HyperSpin Posted May 8, 2015 Posted May 8, 2015 File Name: Fat Match Media Renamer 0.3 File Submitter: HyperSpin File Submitted: 08 May 2015 File Category: ROM/Database/Renaming tools Credits: FatOne85 This is a great tool to rename your media! The file path that you put in the "roms" field is the path that has your names you like while the path on the first tab below that is for the path you want the media files to change to mirror the roms path. Note you don't have to use the roms path here. Sometimes I'll put in the videos path or wheel path (a path that has the corrected media files) and it will work gloriously with renaming all the files in the image path. After you select your paths, just use the last tab named results, press start. After the results happen, press select best option under the options button, then press rename. FatMatch is a renaming utility created by FatOne85. Fatmatch uses fuzzy logic to rename artwork and video files to match your rom set. Some benefits over other similar software are: - Immediate Progress Report on Fuzzy Matching - Folder selection as opposed to list copy-pasting - Treeview of results for easier match picking - Software-controlled file renaming What's New in Version 0.3 (See full changelog) •-------------------------------- •Version 0.3 - March 01 2009 •-------------------------------- •- Tweaked match process •- Fixed list missing images bug (Value 101 Error) •- Fixed match results not displaying proper percentage •- Added "Export Copy Script" Option •-------------------------------- •Version 0.2 - February 25 2009 •-------------------------------- •- Added "List Missing Images" Functionality •- Redesigned Match Scan layout •- Fixed Empty Folder Bug •- Fixed Rename Nothing Selected Bug •- Fixed Process Yielded No Results Bug •- Added "Select Best Matched" Option •- Added "Select Single Matches" Option •- Added "Highlight Range" Option •- Added "Collapse/Expand" Option •- Added functionality of highlighting duplicates •-------------------------------- •Version 0.1.1 - February 18 2009 •-------------------------------- •- Fixed font resizing issue when using larger DPI •- Fixed listing results from highest to lowest percentage match •- Tweaked search algorithm for strings containing numbers Click here to download this file
ninja2bceen Posted July 27, 2018 Posted July 27, 2018 Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
tallpr24 Posted November 27, 2019 Posted November 27, 2019 Hello. I'm using the bezel project app to download all the bezels for all my roms. Can i use this app to rename the bezels to match the roms instead of the renaming the roms?
Creezz67 Posted November 27, 2019 Posted November 27, 2019 23 minutes ago, tallpr24 said: Hello. I'm using the bezel project app to download all the bezels for all my roms. Can i use this app to rename the bezels to match the roms instead of the renaming the roms? yes
ninja2bceen Posted December 1, 2019 Posted December 1, 2019 Or just download them all on emumovies ftp site. I’ve been uploading all the converted ones from the bezel project so they will work in hyperspinSent from my iPhone using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
