snstay Posted April 29, 2015 Posted April 29, 2015 Hey all, got my dice emulator setup.....again after i had to redo it. Well i have all the wheel art and when i launch into dice they are all there but when the wheel gose around a select few disappear. Not all but a few and only when they are out of sight then come back around. I tried doing diffrent checks in hyperHQ but that didnt help. Any ideas? Thanks
Dime333 Posted April 29, 2015 Posted April 29, 2015 I had some really strange issues with that too. I switched to a different DB and that fixed it.
Dazz Posted April 29, 2015 Posted April 29, 2015 yeah, something wrong with your database file... probably an invalid character.
32assassin Posted April 29, 2015 Posted April 29, 2015 you should also open your XML in notepad++ and compare the names to your wheel names. Hyperspin is case sensitive, if the wheel names don't match (including the caps) in the XML; the wheels will disappear as you make a complete scroll. you can also try this program http://www.hyperspin-fe.com/topic/5356-hypert00ls-your-hyperspin-and-hyperpausehyperlaunch-media-help/ extract it to your Hypespin folder - select a system - press Check it will I identify all your missing artwork. case mismatch names will show up as missing. if you have an invalid character in your XML. it will also tell you and the most important thing; it will tell you where to find it.
snstay Posted April 30, 2015 Author Posted April 30, 2015 All Right!! took some renaming between xml and wheel names but i got them all matched up and working thanks for the advise.
