ScummVM game ini needed
silverfox0786
Hi,
Is this it??
http://www.hyperspin-fe.com/topic/5930-scummvm-17
Thanks,
Ron
http://www.hyperspin-fe.com/forum/showpost.php?p=52295&postcount=81
im trying to find the thread to get the ini file for scummVM from the link on the ahk. But since the upgrade of the forum links don't actually go where theya re supposed to
can some one please help
no its not
that the game XML
what I need is the precompiled ini that goes in the appdata folder of windows
my PC crashed and I had to reinstall and forgot to back it up
it basically lists all the games within scummvm with all the correct settings
its was already made so was easy to use other wise I would have to sit there and reset each and every game up
  • 3 weeks later...
Did you ever get the ini or figure it out?
I have the same issue.
Also can it be pointed to a diffrent directory. I use my drive as a portable setup.
yes I managed to get it from the original source and edited the paths to point to mine and all is working again
this time I saved the file to a remote server so I can retrieve it if I ever needed
  • 4 weeks later...
