Tribe Fan Posted May 20, 2015 Posted May 20, 2015 This is a weird issue that I've been struggling with for a while now and haven't found a solution for. When I first open a menu, the video on the selected item will play with no problems. When I scroll down to any other item, though, the video won't load. If I scroll down to an item that has its own theme, the video will play normally. I only seem to be having this problem with mp4's. I still use flv's on my main menu and I don't have this issue with those. Any ideas? Thanks.
gigapig Posted May 20, 2015 Posted May 20, 2015 If it's on the sub wheels which I'm guessing it is, you need to fire up Hyper HQ select the system and click the "Navigation/Themes" tab, then check the "Reload Backgrounds" box. This happens when you don't have a theme for every game and HS is using the Default theme for those without. You'll need to do it for every system, I do this every time I set up a new system.
Tribe Fan Posted May 20, 2015 Author Posted May 20, 2015 Man, you saved me again!!! Thanks a lot! I don't know when I changed that, but man was that ever frustrating. Thanks again.
