Tur-Matcher 1.13
Turranius
  • 2 months later...
Hi great tool, I really like how it ca be used to match everything :P
Have you considered add CRC match so files with real extrange names are found based on is CRC found on XML?
I do that in my little app called HyperArchiver some time ago: http://www.hyperspin-fe.com/topic/1931-hyperarchiver-0007
It search rom files, zip them thogeter and create the rommapping.ini so you can have 2 or more versions of the same game inside a zip, and Rocketlauncher will ask you wich one you want to launch ;)
The app is writen in AutoIt and the source is included (is a mess :( ). Im no updating that anymore but will be nice to see all features in a single app ;)
Thanks for the kind words. Yeah, its funny how you create something for yourself and suddenly lots of people wants to use it =)
I have not considered doing that actually. Its kinda totally in the opposite direction of how this program works. I guess I could give it a try.
Another thing I wanted to add was the ability to match .zipped roms. You can do that today, but only the zip file changes name, not the rom inside of it. I usually get passed that by extracting all the roms, doing a match/rename on the extracted files and then zipping them back up, but I'd be nice to do it directly.
I'll have a look at your script and perhaps I can steal some parts =) Thanks.
Mame related stuff: FTP: grandis.nu, port 21, user:misc, pass:misc
http://grandis.nu/software
Tur-Matcher - Match your roms/media/XML files.
Another Idle Volume Adjuster - Automatically control the volume.
How to: Use MAME Extras as material for HyperPause
How to: Use eXoDOS 2.0 as material for HyperPause
Here is a test of 1.14b1 with CRC support when using an XML. Thanks knewlife. I stole some code and found that XMLDomWrapper.au3 was a lot faster in reading the XML than my own little hack, so started using that one instead. Sped it up a LOT initially when reading XML (If using that as source names).
Tur-Matcher 1.14b1.zip
Glad you can use some of the code. XMLDomWrapper has been updated since I release that but the new version is very confusing... I spend hours yesterday trying to make the last version work... Just because I want the latest version...
So keep using the old version :P
I use 7z command line utility to zip files in HyperAechiver but you can use the 7z.dll that allows you to get data from files without uncompress them.. If I remember right you can get the CRC of files inside an 7z archive... I might be wrong...
