hlsl mame 149
lprong
Hi i go away for weeks at a time so don't get as much time as I'd like to do this stuff but i can get mame 149 to work with directdraw but not with d3direct I'm running windows 8.1 could any one give any advise...
I can't really help with your situation, but I couldn't het HLSL to work worth a damn with 149 myself.
I just went ahead and updated to 160.1 and HLSL worked like a charm. 161.1 is even better.
So if you're after that look I'd recommend biting the bullet and updating.
That's why I edited it. It's out that soon?
I will probably update to the next version that makes major HLSL improvements. I'm still hoping that rumor of improved Vector HLSL actually happens.
Have thought about updating but then how many roms chd will i need to update does 160.1 run mame ui
Yeah. 161.1 is also available for MAMEUIFX. Jumpstiles has his compiled extra-awesome version here somewhere. Not sure how much the difference between version is size-wise though.
That may be my best option thanks
Good luck. And if you run AAE you may need to keep some of those older 149 roms.
