3 hyperspins. I downloaded a 1tb preconfiged torrent and snes, sega gen, nes, and mame work fine but disc systems never boot daemon, says something like error failed to launch preogram or document . I also have a fresh installfrom the hyperspin site that doesnt throw any errors for saturn but doesnt mount the image, read previous post. I also have another 1 of the tbs just for the emulators and games. These have been the most stressful days Ive had in a long time. Ive watched far too many youtube tutorials that dont seem to work. why cant I get disc games to work? heres the tb hyperspin log it doesnt show any errors DEBUG 2015-04-17 04:31:41 [1] HyperEmu.Ini.HyperLaunchHQIni HyperEmu.Ini.HyperLaunchHQIni..ctor(:0) – HyperLaunchHQ ini file path is D:\Hyperspin 2\Hyperlaunch\HyperlaunchHQ\Settings\HyperLaunchHQ.ini DEBUG 2015-04-17 04:31:41 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Hyperlaunch\HyperlaunchHQ\Settings\HyperLaunchHQ.ini DEBUG 2015-04-17 04:31:41 [1] HyperEmu.Ini.HyperLaunchHQIni HyperEmu.Ini.HyperLaunchHQIni.readIniValues(:0) – Window coordinates are : 1150|960|150|150 DEBUG 2015-04-17 04:31:41 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\HyperLaunch.ini DEBUG 2015-04-17 04:31:41 [1] HyperEmu.Ini.HyperLaunchHQIni HyperEmu.Ini.HyperLaunchHQIni..ctor(:0) – HyperLaunchHQ ini file path is D:\Hyperspin 2\Hyperlaunch\HyperlaunchHQ\Settings\HyperLaunchHQ.ini DEBUG 2015-04-17 04:31:41 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Hyperlaunch\HyperlaunchHQ\Settings\HyperLaunchHQ.ini DEBUG 2015-04-17 04:31:41 [1] HyperEmu.Ini.HyperLaunchHQIni HyperEmu.Ini.HyperLaunchHQIni.readIniValues(:0) – Window coordinates are : 1150|960|150|150 DEBUG 2015-04-17 04:31:41 [1] HyperEmu.Forms.BaseWindow HyperEmu.Forms.BaseWindow..ctor(:0) – Main Folder is D:\Hyperspin 2 DEBUG 2015-04-17 04:31:41 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\HyperLaunch.ini DEBUG 2015-04-17 04:31:44 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Global Emulators.ini DEBUG 2015-04-17 04:31:44 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Global HyperLaunch.ini DEBUG 2015-04-17 04:31:44 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Global HyperPause.ini DEBUG 2015-04-17 04:31:44 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Global Bezel.ini DEBUG 2015-04-17 04:31:50 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Sega Saturn\Emulators.ini DEBUG 2015-04-17 04:31:50 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Sega Saturn\Games.ini DEBUG 2015-04-17 04:31:50 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Sega Saturn\HyperLaunch.ini DEBUG 2015-04-17 04:31:50 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Sega Saturn\HyperPause.ini DEBUG 2015-04-17 04:31:50 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Sega Saturn\Bezel.ini DEBUG 2015-04-17 04:32:12 [5] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Global Emulators.ini DEBUG 2015-04-17 04:32:12 [5] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Sega Saturn\Emulators.ini DEBUG 2015-04-17 04:32:18 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Global Emulators.ini DEBUG 2015-04-17 04:32:18 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Sega Saturn\Emulators.ini DEBUG 2015-04-17 04:32:18 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Modules\SSF\SSF.ini DEBUG 2015-04-17 04:32:43 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Global Emulators.ini DEBUG 2015-04-17 04:32:43 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Sega Saturn\Emulators.ini DEBUG 2015-04-17 04:32:43 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Modules\ssf\SSF.ini DEBUG 2015-04-17 04:32:53 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Global Emulators.ini DEBUG 2015-04-17 04:32:53 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Global HyperLaunch.ini DEBUG 2015-04-17 04:32:53 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Global HyperPause.ini DEBUG 2015-04-17 04:32:53 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Global Bezel.ini DEBUG 2015-04-17 04:33:14 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Sega Saturn\Emulators.ini DEBUG 2015-04-17 04:33:14 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Sega Saturn\Games.ini DEBUG 2015-04-17 04:33:14 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Sega Saturn\HyperLaunch.ini DEBUG 2015-04-17 04:33:14 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Sega Saturn\HyperPause.ini DEBUG 2015-04-17 04:33:14 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Sega Saturn\Bezel.ini DEBUG 2015-04-17 04:33:18 [10] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Global Emulators.ini DEBUG 2015-04-17 04:33:18 [10] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File D:\Hyperspin 2\Settings\Sega Saturn\Emulators.ini
SIMPLYAUSTIN Posted April 17, 2015 Posted April 17, 2015 https://youtu.be/2HuMMEimOHc Simply Austin's YouTube
rfancella Posted April 17, 2015 Posted April 17, 2015 Hi, Maybe I can clear up a couple things that might help. Updating HyperLaunch3 (AKA RocketLauncher) is done through the GIT. Or you can go to RLauncher.com and download it from there. The log you posted is not the HyperLaunch log. When posting logs of any sort, please use code tags. Much of this is explained in my guide that iNTiGOD kindly linked to. Thanks, Ron Ok at this point I have 3 hyperspins. I downloaded a 1tb preconfiged torrent and snes, sega gen, nes, and mame work fine but disc systems never boot daemon, says something like error failed to launch preogram or document . I also have a fresh installfrom the hyperspin site that doesnt throw any errors for saturn but doesnt mount the image, read previous post. I also have another 1 of the tbs just for the emulators and games. These have been the most stressful days Ive had in a long time. Ive watched far too many youtube tutorials that dont seem to work. why cant I get disc games to work? heres the tb hyperspin log it doesnt show any errors ...snip... Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
samcraig Posted April 17, 2015 Author Posted April 17, 2015 Ok so I went and watched the video you linked did what it said and it tells me hyperlaunch.log doesnt exist. I want to cry at this point
samcraig Posted April 18, 2015 Author Posted April 18, 2015 Here is exactly what it says on the preconfigured torrent, if I had a log file Id post it but I dont so I am hoping someone can point me to what is going on Error: Failed attempt to launch program or document: Action: <”C:/Program Files (x86)DAEMON Tools Lite\daemon.exe”> Params: <-mount 0,”D:\Games\Sega Saturn\Alien Trilogy V1.000 (1996)(Acclaim)(PAL)(M4)(!).nrg”> The current thread will exit. Specifically: The system cannot find the file specified. Line# ---> 585:RunWait,%DAEMONTOOLS% -mount 0, “%romPath5%%romName%%romExtension%”
SIMPLYAUSTIN Posted April 18, 2015 Posted April 18, 2015 What torrent is this that you are using? There is no quick fix to make hyperspin run. You will have to set it up. As your using a torrent we do not know what version you are using or even how it has been set up. For us to guide you in any way would be almost impossible. Try to keep all the media and art. But start from scratch with the install of Hyperspin. There are lots of people here, guides and loads of information on how to get it setup. Now you already have the media it will take less than an hour to do... rather than taking weeks to try and fix it. Simply Austin's YouTube
iNTiGOD Posted April 18, 2015 Posted April 18, 2015 You can do it!! MAME High Score Tutorial For HyperSpin
SIMPLYAUSTIN Posted April 18, 2015 Posted April 18, 2015 Perfect tut on how to set it up. Although version 5 does not work I dont think with Daemontools and RocketLauncher. But as always a great tut. Much better to learn with visual aids insted of blocks of texts Simply Austin's YouTube
samcraig Posted April 18, 2015 Author Posted April 18, 2015 Just an update, it seems the third time is the charm. Yesterday after all the frustration I decided 1 last time to start from scratch, thinking maybe I didnt download something completely, I deleted everything and downloaded everything again. IT WORKED!!! Saturn is up and running along with sega cd, and all the others. I want to thank you guys for your patience and help. As a side note I only got the torrent for the artwork and game colections.
SIMPLYAUSTIN Posted April 18, 2015 Posted April 18, 2015 Glad you got it working mate. Its all a pain... but its worth it Simply Austin's YouTube
shaner316 Posted April 18, 2015 Posted April 18, 2015 good info. hopefully I can get mine up and running soon too
ralf67 Posted April 24, 2015 Posted April 24, 2015 Hello, i'am new here and i have a questionneed some help, how can i get the download package complete.
